I am looking for wiring diagrams for a 2002 mustang . I have the wire colors for some but i am looking for an actual line diagram which shows all the wires. It would be greatly appreciated if you could tell me where to get them.
THANKS
For the vehicle line diagrams, you'll probably have to go to a Ford dealership or if you're lucky, your library will have a copy of the service manual. You may also be able to purchase a Chilton's manual from a local auto parts store or even on line that may have what you're looking for. Just in case you don't already have this, here's what I have for a 2002 Mustang:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow & lt. grn/pur|+ |ignition harness |
| STARTER|WHITE/ pink |+ |ignition harness |
| IGNITION|RED / lt. green |+ |ignition harness |
| SECOND IGNITION|gray / YELLOW |+ |ignition harness |
| ACCESSORY|BLACK/ lt. green |+ |ignition harness |
| SECOND ACCESSORY|RED / black |+ |ignition harness |
| POWER LOCK|lt. green |+ |low in drivers kick or *1 |
| POWER UNLOCK|purple |+ |low in drivers kick or *1 |
| LOCK MOTOR|RED / white | |low in drivers kick or *1 |
| UNLOCK MOTOR|RED / orange | |low in drivers kick or *1 |
| DISARM DEFEAT|pink/orange | |GEM module *1 |
| PARKING LIGHTS +|brown | |light switch or drivers kick|
| PARKING LIGHTS -|WHITE/ black | |*1 |
| HEADLIGHTS|RED / yellow |+ |light switch |
| DOOR TRIGGER|*2 |- |*2 |
| DOME SUPERVISION|BLACK/ white |+ |drivers kick panel or *1 |
| TRUNK/HATCH PIN|BROWN / white |- |drivers kick panel or *1 |
|TRNK/HTCH RELEASE|purple / YELLOW |+ |drivers kick panel |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM|dk. GREEN/ purple |- |drivers kick panel or *1 |
| DISARM NO UNLOCK| | | |
| TACHOMETER|*3 | |*3 |
| SPEED SENSE|WHITE/ orange | |PCM pin 68 *4 |
| BRAKE WIRE|RED / lt. green |+ |brake switch |
| HORN TRIGGER|yellow/lt. green |- |steering column or *1 |
| WIPERS|white & dk. blu/orn |+ |wiper motor |
| LF WINDOW UP/DN|wht/blk - wht/blk |A |drivers window motor |
| RF WINDOW UP/DN|tan/blu - wht/yel |A |drivers kick panel |
| LR WINDOW UP/DN|yel/blu - gry/orn |A |drivers kick panel |
| RR WINDOW UP/DN|yel/blk - RED / blk |A |drivers kick panel |
| RADIO 12V|lt. GREEN/ violet | |at the radio |
| RADIO GROUND|black | |at the radio |
| RADIO SWITCH|BLACK/ pink | |at the radio |
| RADIO ILLUMINATE|lt. blue/red |+ |at the radio |
| POWER ANTENNA|ORANGE / lt. blue |+ |at the radio |
| LF SPEAKER|orn/grn - blu/wht | |at speaker or amplifier *5 |
| RF SPEAKER|wht/grn - grn/orn | |at speaker or amplifier *5 |
| LR SPEAKER|gry/blu - tan/yel | |at speaker or amplifier *5 |
| RR SPEAKER|orn/red - brn/pnk | |at speaker or amplifier *5 |
Notes:
NOTE: This vehicle has the PATS anti-theft system. Use DEI part number 555F to bypass during remote start operation. *1 Also found at the GEM module located above the drivers kick panel to the drivers side of the steering column. *2 There are two door trigger wires. Use yellow/black for the drivers door and gray/red for the passengers door. Both wires are found above the drivers kick panel in a 20 pin connector. Use both wires and diode isoate each. See direct fax document #1076 for wiring information. *3 For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the pink/white. All of these wires are found at the coil pack. The 4.6L motor uses a separate coil for each cylinder. Go to any coil and use the wire that is NOT red or WHITE/ lt. blue. *4 The PCM is located behind the passenger kick panel. *5 The amplifier is located just below the radio.
the12volt • Support the12volt.com
I already have this info, but thanks anyway.
