Print Page | Close Window |
2014 Hyundai Accent Alarm/Remote Start/Stereo WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138153 Printed Date: May 03, 2024 at 2:14 AM Topic: 2014 Hyundai Accent Alarm/Remote Start/Stereo Wiring Posted By: bency Subject: 2014 Hyundai Accent Alarm/Remote Start/Stereo Wiring Date Posted: January 06, 2015 at 1:51 AM Hi,
I am looking for complete wiring diagram of Hyundai Accent 2014 or its called as Verna Fluidic in India. ------------- Ben Replies: Posted By: tonanzith Date Posted: January 06, 2015 at 2:15 PM This is the American wiring. Yours may be a bit different so definitely verify connections using a meter.
12 Volts green (40A) + ignition switch, black 6 pin plug, pin 1 Second 12 Volts blue (40A) + ignition switch, black 6 pin plug, pin 5 Starter white + ignition switch, black 6 pin plug, pin 3 Second Starter N/A Ignition pink + ignition switch, black 6 pin plug, pin 4 Second Ignition N/A Third Ignition N/A Accessory orange + ignition switch, black 6 pin plug, pin 2 Second Accessory yellow + ignition switch, black 6 pin plug, pin 6 Third Accessory N/A Keysense blue/orange - ignition key switch, white 6 pin plug, pin 4 Data Bus blue/org (immobilizer data); yellow (immob. light) data; - lt left of dash fuse box, black 21 pin plug, pins 11, 3 Can Bus High green (C-CAN) data data link connector, black 16 pin plug, pin 6 Can Bus Low orange (C-CAN) data data link connector, black 16 pin plug, pin 14 Can Bus Sw N/A Power Lock brown (w/BCM); (w/o BCM add actuator in driv door) - driver kick, white 39 pin plug, pin 15 Power Unlock gray (w/BCM); (w/o BCM add actuator in driv door) - driver kick, white 39 pin plug, pin 16 Lock Motor gray (models with BCM) 5 wire dash fuse box, white 42 pin plug (F), pin 22 Driver Unlock Motor brown (models with BCM) 5 wire dash fuse box, white 42 pin plug (F), pin 40 Passenger Unlock Motor brown (models with BCM) 5 wire dash fuse box, white 42 pin plug (F), pin 26 Parking Lights (-) pink/black or orange - headlight switch, wht 14 pin plug, pin 7, or wht 13 pin plug, pin 1 Parking Lights (+) GREEN/ black (L); yellow/black (R) + dash fuse box, white 42 pin plug (F), pins 35, 34 Hazards blue/black (models with BCM) - BCM above gas pedal, white 20 pin plug, pin 4 Turn Signal (Left) green + dash fuse box, white 42 pin plug (F), pin 38 Turn Signal (Right) blue + dash fuse box, white 42 pin plug (F), pin 31 Headlight pink/black (LO); pnk or wht (HI) (w/ign on only) - headlight sw, wht 14 pin plg, pins 12, 13, or wht 13 pin plg, pins 4, 9 AutoLights green (interrupt to turn off autolights) - headlight switch, white 13 pin plug, pin 3 Reverse Light green + driver kick, white 39 pin plug, pin 39 Left Front Door Trigger BROWN / orange - driver kick, white 39 pin plug, pin 2 Right Front Door Trigger pink - driver kick, white 39 pin plug, pin 1 Left Rear Door Trigger (same as right front door trigger) Right Rear Door Trigger (same as right front door trigger) Dome Supervision (same as right front door trigger) Trunk/Hatch Pin green - driver kick, white 39 pin plug, pin 25 Rear Glass Pin N/A Hood Pin N/A Trunk/Hatch Release (locks/unlocks along with doors on hatchback) Trunk Release Motor N/A Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm N/A Factory Alarm Disarm gray/org (key unlock); blue/blk (unlock detection) both dbl - driver kick, white 39 pin plug, pins 12, 38 Disarm No Unlock N/A Trunk Alarm Shunt N/A Tachometer BROWN / white, green, pink, or green ac front of engine, black 12 pin plug, pin 1, 3, 5, or 7 Wait to Start N/A Neutral Safety N/A Clutch Pedal pink + clutch switch, white 2 pin plug, pin 2 Fuel Pump brown + above driver kick, white 22 pin plug, pin 6 Rear Defroster white - rear defogger sw, black 6 pin plug, pin 4, or white 12 pin plug, pin 10 Mirror Defroster (mirror same as rear defrost); blue (front deicer) - front deicer switch, black 6 pin plug, pin 4 Left Front Heated Seat gray/orange + driver kick, white 39 pin plug, pin 26 Right Front Heated Seat ORANGE / black + passenger kick, white 22 pin plug, pin 4 Speed Sense pink 4-Pulse data link conn, blk 16 pin plug, pin 3, or radio, wht 24 pin plug, pin 16 Brake Wire red + above driver kick, white 22 pin plug, pin 7 Parking Brake green - dash fuse box, white 42 pin plug (F), pin 32 Horn Trigger blue - left of dash fuse box, black 21 pin plug, pin 9 Wipers green (LO); white (HI); brown (ignition) + wiper sw, blk 14 pin plg, pins 4, 2, 3, or wht 14 pin plg, pins 3, 9, 10 Left Front Window (Up/Down) green - orange (with auto down only) A power window main switch, white 16 pin plug, pins 8 - 7 Right Front Window (Up/Down) brown - gray A driver kick, harness to rear Left Rear Window (Up/Down) yellow - white A driver kick, harness to rear Right Rear Window (Up/Down) green - blue A driver kick, harness to rear Sun Roof (Open/Close) red - gray (function with ignition on only) - sunroof switch, black 6 pin plug, pins 2 - 3 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V red + radio, white 24 pin plug, pin 12 Radio Ground black - radio, white 24 pin plug, pin 24 Radio Ignition yellow + radio, white 24 pin plug, pin 11 Radio Illumination yellow (parking lights); BLACK/ orange (dimmer) +,- radio, white 18 pin plug, pins 8, 17 Factory Amp Turn-on N/A Power Antenna pink + radio, white 18 pin plug, pin 18 Left Front Speaker (+/-) white - brown +,- radio, white 18 pin plug, pins 2 - 11 Right Front Speaker (+/-) yellow - black +,- radio, white 18 pin plug, pins 3 - 12 Left Rear Speaker (+/-) red - blue +,- radio, white 18 pin plug, pins 1 - 10 Right Rear Speaker (+/-) blue - orange +,- radio, white 18 pin plug, pins 4 - 13 Center Channel (+/-) N/A Subwoofer (+/-) N/A Aux. Audio Input Left (+/-) white - BLACK/ orange +,- radio, white 24 pin plug, pins 21 - 9 Aux. Audio Input Right (+/-) green - BLACK/ orange +,- radio, white 24 pin plug, pins 8 - 9 RSE Video (+/-) N/A RSE Audio Left (+/-) N/A RSE Audio Right (+/-) N/A Satellite Radio 12 Volts (built into radio) Satellite Radio Ground N/A Satellite Radio Ignition N/A Satellite Radio Antenna N/A Satellite Audio Left (+/-) N/A Satellite Audio Right (+/-) N/A Item Size Depth Location Headunit irregular center of dash Left Front Speaker 6.5 left front door Left Front Tweeter left front door Right Front Speaker 6.5 right front door Right Front Tweeter right front door Left Rear Speaker 6.5 left rear door Left Rear Tweeter N/A Right Rear Speaker 6.5 right rear door Right Rear Tweeter N/A Center Channel N/A Subwoofer N/A Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner (built into radio) ------------- Gary Sather |
