hyundai santa fe 2005 2.0 alarm lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138344
Printed Date: April 28, 2024 at 12:50 PM
Topic: hyundai santa fe 2005 2.0 alarm lights
Posted By: stapojj
Subject: hyundai santa fe 2005 2.0 alarm lights
Date Posted: January 26, 2015 at 7:24 AM
Hi all, I have the 2L Diesel Santa Fe 2005. When I de-activate the factory alarm with the key fob, the turn signal lights flash twice and should go off. The right hand side lights stay on!.
(Drivers side, I'm in Ireland)
From reading extensively on the net, I think it may be a sticking relay in the ETACS module. Anyone have/fix this problem?
------------- stapo
Posted By: howie ll
Date Posted: January 26, 2015 at 10:13 AM
Disconnect the battery for 20 minutes it might work.
Sticky relays used to be a problem with Scorpion alarms back in the 90s.
BTW, are you sure the alarm is factory and not a dealer add on by say Cobra using the factory remote?
Posted By: stapojj
Date Posted: January 26, 2015 at 10:23 AM
Thanks for the quick reply. it is using the standard hyundai key fob. Also I see no evidence of a non-factory alarm, so I am reasonably sure it is the factory unit. I will have to get the multimeter out and see which signals are still high when the lights are left on. I think I saw a diagram of the wires and colours on here.
Appreciate the effort. Cheers
------------- stapo
