2015 Subaru Forester Smart Key Alarm Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139133
Printed Date: May 02, 2024 at 2:06 AM
Topic: 2015 Subaru Forester Smart Key Alarm Problems
Posted By: marcodmcr
Subject: 2015 Subaru Forester Smart Key Alarm Problems
Date Posted: June 27, 2015 at 10:59 AM
I need help with this 2015 Subaru Forester, I install the alarm with the smart key and everything its ok but when the client approaches to the car with the smart key the alarm start to sound like if anyone open a door, so I need help with this problem, what happend with the key thats trigger the alarm. Thanks
Posted By: howie ll
Date Posted: June 27, 2015 at 12:47 PM
The quick answer is to use the R/start EVERY time then the usual entry procedure.
Date Posted: June 27, 2015 at 1:47 PM
Sorry but I dont understand what I have to do or what I should check in the instalation or the conections
Posted By: howie ll
Date Posted: June 27, 2015 at 1:54 PM
Was this hard wired or did you use a module such as the DB-ALL2 or Fortin equivalent?
Date Posted: June 27, 2015 at 2:04 PM
Nop, only the alarm but I dont conect any wire to start the vehicule or anti-hijack or any ignition cut
Posted By: howie ll
Date Posted: June 27, 2015 at 2:08 PM
You won't get around it then, the prox key disarms via data.
Date Posted: June 27, 2015 at 2:48 PM
But it wonts disarm the alarm it activated the alarm so I need to press the disarm button to disarm the alarm. Let me tried to explain my self, I wont speak english so well but I tried yo do it, I install the alarm and everything works good, this car had the Smart Key with the Start button so the client decide not cut any wire of the ignicion harness in that case I only use a positive and the ignition pulse for the regular fuction of the alarm. But when you arm the alarm and the alarm system its activated and you go next to the car with the smart key the alarm starts to sound if someone open a door of hit the car but nobody do anything, so my concern is if the smart key send a pulse yo some module or something that this pulse trigger the alarm, I use the wires from the door lock and the motors wires from the kick panel of the driver the same cables to goes to the door. Thanks and sorry about my English.
