Print Page | Close Window |
2014 Camry XLE, Alarm/Remote Start, Stereo WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139545 Printed Date: May 14, 2024 at 11:01 AM Topic: 2014 Camry XLE, Alarm/Remote Start, Stereo Wiring Posted By: wyciwug Subject: 2014 Camry XLE, Alarm/Remote Start, Stereo Wiring Date Posted: October 09, 2015 at 11:55 AM Hello
Does anyone have complete wiring for alarm/remote? Thanks! Any recommendation on the kit? Thanks again! ------------- DCD Replies: Posted By: tonanzith Date Posted: October 10, 2015 at 10:06 PM 2014 Toyota Camry DirectWire Vehicle Information
All Products Item Wire Color Polarity Wire Location 12 Volts green (30A) + ignition switch, white 8 pin plug, pin 5 Second 12 Volts yellow (7.5A) + ignition switch, white 8 pin plug, pin 4 Starter blue + ignition switch, white 8 pin plug, pin 7 Second Starter lt. green + ignition switch, white 8 pin plug, pin 3 Ignition black + ignition switch, white 8 pin plug, pin 6 Second Ignition pink + ignition switch, white 8 pin plug, pin 1 Third Ignition N/A Accessory white + ignition switch, white 8 pin plug, pin 2 Second Accessory N/A Third Accessory N/A Keysense green - Body ECU on dash fuse box, white 30 pin plug, pin 17 Data Bus lt. blue (RX); red (TX) data Transponder Key Amplifier on ign switch, black 7 pin plug, pins 4, 5 The immobilizer light is blue (+) at the A/C control assembly, black 16 pin plug, pin 1. The IMO - IMI are red - green in the driver kick, blue 26 pin plug, pins 4 - 5. Can Bus High blue data data link connector, white 16 pin plug, pin 6 Can Bus Low white data data link connector, white 16 pin plug, pin 14 Can Bus Sw blue (RDA keyless data); gray (SIL immobiliz comm) data Body ECU, wht 30 pin plug, pin 16; data link conn, wh 16 pin plg, pin 7 Power Lock blue (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9 Power Unlock green (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10 Lock Motor red 5 wire driver kick, white 18 pin plug, pin 18 Driver Unlock Motor gray 5 wire driver kick, white 18 pin plug, pin 12 Passenger Unlock Motor green 5 wire dash fuse box, white 36 pin plug (3C), pin 11 Parking Lights (-) black - Body ECU on dash fuse box, white 30 pin plug, pin 30 Parking Lights (+) pink + dash fuse box, white 36 pin plug (3C), pin 5 Hazards white - A/C control assembly, black 16 pin plug, pin 4 Turn Signal (Left) yellow + dash fuse box, white 36 pin plug (3C), pin 22 Turn Signal (Right) green + dash fuse box, white 36 pin plug (3C), pin 19 Headlight pink - Body ECU on dash fuse box, white 30 pin plug, pin 29 AutoLights green (interrupt to turn off autolights) - Body ECU on dash fuse box, wht 30 pin plug, pin 28 Reverse Light pink + dash fuse box, white 36 pin plug (3C), pin 7 Left Front Door Trigger blue - dash fuse box, white 36 pin plug (3C), pin 15 Right Front Door Trigger lt. blue - Body ECU on dash fuse box, wht 30 pin plug, pin 19 Left Rear Door Trigger pink - Body ECU on dash fuse box, wht 30 pin plug, pin 1 Right Rear Door Trigger black - Body ECU on dash fuse box, wht 30 pin plug, pin 6 Dome Supervision lt. green - dash fuse box, rear, white 40 pin plug (3B), pin 35 Trunk/Hatch Pin white - dash fuse box, white 36 pin plug (3C), pin 9 Rear Glass Pin N/A Hood Pin purple - dash fuse box, white 40 pin plug (3D), pin 25 Trunk/Hatch Release (use trunk release motor) Trunk Release Motor red 5 wire dash fuse box, white 36 pin plug (3C), pin 10 Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm red (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11 Factory Alarm Disarm gray (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24 Disarm No Unlock (use keysense) Trunk Alarm Shunt N/A Tachometer green ac data link connector, white 16 pin plug, pin 9 Wait to Start N/A Neutral Safety N/A Clutch Pedal N/A Fuel Pump black + driver kick, harness to rear Rear Defroster green - passenger kick, gray 18 pin plug, pin 18 Mirror Defroster (same as rear defroster) Left Front Heated Seat black + resistor left seat heater switch, black 8 pin plug, pin 6 Right Front Heated Seat purple + resistor right seat heater switch, black 8 pin plug, pin 5 Speed Sense blue or purple ac driver kick, blue 26 pin plug, pin 21 or radio, white 28 pin plug, pin 17 Brake Wire red + brake switch, white 4 pin plug, pin 1 Parking Brake yellow - dash fuse box, white 40 pin plug (3D), pin 20 Horn Trigger lt. blue - dash fuse box, white 40 pin plug (3D), pin 15 Wipers blue (LO); green (HI); pink (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) white - red A driver kick, white 18 pin plug, pins 1 - 3 Left Rear Window (Up/Down) blue - black A driver kick, white 26 pin plug, pins 1 - 15 Right Rear Window (Up/Down) yellow - lt. green A driver kick, white 18 pin plug, pins 7 - 2 Sun Roof (Open/Close) black - green (function with ignition on only) - roof console assembly, black 20 pin plug, pins 3 - 2 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V blue / YELLOW + radio, white 10 pin plug, pin 4 or white 20 pin plug, pin 1 Radio Ground brown - radio, white 10 pin plug, pin 7 or white 20 pin plug, pin 20 Radio Ignition gray + radio, white 10 pin plug, pin 3 or white 20 pin plug, pin 11 Radio Illumination green (parking lights); white (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5 On some models, they are in the white 20 pin plug, pins 2, 12. Factory Amp Turn-on N/A Power Antenna N/A Left Front Speaker (+/-) pink - purple +,- radio, white 10 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are pink - purple (woofer); pink - purple (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 11 - 26; 14 - 29. Right Front Speaker (+/-) lt. green - blue +,- radio, white 10 pin plug, pins 1 - 5 On models with amplifier, the speaker wires are lt. green - blue or yellow - pink (woofer); lt. green - blue (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 15 - 30; 12 - 27. Left Rear Speaker (+/-) black - yellow +,- radio, white 6 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are black - yellow at the amplifier under driver seat, white 30 pin plug, pins 9 - 24. Right Rear Speaker (+/-) red - white +,- radio, white 6 pin plug, pins 1 - 3 On models with amplifier, the speaker wires are red - white at the amplifier under driver seat, white 30 pin plug, pins 10 - 25. Center Channel (+/-) black - green +,- amplifier under driver seat, white 30 pin plug, pins 13 - 28 Subwoofer (+/-) pink - yellow +,- amplifier under driver seat, white 30 pin plug, pins 8 - 23 Aux. Audio Input Left (+/-) red - white +,- radio, white 28 pin plug, pins 28 - 27 Aux. Audio Input Right (+/-) black - white +,- radio, white 28 pin plug, pins 26 - 27 RSE Video (+/-) white - red (rear view camera video) +,- radio, white 16 pin plug, pins 8 - 16 RSE Audio Left (+/-) black - green (USB and bluetooth audio) +,- radio, white 12 pin plug, pins 4 - 5 RSE Audio Right (+/-) red - white (USB and bluetooth audio) +,- radio, white 12 pin plug, pins 2 - 3 Satellite Radio 12 Volts (built into radio) Satellite Radio Ground N/A Satellite Radio Ignition N/A Satellite Radio Antenna N/A Satellite Audio Left (+/-) N/A Satellite Audio Right (+/-) N/A Item Size Depth Location Headunit irregular center of dash Left Front Speaker 7.0 or 7 x 10 left front door Left Front Tweeter 2.6 or 3.1 left front dash Right Front Speaker 7.0 or 7 x 10 right front door Right Front Tweeter 2.6 or 3.1 right front dash Left Rear Speaker 7.0 or 3.1 left rear shelf Left Rear Tweeter N/A Right Rear Speaker 7.0 or 3.1 right rear shelf Right Rear Tweeter N/A Center Channel 3.1 top center of dash Subwoofer 7 x 10 left rear shelf Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner (built into radio) ------------- Gary Sather Posted By: wyciwug Date Posted: October 13, 2015 at 4:22 PM Thank you tonanzith for the wiring diagram
I just bought this Viper 4105V 1-Way 4-Button Remote Start System with Keyless Entry and this Ads-alca bypass idatalink bypass This is my first time to install remote start for a push start and using this by pass. Where can I find the Steering Lock connector? Thanks. I am looking at the wires and kindda confusing. ------------- DCD Posted By: rs specialist Date Posted: October 14, 2015 at 8:15 PM If you are using the ALCA, what firmware is it flashed for? The module is doing 99% of the install. The remote start you are installing is basically just communicating between the remotes and the module. That is a bit of an over kill for a vehicle like that.
You say smart start in the title of the post, are you installing a system with a phone app or do you mean smart key vehicle? |
