Print Page | Close Window |
Chevrolet Silverado 2015, alarm/remote start wiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140455 Printed Date: May 02, 2024 at 2:13 AM Topic: Chevrolet Silverado 2015, alarm/remote start wiring Posted By: installesl Subject: Chevrolet Silverado 2015, alarm/remote start wiring Date Posted: December 30, 2015 at 3:16 PM I'm looking for the security and remote start wiring. Also, I would like to know if the 2014 version of the vehicle has the same wiring as well.
Thank You Replies: Posted By: 120mar12 Date Posted: October 12, 2016 at 7:50 AM Do you have wiring for Silverado 1500 2015?
Posted By: lurch228 Date Posted: October 12, 2016 at 8:45 AM Directwire
2015 Chevrolet Silverado 1500 - North America Remote Start, Security, Keyless Entry, Accessories Item / Wire Color / Polarity / Wire Location 12 Volts RED / purple (20A) + BCM under driver dash, blue 27 pin plug, pin 4 Second 12 Volts RED / blue (20A) + BCM under driver dash, white 26 pin plug, pin 2 Starter yellow (for starter kill only) + starter or underhood fuse box, green 58 pin plug, pin E2 Second Starter wht/pur (r-code); wht/blk (5V ref) (Tech Doc 1605) +9600 ohms ignition sw or BCM under driver dash, grn 25 pin plug, pins 15, 22 Ignition PURPLE / black + ignition sw or BCM under driver dash, green 25 pin plug, pin 6 Accessory purple / YELLOW + ignition sw or BCM under driver dash, green 25 pin plug, pin 5 Second Accessory (same as second starter) +6300 ohms Keysense (same as second starter) Data Bus GREEN/ purple (immobilizer LIN bus) data immobilizer mod or BCM under driver dash, grn 25 pin plug, pin 2 CAN Bus High blue (high speed GMLAN) data data link conn or BCM under driver dash, white 26 pin plug, pin 25 CAN Bus Low white (high speed GMLAN) data data link conn or BCM under driver dash, white 26 pin plug, pin 24 CAN Bus SW green (low speed GMLAN) data data link conn or BCM under driver dash, gray 26 pin plug, pin 23 Power Lock BROWN / yellow - BCM under driver dash, blue 27 pin plug, pin 19 Power Unlock BROWN / white - BCM under driver dash, blue 27 pin plug, pin 15 Lock Motor BROWN / yellow 5 wire BCM under driver dash, pink 27 pin plug, pin 4 Driver Unlock Motor blue/white 5 wire BCM under driver dash, pink 27 pin plug, pin 1 Passenger Unlock Motor gray/green 5 wire BCM under driver dash, pink 27 pin plug, pin 2 Factory Alarm Arm (factory remote only) Factory Alarm Disarm (see disarm no unlock) Disarm No Unlock (transponder and ignition) Parking Lights (+) PURPLE / gray (L); gray/brown (R) + underhood fuse box, brown 58 pin plug, pins G1, F1 Parking Lights (-) GREEN/ gray - BCM under driver dash, white 26 pin plug, pin 22 Hazards GREEN / WHITE - BCM under driver dash, blue 27 pin plug, pin 26 Turn Signal (Left) blue/white (F); yellow/blue (R) + BCM under driver dash, brown 26 pin plug, pins 2, 1 Turn Signal (Right) GREEN/ purple (F); BROWN / green (R) + BCM under driver dash, black 26 pin plug, pins 3, 4 Headlight WHITE/ purple - BCM under driver dash, white 26 pin plug, pin 16 AutoLights GREEN/ brown (ground to turn off) - BCM under driver dash, white 26 pin plug, pin 11 Reverse Light blue/brown + BCM under driver dash, brown 26 pin plug, pin 26 Left Front Door Trigger gray (without power wndw); gray (with power wndw) - BCM, gray 26 pin plug, pin 25; LF wnd motor, black 7 pin plug, pin 6 Right Front Door Trigger gray (without power wndw); gray (with power wndw) - BCM, gy 26P plg, pin14; RF wnd sw, bk 8P plg, pin8 Left Rear Door Trigger gray/white - left rear window switch, black 8 pin plug, pin 2 Right Rear Door Trigger gray/white - right rear window switch, black 8 pin plug, pin 2 Dome Light gray + BCM under driver dash, gray 26 pin plug, pin 1 Hood Pin BROWN / green - BCM under driver dash, black 26 pin plug, pin 24 Tachometer brn, grn, wht/gn or ye/gy (fuel inject 1, 3, 5, 7) ac rear top center of engine, black 12 pin plug, pin 5, 7, 8, or 9 Wait to Start GREEN/ brown - instrument cluster, black 32 pin plug, pin 32 Clutch Pedal yellow (see Tech Doc 10001) resistors clutch switch, black 3 pin plug, pin B Fuel Pump PURPLE / green (light duty); gray (heavy duty) + underhood fuse box, white 58 pin plug, pin J5; D2 Rear Defroster BROWN / purple + latched passenger kick, gray 10 pin plug, pin 4 Mirror Defroster (same as rear defroster) Left Front Heated Seat (LIN bus) Right Front Heated Seat (LIN bus) Speed Sense GREEN/ gray ac dash junction block left of brake pedal, gray 50 pin plug, pin 47 Brake Wire PURPLE / white + BCM under driver dash, black 26 pin plug, pin 11 Parking Brake blue/purple - BCM under driver dash, white 26 pin plug, pin 10 Horn Trigger BROWN / white - BCM under driver dash, brown 26 pin plug, pin 19 Wipers gray + BCM under driver dash, black 26 pin plug, pin 16 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) GREEN/ gray - yellow/blue A RF window switch, black 8 pin plug, pins 2 - 3 Left Rear Window (Up/Down) blue/purple - yellow/blue A LR window switch, black 8 pin plug, pins 6 - 7 Right Rear Window (Up/Down) blue/gray - GREEN/ black A RR window switch, black 8 pin plug, pins 6 - 7 Sun Roof (Open/Close) GREEN / WHITE and BROWN / blue (open) (w/ign on only) both - sunroof switch, black 8 pin plug, pins 6, 1 Sun Roof (Limit/Close) blue/white and BROWN / blue (close) (w/ign on only) both - sunroof switch, black 8 pin plug, pins 4, 1 Memory Seat 1 white - 630 ohms driver kick, door harness, gray 41 pin plug, pin 8 Memory Seat 2 (same as memory seat 1) -2000 ohms Audio Item Wire Color Polarity Wire Location Radio 12V RED / purple + radio, green 16 pin plug, pin 8 Radio Ground black - radio, green 16 pin plug, pin 16 Radio Ignition (low speed GMLAN) Radio Illumination (low speed GMLAN) Factory Amp Turn-on (MOST serial data) Left Front Speaker (+/-) blue - BROWN / blue +,- radio, green 16 pin plug, pins 1 - 9 Right Front Speaker (+/-) yellow - yellow/black +,- radio, green 16 pin plug, pins 2 - 10 Left Rear Speaker (+/-) green - GREEN/ black +,- radio, green 16 pin plug, pins 3 - 11 Right Rear Speaker (+/-) white - blue/black +,- radio, green 16 pin plug, pins 4 - 12 Subwoofer (+/-) blue/gray - gray/black +,- amplifier behind rear seats, black 8 pin plug, pins 1 - 5 Aux. Audio Input Left (+/-) gray - purple +,- radio, gray 20 pin plug, pins 9 - 8 Aux. Audio Input Right (+/-) green - purple +,- radio, gray 20 pin plug, pins 10 - 8 RSE Video (+/-) (digital video); gry/yel - wht/blu (rearview cam) +,- radio, gray 20 pin plug, pins 5 - 4 RSE Audio Left (+/-) GREEN / WHITE - blue/purple (headphone audio) +,- media disc player, gray 20 pin plug, pins 1 - 3 RSE Audio Right (+/-) BROWN / gray - blue/purple (headphone audio) +,- media disc player, gray 20 pin plug, pins 2 - 3 Satellite Radio 12 Volts (built into radio) What Fits Item Size Depth Location Headunit irregular center of dash Left Front Speaker left front door Left Front Tweeter left front dash Right Front Speaker right front door Right Front Tweeter right front dash Left Rear Speaker left rear side panel or door Right Rear Speaker right rear side panel or door Subwoofer front of center console Satellite Radio Tuner (built into radio) Notes: Accessory: DO NOT use the accessory wire listed as a switched power SOURCE for any aftermarket accessories. Tachometer: On 6.0L models, the fuel injectors 1, 3, 5, or 7 are GREEN/ YELLOW, BROWN / purple, BROWN / green, BROWN / purple at any fuel injector, gray 2 pin plug, pin B. On 6.6L diesel models, use yellow/purple or blue/white at the camshaft position sensor, gray 3 pin plug, pin 1. Fuel Pump: On dual fuel pump models, fuel pump 2 is gray (+) at the underhood fuse box, white 58 pin plug, pin L7. On CNG models, it is gray (+) at the underhood fuse box, gray 58 pin plug, pin B5. Left Front Speaker (+/-): On models with amplifier, the speaker wires are blue - BROWN / blue at the amplifier behind rear seats, black 8 pin plug, pins 3 - 7. The tweeter wires are yellow/blue - yellow/gray at the amplifier, black 16 pin plug, pins 5 - 13 (premium audio). Right Front Speaker (+/-): On models with amplifier, the speaker wires are yellow - yellow/black at the amplifier behind rear seats, black 8 pin plug, pins 2 - 6. The tweeter wires are BROWN / green - PURPLE / brown at the amplifier, black 16 pin plug, pins 4 - 12 (premium audio). Left Rear Speaker (+/-): On models with amplifier, the speaker wires are green - GREEN/ black at the amplifier behind rear seats, black 16 pin plug, pins 7 - 15. Right Rear Speaker (+/-): On models with amplifier, the speaker wires are white - blue/black at the amplifier behind rear seats, black 16 pin plug, pins 6 - 14. Posted By: 120mar12 Date Posted: November 06, 2016 at 7:02 PM I am confused which wire is the positive and negative.
2015 Silverado non touch screen radio. Left Front Speaker (+/-) blue - BROWN / blue +,- radio, green 16 pin plug, pins 1 - 9 Right Front Speaker (+/-) yellow - yellow/black +,- radio, green 16 pin plug, pins 2 - 10 What I understand in here is Blue negative and Brown Blue Positive but something do not make sense. Other pages: Left front (+) dark blue (-) brown with dark blue stripe Right front (+) yellow (-) yellow with black stripe --------- 2014 Silverado without Bose: ITEM WIRE COLOR LOCATION Left Front Speaker (+/-) // blue - BROWN / blue // radio, green 16 pin plug, pins 1 - 9 Right Front Speaker (+/-) // yellow - yellow/black // radio, green 16 pin plug, pins 2 - 10 ------ Right Front + : Yellow/Black Right Front - : Yellow Left Front + : BROWN / Blue Left Front - : Blue ----- Left Front Speaker Wire (+) Positive: Blue Left Front Speaker Wire (-) Negative: BROWN / Blue Right Front Speaker Wire (+) Positive: Yellow Right Front Speaker Wire (-) Negative: Yellow/Black Confused Posted By: geepherder Date Posted: November 06, 2016 at 9:58 PM If in doubt, you can "pop" the speakers with a small AA/AAA battery to test polarity.
https://www.the12volt.com/installbay/forum_posts.asp?tid=74637 If you scroll down to the paragraph that starts with "Sixth", it'll tell you how to do this. ------------- My ex once told me I have a perfect face for radio. |
