Print Page | Close Window |
2015 Toyota Camry Remote Start/Security WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141405 Printed Date: September 20, 2024 at 8:01 PM Topic: 2015 Toyota Camry Remote Start/Security Wiring Posted By: thecandyman Subject: 2015 Toyota Camry Remote Start/Security Wiring Date Posted: June 17, 2016 at 1:36 PM Hey All at 12volt! I just joined and I am starting my research to install a Viper 5706v with an idatalink AL(DL) TL9.
I was looking in the vehicle wiring section for information on the 2015 Toyota Camry SE standard H key, but didn't see anything for the new model year since it was redesigned (most current model listed is the 2014). I tried searching to see if anyone else has asked for this information, but I didn't seem to find anything relevant. Could someone please post if they have this information available? Many thanks and looking forward to gaining knowledge here at 12volt! Replies: Posted By: tonanzith Date Posted: June 17, 2016 at 11:54 PM here you go:
2015 (through 2016) Toyota Camry DirectWire Vehicle Information All Products Item Wire Color Polarity Wire Location 12 Volts green (30A) + ignition switch, white 8 pin plug, pin 5 Second 12 Volts yellow (7.5A) + ignition switch, white 8 pin plug, pin 4 Starter blue + ignition switch, white 8 pin plug, pin 7 Second Starter lt. green + ignition switch, white 8 pin plug, pin 3 Ignition black + ignition switch, white 8 pin plug, pin 6 Second Ignition pink + ignition switch, white 8 pin plug, pin 1 Third Ignition N/A Accessory white + ignition switch, white 8 pin plug, pin 2 Second Accessory N/A Third Accessory N/A Keysense green - Body ECU on dash fuse box, white 30 pin plug, pin 17 Data Bus red (IMO); green (IMI) data driver kick, blue 26 pin plug, pins 4, 5 The immobilizer light is blue (+) at the A/C control assembly, black 16 pin plug, pin 1. Can Bus High blue data data link connector, white 16 pin plug, pin 6 Can Bus Low white data data link connector, white 16 pin plug, pin 14 Can Bus Sw blue (RDA keyless data); gray (SIL immobiliz comm) data Body ECU, wht 30 pin plug, pin 16; data link conn, wh 16 pin plg, pin 7 Power Lock blue (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9 Power Unlock green (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10 Lock Motor red 5 wire driver kick, white 18 pin plug, pin 18 Driver Unlock Motor gray 5 wire driver kick, white 18 pin plug, pin 12 Passenger Unlock Motor green 5 wire dash fuse box, white 36 pin plug (3C), pin 11 Parking Lights (-) black - Body ECU on dash fuse box, white 30 pin plug, pin 30 Parking Lights (+) pink + dash fuse box, white 36 pin plug (3C), pin 5 Hazards white - A/C control assembly, black 16 pin plug, pin 4 Turn Signal (Left) yellow + dash fuse box, white 36 pin plug (3C), pin 22 Turn Signal (Right) green + dash fuse box, white 36 pin plug (3C), pin 19 Headlight pink - Body ECU on dash fuse box, white 30 pin plug, pin 29 AutoLights green (interrupt to turn off autolights) - Body ECU on dash fuse box, wht 30 pin plug, pin 28 Reverse Light pink + dash fuse box, white 36 pin plug (3C), pin 7 Left Front Door Trigger blue - dash fuse box, white 36 pin plug (3C), pin 15 Right Front Door Trigger lt. blue - Body ECU on dash fuse box, wht 30 pin plug, pin 19 Left Rear Door Trigger pink - Body ECU on dash fuse box, wht 30 pin plug, pin 1 Right Rear Door Trigger black - Body ECU on dash fuse box, wht 30 pin plug, pin 6 Dome Supervision lt. green - dash fuse box, rear, white 40 pin plug (3B), pin 35 Trunk/Hatch Pin white - dash fuse box, white 36 pin plug (3C), pin 9 Rear Glass Pin N/A Hood Pin purple - dash fuse box, white 40 pin plug (3D), pin 25 Trunk/Hatch Release (use trunk release motor) Trunk Release Motor red 5 wire dash fuse box, white 36 pin plug (3C), pin 10 Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm red (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11 Factory Alarm Disarm gray (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24 Disarm No Unlock (use keysense) Trunk Alarm Shunt N/A Tachometer green ac data link connector, white 16 pin plug, pin 9 Wait to Start N/A Neutral Safety N/A Clutch Pedal N/A Fuel Pump black + driver kick, harness to rear Rear Defroster green - passenger kick, gray 18 pin plug, pin 18 Mirror Defroster (same as rear defroster) Left Front Heated Seat black + resistor left seat heater switch, black 10 pin plug, pin 7 Right Front Heated Seat purple + resistor right seat heater switch, black 8 pin plug, pin 5 Speed Sense blue or purple ac driver kick, blue 26 pin plug, pin 21 or radio, white 28 pin plug, pin 17 Brake Wire red + brake switch, white 4 pin plug, pin 1 Parking Brake yellow - dash fuse box, white 40 pin plug (3D), pin 20 Horn Trigger lt. blue - dash fuse box, white 40 pin plug (3D), pin 15 Wipers blue (LO); green (HI); pink (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) (motor is part of module) Left Rear Window (Up/Down) blue - black A driver kick, white 26 pin plug, pins 1 - 15 Right Rear Window (Up/Down) yellow - lt. green A driver kick, white 18 pin plug, pins 7 - 2 Sun Roof (Open/Close) black - green (function with ignition on only) - roof console assembly, black 20 pin plug, pins 3 - 2 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V blue / YELLOW + radio, white 10 pin plug, pin 4 Radio Ground brown - radio, white 10 pin plug, pin 7 Radio Ignition gray + radio, white 10 pin plug, pin 3 Radio Illumination green (parking lights); lt. blue (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5 Factory Amp Turn-on N/A Power Antenna N/A Left Front Speaker (+/-) pink - purple +,- radio, white 10 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are pink - purple (woofer); pink - purple (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 11 - 26; 14 - 29. Right Front Speaker (+/-) lt. green - blue +,- radio, white 10 pin plug, pins 1 - 5 On models with amplifier, the speaker wires are lt. green - blue or yellow - pink (woofer); lt. green - blue (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 15 - 30; 12 - 27. Left Rear Speaker (+/-) black - yellow +,- radio, white 6 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are black - yellow at the amplifier under driver seat, white 30 pin plug, pins 9 - 24. Right Rear Speaker (+/-) red - white +,- radio, white 6 pin plug, pins 1 - 3 On models with amplifier, the speaker wires are red - white at the amplifier under driver seat, white 30 pin plug, pins 10 - 25. Center Channel (+/-) black - green +,- amplifier under driver seat, white 30 pin plug, pins 13 - 28 Subwoofer (+/-) pink - yellow +,- amplifier under driver seat, white 30 pin plug, pins 8 - 23 Aux. Audio Input Left (+/-) red - white +,- radio, white 28 pin plug, pins 28 - 27 Aux. Audio Input Right (+/-) black - white +,- radio, white 28 pin plug, pins 26 - 27 RSE Video (+/-) white - red (rear view camera video) +,- radio, white 24 pin plug, pins 12 - 24 RSE Audio Left (+/-) N/A RSE Audio Right (+/-) N/A Satellite Radio 12 Volts red + Satellite Radio below radio, wht 8 pin plug, pin 4 Satellite Radio Ground black - Satellite Radio below radio, wht 8 pin plug, pin 8 Satellite Radio Ignition yellow + Satellite Radio below radio, wht 8 pin plug, pin 3 Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) (DIN cable) Satellite Audio Right (+/-) (DIN cable) Item Size Depth Location Headunit irregular center of dash Left Front Speaker 7.0 or 7 x 10 left front door Left Front Tweeter 2.6 or 3.1 left front dash Right Front Speaker 7.0 or 7 x 10 right front door Right Front Tweeter 2.6 or 3.1 right front dash Left Rear Speaker 7.0 or 3.1 left rear shelf Left Rear Tweeter N/A Right Rear Speaker 7.0 or 3.1 right rear shelf Right Rear Tweeter N/A Center Channel 3.1 top center of dash Subwoofer 7 x 10 left rear shelf Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner below radio ------------- Gary Sather Posted By: maryland33 Date Posted: December 13, 2016 at 4:05 PM I'm doing a 2016 Camry now (non smart key). Only difference thus far is that the white accessory wire does work heat,a/c. Radio works lol.
Posted By: maryland33 Date Posted: December 13, 2016 at 5:01 PM Edit... Heat or ac does NOT work with the white accessory wire. Sorry,still working it out
Posted By: maryland33 Date Posted: December 14, 2016 at 11:30 AM Pink wire (2nd ignition) @ ignition switch harness did the trick. That's what I get for being outta the game for so long lol. Hope this helps someone out there. Thanks Tonanzith!!!
Posted By: miketheman Date Posted: December 22, 2016 at 10:08 PM tonanzith wrote:Rear Defroster green - passenger kick, gray 18 pin plug, pin 18 Mirror Defroster (same as rear defroster) here you go: 2015 Toyota Camry DirectWire Vehicle Information All Products Item Wire Color Polarity Wire Location 12 Volts green (30A) + ignition switch, white 8 pin plug, pin 5 Second 12 Volts yellow (7.5A) + ignition switch, white 8 pin plug, pin 4 Starter blue + ignition switch, white 8 pin plug, pin 7 Second Starter lt. green + ignition switch, white 8 pin plug, pin 3 Ignition black + ignition switch, white 8 pin plug, pin 6 Second Ignition pink + ignition switch, white 8 pin plug, pin 1 Third Ignition N/A Accessory white + ignition switch, white 8 pin plug, pin 2 Second Accessory N/A Third Accessory N/A Keysense green - Body ECU on dash fuse box, white 30 pin plug, pin 17 Data Bus red (IMO); green (IMI) data driver kick, blue 26 pin plug, pins 4, 5 The immobilizer light is blue (+) at the A/C control assembly, black 16 pin plug, pin 1. Can Bus High blue data data link connector, white 16 pin plug, pin 6 Can Bus Low white data data link connector, white 16 pin plug, pin 14 Can Bus Sw blue (RDA keyless data); gray (SIL immobiliz comm) data Body ECU, wht 30 pin plug, pin 16; data link conn, wh 16 pin plg, pin 7 Power Lock blue (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9 Power Unlock green (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10 Lock Motor red 5 wire driver kick, white 18 pin plug, pin 18 Driver Unlock Motor gray 5 wire driver kick, white 18 pin plug, pin 12 Passenger Unlock Motor green 5 wire dash fuse box, white 36 pin plug (3C), pin 11 Parking Lights (-) black - Body ECU on dash fuse box, white 30 pin plug, pin 30 Parking Lights (+) pink + dash fuse box, white 36 pin plug (3C), pin 5 Hazards white - A/C control assembly, black 16 pin plug, pin 4 Turn Signal (Left) yellow + dash fuse box, white 36 pin plug (3C), pin 22 Turn Signal (Right) green + dash fuse box, white 36 pin plug (3C), pin 19 Headlight pink - Body ECU on dash fuse box, white 30 pin plug, pin 29 AutoLights green (interrupt to turn off autolights) - Body ECU on dash fuse box, wht 30 pin plug, pin 28 Reverse Light pink + dash fuse box, white 36 pin plug (3C), pin 7 Left Front Door Trigger blue - dash fuse box, white 36 pin plug (3C), pin 15 Right Front Door Trigger lt. blue - Body ECU on dash fuse box, wht 30 pin plug, pin 19 Left Rear Door Trigger pink - Body ECU on dash fuse box, wht 30 pin plug, pin 1 Right Rear Door Trigger black - Body ECU on dash fuse box, wht 30 pin plug, pin 6 Dome Supervision lt. green - dash fuse box, rear, white 40 pin plug (3B), pin 35 Trunk/Hatch Pin white - dash fuse box, white 36 pin plug (3C), pin 9 Rear Glass Pin N/A Hood Pin purple - dash fuse box, white 40 pin plug (3D), pin 25 Trunk/Hatch Release (use trunk release motor) Trunk Release Motor red 5 wire dash fuse box, white 36 pin plug (3C), pin 10 Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm red (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11 Factory Alarm Disarm gray (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24 Disarm No Unlock (use keysense) Trunk Alarm Shunt N/A Tachometer green ac data link connector, white 16 pin plug, pin 9 Wait to Start N/A Neutral Safety N/A Clutch Pedal N/A Fuel Pump black + driver kick, harness to rear Rear Defroster green - passenger kick, gray 18 pin plug, pin 18 Mirror Defroster (same as rear defroster) Left Front Heated Seat black + resistor left seat heater switch, black 10 pin plug, pin 7 Right Front Heated Seat purple + resistor right seat heater switch, black 8 pin plug, pin 5 Speed Sense blue or purple ac driver kick, blue 26 pin plug, pin 21 or radio, white 28 pin plug, pin 17 Brake Wire red + brake switch, white 4 pin plug, pin 1 Parking Brake yellow - dash fuse box, white 40 pin plug (3D), pin 20 Horn Trigger lt. blue - dash fuse box, white 40 pin plug (3D), pin 15 Wipers blue (LO); green (HI); pink (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) (motor is part of module) Left Rear Window (Up/Down) blue - black A driver kick, white 26 pin plug, pins 1 - 15 Right Rear Window (Up/Down) yellow - lt. green A driver kick, white 18 pin plug, pins 7 - 2 Sun Roof (Open/Close) black - green (function with ignition on only) - roof console assembly, black 20 pin plug, pins 3 - 2 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V blue / YELLOW + radio, white 10 pin plug, pin 4 Radio Ground brown - radio, white 10 pin plug, pin 7 Radio Ignition gray + radio, white 10 pin plug, pin 3 Radio Illumination green (parking lights); lt. blue (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5 Factory Amp Turn-on N/A Power Antenna N/A Left Front Speaker (+/-) pink - purple +,- radio, white 10 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are pink - purple (woofer); pink - purple (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 11 - 26; 14 - 29. Right Front Speaker (+/-) lt. green - blue +,- radio, white 10 pin plug, pins 1 - 5 On models with amplifier, the speaker wires are lt. green - blue or yellow - pink (woofer); lt. green - blue (tweeter) at the amplifier under driver seat, white 30 pin plug, pins 15 - 30; 12 - 27. Left Rear Speaker (+/-) black - yellow +,- radio, white 6 pin plug, pins 2 - 6 On models with amplifier, the speaker wires are black - yellow at the amplifier under driver seat, white 30 pin plug, pins 9 - 24. Right Rear Speaker (+/-) red - white +,- radio, white 6 pin plug, pins 1 - 3 On models with amplifier, the speaker wires are red - white at the amplifier under driver seat, white 30 pin plug, pins 10 - 25. Center Channel (+/-) black - green +,- amplifier under driver seat, white 30 pin plug, pins 13 - 28 Subwoofer (+/-) pink - yellow +,- amplifier under driver seat, white 30 pin plug, pins 8 - 23 Aux. Audio Input Left (+/-) red - white +,- radio, white 28 pin plug, pins 28 - 27 Aux. Audio Input Right (+/-) black - white +,- radio, white 28 pin plug, pins 26 - 27 RSE Video (+/-) white - red (rear view camera video) +,- radio, white 24 pin plug, pins 12 - 24 RSE Audio Left (+/-) N/A RSE Audio Right (+/-) N/A Satellite Radio 12 Volts red + Satellite Radio below radio, wht 8 pin plug, pin 4 Satellite Radio Ground black - Satellite Radio below radio, wht 8 pin plug, pin 8 Satellite Radio Ignition yellow + Satellite Radio below radio, wht 8 pin plug, pin 3 Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) (DIN cable) Satellite Audio Right (+/-) (DIN cable) Item Size Depth Location Headunit irregular center of dash Left Front Speaker 7.0 or 7 x 10 left front door Left Front Tweeter 2.6 or 3.1 left front dash Right Front Speaker 7.0 or 7 x 10 right front door Right Front Tweeter 2.6 or 3.1 right front dash Left Rear Speaker 7.0 or 3.1 left rear shelf Left Rear Tweeter N/A Right Rear Speaker 7.0 or 3.1 right rear shelf Right Rear Tweeter N/A Center Channel 3.1 top center of dash Subwoofer 7 x 10 left rear shelf Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner below radio Posted By: thecandyman Date Posted: December 23, 2016 at 3:06 AM My 2015 Camry was a negative latched rear defroster (no pulse, it was 0v off and went to 12v when on and stayed there). I used a relay, the vipers 200mA output basically grounded the green defroster wire through the relay because I wasn't sure how much current it uses, I figured just to be safe I would use a relay.
Posted By: miketheman Date Posted: December 23, 2016 at 12:01 PM can i use the GWR wire to do this? will it dammage the rear defroster if it goes on every time i remote start it?
Posted By: miketheman Date Posted: December 25, 2016 at 6:18 PM thecandyman wrote: what you described is a positive latched wire. |
