radio amp turn on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141423
Printed Date: May 04, 2024 at 5:23 PM
Topic: radio amp turn on
Posted By: bball50usa
Subject: radio amp turn on
Date Posted: June 22, 2016 at 11:16 AM
wired in new radio with aftermarket connector, have no audio.
install factory unit, ok.
no amp turn on from new head unit, nothing here for amp turn on wire.
please help.
98 Cadillac Deville, non bose
------------- bball50usa
Posted By: geepherder
Date Posted: June 22, 2016 at 12:50 PM
Grab a basic test light. With the aftermarket deck plugged in, but not installed in the dash, turn the key to the on position. Now, connect the alligator clip of the test light to 12 volts, and back probe any remaining wires (not currently used) in the factory plug one at a time and see if you get sound.
------------- My ex once told me I have a perfect face for radio.
Posted By: icearrow6
Date Posted: June 22, 2016 at 1:06 PM
What harness part did you use?
Posted By: sparkie
Date Posted: June 22, 2016 at 3:51 PM
The factory amp is turned on and controlled through data. You need to use a radio replacement module that will turn on the amp.
------------- sparky
Date Posted: June 22, 2016 at 3:58 PM
ah, just as I thought. do not have the availability to diagrams and info I had before I retired.
thank you.
