2012 Chevrolet Cruze Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141566
Printed Date: May 07, 2024 at 6:47 AM
Topic: 2012 Chevrolet Cruze Alarm/Remote Start Wiring
Posted By: lurch228
Subject: 2012 Chevrolet Cruze Alarm/Remote Start Wiring
Date Posted: July 30, 2016 at 11:01 PM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / CRUZE / 2012 / Remote Start
[PRINT THIS PAGE]
12volts RED / gray (30A) + BCM in center console RF side, blue 27 pin plug, pin 4
Starter yellow or BLACK/ red (for starter kill only) + starter motor or underhood fuse box, black 50 pin plug (X3), pin 5
Second Starter wht/pur (r-code); wht/blk (5V ref) (Tech Doc 1605) +9.6K ohms ign sw or BCM in ctr console RF side, grn 25 pin plug, pins 15, 22
Ignition PURPLE / black + ignition sw or BCM in ctr console RF side, green 25 pin plug, pin 6
Second Ignition N/A
Third Ignition N/A
Accessory purple / YELLOW + ignition sw or BCM in ctr console RF side, green 25 pin plug, pin 5
Second Accessory (same as second starter) +6.3K ohms
Keysense (same as second starter)
Power Lock BROWN / yellow - door lock sw or BCM in ctr console RF side, blue 27 pin plug, pin 19
Power Unlock BROWN / white - door lock sw or BCM in ctr console RF side, blue 27 pin plug, pin 15
Lock Motor BROWN / yellow 5 wire BCM in center console RF side, pink 27 pin plug, pin 4
Unlock Motor gray 5 wire BCM in center console RF side, pink 27 pin plug, pin 1
Parking Lights+ PURPLE / gray (L); gray/brown (R) + BCM in center console RF side, black 26 pin plug, pins 6, 5
Parking Lights- GREEN/ gray - headlight sw or BCM in ctr console RF side, white 26 pin plug, pin 22
Hazards GREEN / WHITE - hazard sw or BCM in ctr console RF side, blue 27 pin plug, pin 26
Turn Signal(L) blue/white (F); blue/white (R) + BCM in center console RF side, brown 26 pin plug, pins 2, 1
Turn Signal(R) GREEN/ purple (F); blue/purple (R) + BCM in center console RF side, black 26 pin plug, pins 3, 4
Reverse Light GREEN / WHITE + BCM in center console RF side, gray 26 pin plug, pin 3
Door Trigger gray (xpress down wndw); gray(xpress up/down wndw) - driv wndw sw, blk 8 pin plug, pin 6; driv wndw mtr, blk 7 pin plg, pin 6
Dome Supervision gray + BCM in center console RF side, gray 26 pin plug, pin 1
Trunk/Hatch Pin PURPLE / gray - BCM in center console RF side, pink 27 pin plug, pin 5
Hood Pin BROWN / green - BCM, pink 27 pin plug, pin 6 or black 26 pin plug, pin 24
Trunk/Hatch Release yellow/blue (rear handle switch) - BCM in center console RF side, pink 27 pin plug, pin 15
Power Sliding Door N/A
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (Passkey and ignition)
Tachometer BROWN / pur, yellow/wht, BROWN / pur, or BROWN / yel ac any fuel injector, black 2 pin plug, pin 2
Wait to start N/A
Brake Wire PURPLE / white + BCM in center console RF side, black 26 pin plug, pin 11
Parking Brake blue/purple - park brk sw or BCM in ctr console RF side, gray 26 pin plug, pin 15
Horn Trigger GREEN / WHITE to BROWN / white - horn sw or BCM in ctr console RF side, brown 26 pin plug, pin 19
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Modules: Not Available
warning
