2011 Chevrolet Colorado, Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141722
Printed Date: May 04, 2024 at 3:02 AM
Topic: 2011 Chevrolet Colorado, Alarm/Remote Start Wiring
Posted By: lurch228
Subject: 2011 Chevrolet Colorado, Alarm/Remote Start Wiring
Date Posted: September 15, 2016 at 12:15 AM
Directwire
2011 Chevrolet Colorado - North America
Remote Start, Security, Keyless Entry, Accessories
Item Wire Color Polarity Wire Location
12 Volts orange (15A), orange (15A) + BCM in passenger kick, black 56 pin plug, pins B5 and B8
Second 12 Volts red + battery or underhood fuse box
Starter purple (for starter kill only) + starter or underhood fuse box, black 68 pin plug, pin E2
Second Starter wht/blu (r-code), wht/yel (5V ref) (Tech Doc 1603) mux ignition switch, green 6 pin plug, pins 4 and 5
Ignition WHITE/ green + ignition switch, green 6 pin plug, pin 3
Accessory WHITE/ red + ignition switch, green 6 pin plug, pin 1
Second Accessory same as second starter
Keysense same as second starter
CAN Bus High tan/white (high speed GMLAN) data data link connector, black 16 pin plug, pin 6
CAN Bus Low tan (high speed GMLAN) data data link connector, black 16 pin plug, pin 14
CAN Bus SW purple (J1850 Class 2 Serial Data) data data link connector, black 16 pin plug, pin 2
Power Lock lt. blue - driver kick or BCM in passenger kick, black 56 pin plug, pin A11
Power Unlock white double - driver kick or BCM in passenger kick, black 56 pin plug, pin A12
Lock Motor gray 5 wire driver kick, door harness
Driver Unlock Motor tan 5 wire driver window switch, white 8 pin plug, pin 2
Passenger Unlock Motor tan 5 wire driver kick, door harness
Factory Alarm Arm factory remote only
Factory Alarm Disarm see disarm no unlock
Disarm No Unlock Passlock and ignition
Parking Lights (+) brown + BCM in passenger kick, black 56 pin plug, pin A48
Parking Lights (-) BROWN / white - headlight sw or BCM in passenger kick, gray 56 pin plug, pin A7
Hazards white - hazard switch or BCM in passenger kick, gray 56 pin plug, pin A48
Turn Signal (Left) lt. blue (F), yellow (R) + BCM in passenger kick, black 56 pin plug, pins A3 and B1
Turn Signal (Right) dk. blue (F), dk. green (R) + BCM in passenger kick, black 56 pin plug, pins A19 and B2
Headlight white - headlight sw or BCM in passenger kick, gray 56 pin plug, pin A2
AutoLights PURPLE / white (ground to turn off autolights) - switch or BCM in pass kick, gry 56 pin plg, pin A9
Reverse Light pink + BCM in passenger kick, black 56 pin plug, pin A1
Left Front Door Trigger gray/black - BCM in passenger kick, black 56 pin plug, pin A32
Right Front Door Trigger lt. GREEN/ black - BCM in passenger kick, black 56 pin plug, pin A38
Left Rear Door Trigger lt. blue/black - BCM in passenger kick, black 56 pin plug, pin A44
Right Rear Door Trigger BLACK/ white - BCM in passenger kick, black 56 pin plug, pin A39
Dome Light white - BCM in passenger kick, black 56 pin plug, pin A46
Tachometer black, lt grn/blk, pnk/blk, lt blu/blk, or blk/wht ac any fuel injector, gray 2 pin plug, pin B
Clutch Pedal dk. blue (see Tech Doc 10001) - 180 ohms clutch switch, black 3 pin plug, pin B
Fuel Pump dk. GREEN / WHITE + ECM underhood RR corner, blue 56 pin plug, pin 13
Left Front Heated Seat pink (low 2.5K ohms, high 4.9K ohms) + resistor driver heated seat switch, black 8 pin plug, pin B
Right Front Heated Seat pink (low 3K ohms, high 2.3K ohms) + resistor passenger heated seat switch, black 8 pin plug, pin B
Speed Sense PURPLE / white ac ECM, gry 73 pin plg, pin 66 (M/T); TCM, blk 49 pin plg, pin 41 (A/T)
Brake Wire lt. blue + driver A pillar or underhood fuse box, white 32 pin plug, pin B4
Parking Brake lt. blue - parking brake sw or BCM in pass kick, black 56 pin plug, pin A31
Horn Trigger green to black - horn switch or BCM in passenger kick, black 56 pin plug, pin A40
Wipers dk. green + BCM in passenger kick, black 56 pin plug, pin A8
Left Front Window (Up/Down) dk. blue - brown A driver window switch, white 8 pin plug, pins 7 and 8
Right Front Window (Up/Down) dk. blue - brown A passenger window switch, white 12 pin plug, pins 12 and 10
Left Rear Window (Up/Down) dk. blue - brown A left rear window switch, white 8 pin plug, pins 8 and 7
Right Rear Window (Up/Down) dk. blue - brown A right rear window switch, white 8 pin plug, pins 8 and 7
Sun Roof (Open/Close) dk. green - black A sunroof switch
