Print Page | Close Window |
2016 Dodge Challenger HK WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142637 Printed Date: April 29, 2024 at 7:12 AM Topic: 2016 Dodge Challenger HK Wiring Posted By: spdy1969 Subject: 2016 Dodge Challenger HK Wiring Date Posted: February 20, 2017 at 4:43 AM Hello, looking for a wiring diagram for my 2016 Dodge Challenger ScatPack with the Harman Kardon premium sound system.
Will be utilizing either the JL Audio Fix86 I already have or the new PAC AP4-CH41 interface. Thanks. Replies: Posted By: tonanzith Date Posted: May 21, 2017 at 10:29 PM Smart Key) - North America DirectWire Vehicle Information
All Products Item Wire Color Polarity Wire Location 12 Volts red/yellow (40A) + BCM above passenger kick, black 4 pin plug (B), pin 3 Starter lt. blue/tan (for starter kill only) + BCM above passenger kick, black 24 pin plug (A), pin 19 Ignition pink/white (for ignition sense only) + BCM above passenger kick, black 48 pin plug (E), pin 27 or 31 Accessory brown/orange (for accessory sense only) + BCM above passenger kick, black 48 pin plug (E), pin 36 PTS 1 purple/lt. blue + Keyless Ignition Node (Start/Stop Button), black 6 pin plug, pin 4 CAN Bus High gray/white (CAN C) data data link connector, black 16 pin plug, pin 6 CAN Bus Low yellow (CAN C) data data link connector, black 16 pin plug, pin 14 CAN Bus High 2 gray (CAN IHS) data data link connector, black 16 pin plug, pin 3 CAN Bus Low 2 white (CAN IHS) data data link connector, black 16 pin plug, pin 11 IMMO Data white/lt. green (Security K Line) data Keyless Ignition Node (Start/Stop Button), black 6 pin plug, pin 5 Power Lock purple/lt. green (passenger door switch) - 330 ohms passenger window/door lock switch, green 10 pin plug, pin 8 Power Unlock (same as power lock) - 100 ohms Lock Motor lt. green/dk. green 5 wire BCM above passenger kick, white 48 pin plug (F), pin 2 Driver Unlock Motor tan/lt. green 5 wire BCM above passenger kick, white 48 pin plug (F), pin 1 Passenger Unlock Motor purple/lt. green 5 wire BCM above passenger kick, white 48 pin plug (F), pin 3 Factory Alarm Arm (arms on lock with door open) Factory Alarm Disarm (see disarm no unlock) Disarm No Unlock (proximity key and push-button) Parking Lights (+) white/brown (LF); white/lt. blue (RF); white/gray (LR); white/orange (RR) + BCM, wht 24 pin plg (D), pin 1; blk 24 pin plg (A), pin 2; wht 48 pin plg (F), pin 32; blk 48 pin plg (E), pin 4 Parking Lights MUX white (see Tech Doc 1082) -1130 ohms headlight switch, black 6 pin plug, pin 3 or BCM above passenger kick, blue 24 pin plug (G), pin 20 Hazards white/dk. blue - BCM above passenger kick, blue 24 pin plug (G), pin 21 Turn Signal (Left) white/gray (F); white/dk. green (R) + BCM above passenger kick, white 24 pin plug (D), pin 14; black 48 pin plug (E), pin 3 Turn Signal (Right) white/gray (F); white/yellow (R) + BCM above passenger kick, black 24 pin plug (A), pin 13; white 48 pin plug (F), pin 42 Headlight white (need to relay isolate the switch) - 660 ohms headlight switch, black 6 pin plug, pin 3 or BCM above passenger kick, blue 24 pin plug (G), pin 20 AutoLights white (need to relay isolate the switch) -2000 ohms (off) headlight switch, black 6 pin plug, pin 3 or BCM above passenger kick, blue 24 pin plug (G), pin 20 Reverse Light white/tan + BCM above passenger kick, white 48 pin plug (F), pin 41 Left Front Door Trigger purple - BCM above passenger kick, white 48 pin plug (F), pin 9 Right Front Door Trigger purple/white - BCM above passenger kick, white 48 pin plug (F), pin 23 Dome Light yellow/purple + BCM above passenger kick, blue 24 pin plug (G), pin 14 Trunk/Hatch Pin purple/orange - BCM above passenger kick, white 48 pin plug (F), pin 26 Hood Pin purple/lt. blue - BCM above passenger kick, black 24 pin plug (A), pin 11 Trunk/Hatch Release lt. green - 560 ohms BCM above passenger kick, blue 24 pin plug (G), pin 8 Trunk Release Motor tan/yellow 5 wire BCM above passenger kick, white 48 pin plug (F), pin 4 Tachometer NOT brown/white ac any fuel injector Clutch Pedal yellow/orange (interlock); dk. green/orange (upstop) Tech Doc 10002 clutch switch, gray 3 pin plug, pins 2, 1 Fuel Pump dk. blue/orange (3.6L, 5.7L, 6.4L) + Fuel Pump Module under rear seat, black 5 pin plug, pin 5 On 6.2L models, it is dk. blue/orange (+) at the Fuel Pump Module under rear seat, gray 6 pin plug, pins 5 and 6. Rear Defroster dk. blue/white + latched A/C Heater Module behind glove box, white 24 pin plug, pin 18 Mirror Defroster (CAN IHS) Left Front Heated Seat (CAN IHS) Right Front Heated Seat (CAN IHS) Speed Sense (wheel speed sensor) Brake Wire dk. green/white + BCM above passenger kick, white 24 pin plug (D), pin 18 Parking Brake dk. green/white - BCM above passenger kick, black 48 pin plug (E), pin 11 Horn Trigger dk. green/white + BCM above passenger kick, black 24 pin plug (A), pin 23 Wipers brown/white + BCM above passenger kick, black 24 pin plug (A), pin 12 Left Front Window (Up/Down) (not recommended because of auto window drop down) Right Front Window (Up/Down) (not recommended because of auto window drop down) Sun Roof (Open/Close) orange/tan - orange/lt. blue (function with ignition on only) + above driver kick, gray 24 pin plug, pins 16 - 4 Radio 12V red/white + radio, black 52 pin plug, pin 44 Radio Ground black - radio, black 52 pin plug, pin 43 Radio Ignition (CAN IHS) Radio Illumination (CAN IHS) Factory Amp Turn-on (CAN IHS) Left Front Speaker (+/-) gray/purple - gray/yellow +,- radio, black 52 pin plug, pins 47 - 51 On models with amplifier, the speaker wires are gray/purple - gray/yellow at the amplifier above driver kick, black 16 pin plug, pins 8 - 16 or white 22 pin plug, pins 22 - 21. The tweeter wires are gray/orange - gray/yellow at the amplifier, white 22 pin plug, pins 20 - 9 or 6 - 7. Right Front Speaker (+/-) dk. green/purple - dk. green/yellow +,- radio, black 52 pin plug, pins 46 - 50 On models with amplifier, the speaker wires are dk. green/purple - dk. green/yellow at the amplifier above driver kick, black 16 pin plug, pins 7 - 15 or white 22 pin plug, pins 10 - 11. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 - 8 or 9 - 8. Left Rear Speaker (+/-) dk. green/tan - dk. green/gray +,- radio, black 52 pin plug, pins 48 - 52 On models with amplifier, the speaker wires are dk. green/tan - dk. green/gray at the amplifier above driver kick, black 16 pin plug, pins 14 - 6 or gray 22 pin plug, pins 22 - 21. The tweeter wires are dk. green/dk. blue - dk. green/tan at the amplifier, black 16 pin plug, pins 13 - 5 or white 22 pin plug, pins 2 - 3. Right Rear Speaker (+/-) dk. green/brown - yellow/gray +,- radio, black 52 pin plug, pins 45 - 49 On models with amplifier, the speaker wires are dk. green/brown - yellow/gray at the amplifier above driver kick, black 16 pin plug, pins 3 - 11 or white 22 pin plug, pins 5 - 4. The tweeter wires are gray/dk. blue - gray/tan at the amplifier, black 16 pin plug, pins 4 - 12 or white 22 pin plug, pins 15 - 16. Center Channel (+/-) gray/brown - gray/orange +,- amplifier above driver kick, white 22 pin plug, pins 10 - 21 or 19 - 20 Subwoofer (+/-) gray/brown - dk. green/orange (1); gray/white - dk. green/white (2) +,- amplifier above driver kick, black 16 pin plug, pins 10 - 2; 9 - 1 On premium 3 audio systems, they are at the amplifier, white 22 pin plug, pins 18 - 17; 14 - 13. Aux. Audio Input Left (+/-) lt. green/tan - lt. green/dk. blue +,- radio, black 52 pin plug, pins 16 - 7 Aux. Audio Input Right (+/-) lt. green/lt. blue - lt. green/dk. blue +,- radio, black 52 pin plug, pins 6 - 7 RSE Video (+/-) dk. green/brown - dk. green/orange (rear view camera video) +,- radio, black 52 pin plug, pins 31 - 32 Satellite Radio 12 Volts (built into radio) Item Size Depth Location Headunit irregular center of dash Left Front Speaker 6 x 9 left front door Left Front Tweeter 3.5 left front dash Right Front Speaker 6 x 9 right front door Right Front Tweeter 3.5 right front dash Left Rear Speaker 6.5 or 3.5 left rear shelf Left Rear Tweeter 3.5 left rear side panel Right Rear Speaker 6.5 or 3.5 right rear shelf Right Rear Tweeter 3.5 right rear side panel Center Channel 3.5 top center of dash Subwoofer 8 or 10 center of rear shelf or spare tire well of trunk Satellite Radio Tuner (built into radio) ------------- Gary Sather Posted By: spdy1969 Date Posted: June 02, 2017 at 12:05 AM Thanks for this. Now to wait for the new pac to arrive as the fix86 I have just isn't working out.
