Wiring for 2014 F150 with Sony Audio & Sync
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142860
Printed Date: May 03, 2024 at 5:40 AM
Topic: Wiring for 2014 F150 with Sony Audio & Sync
Posted By: tonycacaroni
Subject: Wiring for 2014 F150 with Sony Audio & Sync
Date Posted: April 12, 2017 at 10:37 AM
I have searched all over for any wiring color code / pin out info for a 2014 Ford F150 FX4 with Sony Audio and Sync.
If anyone has this info to share, you would be my internet buddy for life.
This is the setup where the speaker amp is under the center console and the sub in under the back passenger seat.
Thanks,
------------- Tony Bologna
Posted By: i am an idiot
Date Posted: April 12, 2017 at 11:33 AM
What are you trying to do?
Date Posted: April 12, 2017 at 12:00 PM
I replaced the sony sub with 2 10" RF's powered by a mono amp Pioneer GM-D8601 which accepts high level input. I tap'ed into the old inputs to the old sub for source. After tweaking cross over and gain system works "okay" but I believe the source I'm using is probably not optimal. So now I'm investigating if I need a LC6I but if so, I may need to replace the Sony speaker amps which I was trying to avoid. Having this wiring info is part of my planing.
