2010 toyota tundra radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142987
Printed Date: April 27, 2024 at 1:17 PM
Topic: 2010 toyota tundra radio
Posted By: anthonyc...
Subject: 2010 toyota tundra radio
Date Posted: May 21, 2017 at 4:14 PM
To whom it may concern,
I had to replace my evaporator, I did what I had to. Remove the dash. Lets start from the beginning, I disconnected the negative battery cable, removed the dash skin, the mounting bar, and the duct work. Replaced everything, the A/C works beautiful. Everything works but the radio, the clock, and ambient temperature readout. I checked all my fuses, removed the skin again to double check my connections, and checked for pushed pins. I'm stumped! The next thing I need to do is trace the wiring. Has anyone ever experienced the radio not working after a dash removal? Did I do wrong by only disconnecting the negative battery cable, should I have disconnected the positive cable as well?
If anyone out there can help me out I would really appreciate it.
Thanking you in advance,
Anthony C
------------- "TAKE IT EASY WHILE YOU'RE GOING FAST!"
