Print Page | Close Window |
2016 Hyundia Sonata Wiring Code for Factory RadioPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144950 Printed Date: May 09, 2024 at 2:19 PM Topic: 2016 Hyundia Sonata Wiring Code for Factory Radio Posted By: aflanigan70 Subject: 2016 Hyundia Sonata Wiring Code for Factory Radio Date Posted: November 15, 2018 at 6:14 PM 2016 Hyundia Sonata need to know the wiring codes and colors for the factory radio i am hooking up an Amp to factory radio nothing is matching p?
------------- aundrey Flanigan Replies: Posted By: aflanigan70 Date Posted: November 15, 2018 at 6:23 PM it has no RCA jack hook up and not a push button start its a reg start and is there a way i can not take out the dash
------------- aundrey Flanigan Posted By: i am an idiot Date Posted: November 15, 2018 at 7:56 PM https://metraonline.com/part/DP-7363B
Click on instructions below the picture of the kit. It is not real difficult to remove the radio. Left Front Speaker (+/-) red - blue +,- radio, white 18 pin plug, pins 2 - 11 Right Front Speaker (+/-) green - orange +,- radio, white 18 pin plug, pins 3 - 12 Left Rear Speaker (+/-) white - black +,- radio, white 18 pin plug, pins 1 - 10 Right Rear Speaker (+/-) brown - white +,- radio, white 18 pin plug, pins 4 - 13 Center Channel (+/-) red - blue (JBL) +,- amplifier in trunk right side, white 12 pin plug, pins 5 - 11 Subwoofer (+/-) white - brown (JBL) +,- amplifier in trunk right side, white 12 pin plug, pins 6 - 12 Posted By: tonanzith Date Posted: December 08, 2018 at 9:57 PM 2016 Hyundai Sonata - North America
Item Wire Color Polarity Wire Location 12 Volts red/orange (30A) + ignition switch, black 6 pin plug, pin 1 Second 12 Volts red (40A) + ignition switch, black 6 pin plug, pin 5 Ground (chassis ground) Starter yellow + ignition switch, black 6 pin plug, pin 3 Ignition pink + ignition switch, black 6 pin plug, pin 4 Accessory orange + ignition switch, black 6 pin plug, pin 2 Second Accessory blue + ignition switch, black 6 pin plug, pin 6 Keysense white - key switch, white 6 pin plug, pin 4 CAN Bus High white (C-CAN) data OBD-data link connector, black 16 pin plug, pin 6 CAN Bus Low brown (C-CAN) data OBD-data link connector, black 16 pin plug, pin 14 CAN Bus High 2 yellow (B-CAN) data SJB-dash fuse box, rear, white 32 pin plug (F), pin 9 CAN Bus Low 2 black (B-CAN) data SJB-dash fuse box, rear, white 32 pin plug (F), pin 10 IMMO Data blue/orange (EMS COM) data driver kick, white 47 pin plug, pin 19 K Line blue/black data OBD-data link connector, black 16 pin plug, pin 12 Power Lock white (without memory); (with memory use - SJB-dash fuse box, white 32 pin plug (H), pin 1 factory alarm arm) Power Unlock yellow (without memory); (with memory use - SJB-dash fuse box, white 32 pin plug (H), pin 19 factory alarm disarm) Power Unlock - Driver Door yellow/orange - SJB-dash fuse box, rear, white 32 pin plug (F), pin 5 Lock Motor gray/black 5 wire SJB-dash fuse box, black 51 pin plug (D), pin 44 Driver Unlock Motor white 5 wire driver kick, white 77 pin plug, pin 52 Passenger Unlock Motor brown 5 wire SJB-dash fuse box, black 51 pin plug (D), pin 26 Factory Alarm Arm yellow (key lock); brown (detection) (see - and SJB-dash fuse box, white 32 pin plug (H), pins 5, 10 Tech Doc 1300) open Factory Alarm blue (key unlock); brown (detection) (see Disarm Tech Doc 1300) both - SJB-dash fuse box, white 32 pin plug (H), pins 22, 10 Disarm No Unlock (transponder and ignition) Parking Lights green/black (L); brown/black (R) + SJB-dash fuse box, black 51 pin plug (D), pins 6, 5 Parking Lights MUX blue/orange - 1680 headlight/wiper switch, black 16 pin plug, pin 14 ohms Hazards red/black - SJB-dash fuse box, rear, white 32 pin plug (F), pin 13 Turn Signal (Left) blue/orange (F); blue/orange (R) + SJB-dash fuse box, white 20 pin plug (B), pin 18; black 51 pin plug (D), pin 30 Turn Signal (Right) red/orange (F); red/orange (R) + SJB-dash fuse box, white 20 pin plug (B), pin 8; black 51 pin plug (D), pin 28 Headlight blue/orange - 5580 headlight/wiper switch, black 16 pin plug, pin 14 ohms AutoLights blue/orange cut headlight/wiper switch, black 16 pin plug, pin 14 Reverse Light blue + driver kick, white 47 pin plug, pin 7 Left Front Door Trigger blue - SJB-dash fuse box, white 32 pin plug (H), pin 9 Right Front Door Trigger white - SJB-dash fuse box, white 32 pin plug (H), pin 11 Left Rear Door Trigger brown - SJB-dash fuse box, white 32 pin plug (H), pin 12 Right Rear Door Trigger orange - SJB-dash fuse box, white 32 pin plug (H), pin 14 Dome Light yellow - left front pillar, white 36 pin plug, pin 4 Trunk/Hatch Pin black/orange - SJB-dash fuse box, white 32 pin plug (H), pin 13 Hood Pin green - SJB-dash fuse box, white 24 pin plug (C), pin 3 Trunk/Hatch Release white - trunk lid opener switch, 8 pin plug, pin 3 Trunk Release Motor red + SJB-dash fuse box, black 51 pin plug (D), pin 41 Fuel Door Release green/black + fuel lid opener switch, 8 pin plug, pin 5 Tachometer blue/orange (2.4L, 2.0L-T); green (1.6L-T) ac camshaft position sensor on engine driver side, gray 3 pin plug, pin 3; black 3 pin plug, pin 2 Fuel Pump green + driver kick, white 6 pin plug, pin 2 Rear Defroster black/orange - latched SJB-dash fuse box, white 24 pin plug (C), pin 10 Mirror Defroster (same as rear defroster) Left Front Heated Seat red + A/C Control Module, white 40 pin plug, pin 16 Right Front Heated Seat brown + A/C Control Module, white 40 pin plug, pin 17 Speed Sense green ac OBD-data link connector, black 16 pin plug, pin 3 or radio, white 24 pin plug, pin 16 Brake Wire green + driver kick, white 47 pin plug, pin 14 Parking Brake orange (without electric parking brake) - SJB-dash fuse box, white 24 pin plug (C), pin 13 Horn Trigger yellow/orange - driver kick, white 47 pin plug, pin 35 Wipers blue + driver kick, white 47 pin plug, pin 33 Left Front Window (Up/Down) (motor is part of module) Right Front Window orange - white (without auto up/down only) A driver kick (without memory); RF window switch, white 8 pin (Up/Down) plug, pins 3 - 2 (with memory) Left Rear Window gray - pink (without memory); green - yellow A driver kick (without memory); LR window switch, white 12 (Up/Down) (with memory) pin plug, pins 1 - 4 (with memory) Right Rear Window green - yellow (without memory); brown - A driver kick (without memory); RR window switch, white 12 (Up/Down) white (with memory) pin plug, pins 1 - 4 (with memory) Sun Roof (Open/Close) yellow - gray (function with ignition on only) - panorama sunroof switch, black 6 pin plug, pins 2 - 3 Memory Seat 1 pink - driver kick, harness to rear Memory Seat 2 blue - driver kick, harness to rear Radio 12V red/black + radio, white 24 pin plug, pin 12 Radio Ground black - radio, white 24 pin plug, pin 24 Radio Ignition green/black + radio, white 24 pin plug, pin 11 or 18 Radio Illumination blue (parking lights); gray (dimmer) +,- radio, white 18 pin plug, pins 8, 17 Factory Amp Turn- on (M-CAN) Power Antenna red + radio, white 18 pin plug, pin 18 Left Front Speaker (+/-) red - blue +,- radio, white 18 pin plug, pins 2 - 11 Note - Left Front Speaker (+/-): On models with amplifier, the speaker wires are red - blue at the amplifier in trunk right side, white 12 pin plug, pins 1 - 7 (JBL) or black 28 pin plug, pins 26 - 25 (MOBIS). The tweeter wires are red - blue at the amplifier, white 22 pin plug, pins 1 - 12 (JBL) or black 28 pin plug, pins 3 - 4 (MOBIS). Right Front Speaker (+/-) green - orange +,- radio, white 18 pin plug, pins 3 - 12 Note - Right Front Speaker (+/-): On models with amplifier, the speaker wires are green - orange at the amplifier in trunk right side, white 12 pin plug, pins 2 - 8 (JBL) or black 28 pin plug, pins 28 - 27 (MOBIS). The tweeter wires are brown - white at the amplifier, white 22 pin plug, pins 2 - 13 (JBL) or black 28 pin plug, pins 1 - 2 (MOBIS). Left Rear Speaker (+/-) white - black +,- radio, white 18 pin plug, pins 1 - 10 Note - Left Rear Speaker (+/-): On models with amplifier, the speaker wires are white - black at the amplifier in trunk right side, white 12 pin plug, pins 3 - 9 (JBL) or black 28 pin plug, pins 15 - 14 (MOBIS). Right Rear Speaker (+/-) brown - white +,- radio, white 18 pin plug, pins 4 - 13 Note - Right Rear Speaker (+/-): On models with amplifier, the speaker wires are brown - white at the amplifier in trunk right side, white 12 pin plug, pins 4 - 10 (JBL) or black 28 pin plug, pins 13 - 12 (MOBIS). Center Channel (+/-) red - blue (JBL) +,- amplifier in trunk right side, white 12 pin plug, pins 5 - 11 Subwoofer (+/-) white - brown (JBL) +,- Note - Subwoofer (+/-): On models with MOBIS amplifier, the subwoofer wires are white - brown (1); blue - red (2) at the amplifier in trunk right side, black 28 pin plug, pins 16 - 17; 18 - 19. amplifier in trunk right side, white 12 pin plug, pins 6 - 12 Aux. Audio Input Left (+/-) black - black/orange or red - black/orange +,- radio, white 24 pin plug, pins 21 - 9 Aux. Audio Input Right (+/-) white - black/orange or black - black/orange +,- radio, white 24 pin plug, pins 8 - 9 Rearview Camera Video green - white +,- radio, white 16 pin plug, pins 4 - 3 or white 24 pin plug, pins 23 - 22 Satellite Radio 12 Volts (built into radio) What Fits? Item Size Depth Location Headunit irregular center of dash Satellite Radio Tuner (built into radio) ------------- Gary Sather Posted By: akmo23 Date Posted: May 09, 2021 at 11:17 PM On the touchscreen. Vcc is located on the panel with the clock below the stereo behind the tuning knob. There is a diagram and space to wedge an amps remote with no splicing.
Behind the stereo you will see 2 white multi wire pinout clips the (inner clip). The clip has 8 wires slightly thicker and larger pins left side of the clip looking over the unit. The + and - are adjacent for each speaker. I only tapped the red,blue and orange green for my fronts. The tester I made was a 1.5v AA and two leads after removing the pinout to test speakers making contact. Very audible clicking. Telling you how to make the tool and pointing the direction 'goodluck. |
