2019 Ford Transit Van, Full Size, Alarm/Remote Start Wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145462
Printed Date: June 07, 2024 at 12:29 PM
Topic: 2019 Ford Transit Van, Full Size, Alarm/Remote Start Wiring?
Posted By: kamikaze4299
Subject: 2019 Ford Transit Van, Full Size, Alarm/Remote Start Wiring?
Date Posted: June 12, 2019 at 8:19 PM
Was wondering if anyone had the vehicle wire colors for a 2019 Ford Transit Van? Installing a Python Security and Remote Start 2-way System.
Posted By: motosaki
Date Posted: June 13, 2019 at 3:19 PM
12 Volts Blue/Red (15A) + Ignition Switch, black 7 pin plug, pin 4
Second 12 Volts Yellow/Red (60A) + BCM/Dash Fuse Box, black 2 pin plug (A), pin 1
Ground (chassis ground)
Starter Blue/White + Ignition Switch, black 7 pin plug, pin 7
Ignition Brown/Yellow + Ignition Switch, black 7 pin plug, pin 1
Accessory Violet/Green + Ignition Switch, black 7 pin plug, pin 6
Keysense Blue/Gray + Ignition Switch, black 7 pin plug, pin 5
CAN Bus High White/Blue (HS CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 6
CAN Bus Low White (HS CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 14
CAN Bus High 2 Gray/Orange (MS CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 3
CAN Bus Low 2 Violet/Orange (MS CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 11
RX DATA Violet/Gray Data PATS Transceiver on ignition switch, black 4 pin plug, pin 4
TX DATA Yellow/Orange Data PATS Transceiver on ignition switch, black 4 pin plug, pin 3
Power Lock gray/yellow - BCM/dash fuse box, brown 76 pin plug (C), pin 25
Power Unlock violet/gray - BCM/dash fuse box, brown 76 pin plug (C), pin 56
Lock Motor violet/green 5 wire BCM/dash fuse box, brown 46 pin plug (B), pin 18
Driver Unlock Motor blue/green 5 wire BCM/dash fuse box, brown 46 pin plug (B), pin 39
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (transponder and ignition)
Parking Lights green/orange (LF); violet/green (LR); brown/yellow (RF); white/orange (RR) + BCM/dash fuse box, brown 46 pin plug (B), pins 14, 15; brown 76 pin plug (C), pins 66, 67
Parking Lights - (LIN bus)
Hazards brown/yellow - BCM/dash fuse box, blue 76 pin plug (D), pin 13
Turn Signal (Left) blue/green (F); white/green (R) + BCM/dash fuse box, brown 76 pin plug (C), pins 61, 68
Turn Signal (Right) yellow/violet (F); gray/violet (R) + BCM/dash fuse box, brown 76 pin plug (C), pin 63; brown 46 pin plug (B), pin 20
Headlight gray/brown (L); violet/orange (R) (high beams) + BCM/dash fuse box, brown 46 pin plug (B), pins 5, 17
AutoLights (LIN bus)
Reverse Light green/brown + BCM/dash fuse box, brown 46 pin plug (B), pin 11
Left Front Door Trigger green/violet - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 44
Right Front Door Trigger white - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 34
Left Rear Door Trigger green - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 35
Right Rear Door Trigger yellow - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 51
Dome Light yellow/gray and white/orange (front); white/blue and green/violet (rear) - and + junction connector above driver kick, white 59 pin plug, pins 11, 26; 19, 43
Trunk/Hatch Pin brown/violet - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 50
Hood Pin white/brown - N.C. BCM/dash fuse box, brown 76 pin plug (C), pin 40
Trunk Release Motor green/white (cargo doors unlock) 5 wire BCM/dash fuse box, brown 46 pin plug (B), pin 44
Tachometer green/blue, gray/yellow, violet/gray, yellow/orange, brown, or green/white (3.5L) ac PCM on driver fender, 95 pin plug, pin 84, 90, 82, 83, 85, or 95
Rear Defroster blue/gray - BCM/dash fuse box, blue 76 pin plug (D), pin 40
Mirror Defroster (same as rear defroster)
Speed Sense violet/orange ac customer interface connector under driver seat, gray 6 pin plug, pin 4
Brake Wire violet/white + brake switch or BCM/dash fuse box, brown 76 pin plug (C), pin 58
Parking Brake white/violet - BCM/dash fuse box, brown 76 pin plug (C), pin 54
Horn Trigger blue/white - horn switch or BCM/dash fuse box, blue 76 pin plug (D), pin 17
Wipers white - BCM/dash fuse box, brown 76 pin plug (C), pin 42
------------- 15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Date Posted: June 18, 2019 at 8:22 PM
Thank You!
Posted By: vacmech7
Date Posted: October 17, 2020 at 6:37 PM
Did you suscefully install your remote start in your Ford Transit usisng this wire info?
------------- Vacmech7
