Print Page | Close Window |
2017 Kia Sorento, Alarm & Remote Start, Standard KeyPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146425 Printed Date: May 09, 2024 at 12:32 AM Topic: 2017 Kia Sorento, Alarm & Remote Start, Standard Key Posted By: swamprat323 Subject: 2017 Kia Sorento, Alarm & Remote Start, Standard Key Date Posted: September 05, 2020 at 12:14 PM NOT Push to Start but standard key.
2017 Kia Sorento. Remote start and alarm. Replies: Posted By: tonanzith Date Posted: October 01, 2020 at 1:26 PM here you go
2017 Kia Sorento - North America Item Wire Color Polarity Wire Location 12 Volts Red (40A) + Ignition Switch, black 6 pin plug, pin 1 Second 12 Volts White (40A) + Ignition Switch, black 6 pin plug, pin 5 Ground (chassis ground) Starter Black + Ignition Switch, black 6 pin plug, pin 3 Ignition Green + Ignition Switch, black 6 pin plug, pin 4 Accessory Blue + Ignition Switch, black 6 pin plug, pin 2 Second Accessory Red + Ignition Switch, black 6 pin plug, pin 6 Keysense Pink/Black - Key Switch, white 6 pin plug, pin 4 CAN Bus High White (D-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 6 CAN Bus Low Brown (D-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 14 CAN Bus High 2 Red (B-CAN) Data Driver Kick, blue 68 pin plug, pin 14 CAN Bus Low 2 Blue (B-CAN) Data Driver Kick, blue 68 pin plug, pin 4 OBD 12 Volts Gray/Black (10A) + OBD-Data Link Connector, black 16 pin plug, pin 16 OBD Ground Black - OBD-Data Link Connector, black 16 pin plug, pin 4 IMMO Data White/Orange (EMS COM) Data Driver Kick, red 58 pin plug, pin 3 K Line White Data OBD-Data Link Connector, black 16 pin plug, pin 12 Power Lock White/Black (passenger switch) - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 14 Power Unlock Blue/Orange (passenger switch) - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 15 Lock Motor Red Reverse IGPM-Dash Fuse Box, black 46 pin plug (D), pin 24 Driver Unlock Motor Green Reverse Power Window Main Switch, black 8 pin plug, pin 3 Passenger Unlock Motor Brown Reverse IGPM-Dash Fuse Box, black 46 pin plug (D), pin 34 Factory Alarm Arm Brown/Black (see Tech Doc 1300) - Power Window Main Switch, white 32 pin plug, pin 7 Factory Alarm Disarm Pink/Black (see Tech Doc 1300) Double - Power Window Main Switch, white 32 pin plug, pin 6 Lock Detection Red/Orange (see Tech Doc 1300) Open Power Window Main Switch, white 32 pin plug, pin 4 Unlock Detection (same as lock detection) - Parking Lights White/Black (LF); Brown (RF) + IGPM-Dash Fuse Box, black 51 pin plug (B), pin 14 (LF); pin 11 (RF) Parking Lights 2 Green/Black (LR); Yellow (RR) + IGPM-Dash Fuse Box, white 41 pin plug (C), pin 22 (LR); pin 33 (RR) Parking Lights - Blue - 1680 Ohms Headlight-Wiper Switch, black 16 pin plug, pin 14 Parking Lights MUX Blue MUX Headlight-Wiper Switch, black 16 pin plug, pin 14 Hazards Pink - IGPM-Dash Fuse Box, rear, white 18 pin plug (G), pin 15 Turn Signal (Left) Yellow/Black (LF); Gray (LR) + IGPM-Dash Fuse Box, black 51 pin plug (B), pin 18 (LF); white 41 pin plug (C), pin 32 (LR) Turn Signal (Right) White (RF); White/Black (RR) + IGPM-Dash Fuse Box, black 51 pin plug (B), pin 51 (RF); white 41 pin plug (C), pin 3 (RR) Headlight Blue/Orange - Headlight-Wiper Switch, black 16 pin plug, pin 15 AutoLights Blue Cut Headlight-Wiper Switch, black 16 pin plug, pin 14 Reverse Light Red/Black + IGPM-Dash Fuse Box, black 46 pin plug (D), pin 2 Left Front Door Trigger Gray/Orange - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 17 Right Front Door Trigger Yellow/Black - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 18 Left Rear Door Trigger White/Black - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 8 Right Rear Door Trigger Brown/Black - IGPM-Dash Fuse Box, black 46 pin plug (D), pin 7 Dome Light Brown - Left Front Pillar, white 36 pin plug, pin 35 Trunk/Hatch Pin Brown - IGPM-Dash Fuse Box, white 41 pin plug (C), pin 25 Hood Pin Pink/Black - IGPM-Dash Fuse Box, black 51 pin plug (B), pin 21 Power Liftgate Green/Orange - Power Liftgate Switch, white 8 pin plug, pin 5 Trunk/Hatch Release Gray/Black (rear handle switch) - IGPM-Dash Fuse Box, white 41 pin plug (C), pin 28 Trunk Release Motor Blue + IGPM-Dash Fuse Box, black 46 pin plug (D), pin 45 Fuel Door Release Blue + Fuel Filler Door Switch, white 8 pin plug, pin 2 Tachometer Brown (2.0L and 2.4L) AC Camshaft Position Sensor, engine driver side front, gray 3 pin plug, pin 1 Tachometer 2 Gray (3.3L) AC Camshaft Position Sensor, engine driver side front, black 3 pin plug, pin 2 Fuel Pump Pink + Driver Kick, white 25 pin plug, pin 9 Rear Defroster Green/Orange - Latched Driver Kick, red 58 pin plug, pin 16 Mirror Defroster (same as rear defroster) Wiper Deicer (same as rear defroster) Left Front Heated Seat Brown + Seat Heater Switch, white 24 pin plug, pin 11 Right Front Heated Seat Gray + Seat Heater Switch, white 24 pin plug, pin 2 Speed Sense Brown/Orange AC OBD-Data Link Connector, black 16 pin plug, pin 3 --or-- Radio, white 24 pin plug, pin 16 or white 38 pin plug, pin 38 Brake Wire Green/Orange + IGPM-Dash Fuse Box, black 51 pin plug (B), pin 12 Parking Brake Gray/Orange - Driver Kick, red 58 pin plug, pin 8 (w/o EPB); Driver Front of Center Console, white 32 pin plug, pin 31 (with EPB) Horn Trigger Gray - Driver Kick, red 58 pin plug, pin 21 Wipers Orange/Black + Driver Kick, red 58 pin plug, pin 19 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) White - Pink (w/o auto up/down only) A Passenger Window Switch, white 18 pin plug, pins 15 - 13 or black 8 pin plug, pins 4 - 7 Left Rear Window (Up/Down) Pink - Brown (w/o auto up/down only) A Left Rear Window Switch, white 18 pin plug, pins 15 - 13 Right Rear Window (Up/Down) Pink - Brown (w/o auto up/down only) A Right Rear Window Switch, white 18 pin plug, pins 15 - 13 Sun Roof (Open/Close) Red and White (open) (functions with ignition on only) Both - Sunroof Switch, white 6 pin plug, pins 2, 5 Sun Roof (Limit/Close) Brown and White (close) (functions with ignition on only) Both - Sunroof Switch, white 6 pin plug, pins 3, 5 Memory Seat 1 Blue - Power Window Main Switch, white 32 pin plug, pin 1 Memory Seat 2 Red/Black - Power Window Main Switch, white 32 pin plug, pin 2 Radio 12V Pink + Radio, white 24 pin plug, pin 12 or white 35 pin plug, pin 10 Radio Ground Black - Radio, white 24 pin plug, pin 24 or white 35 pin plug, pin 12 Radio Ignition White + Radio, white 24 pin plug, pin 11 or 18 or white 35 pin plug, pin 22 Radio Illumination Red/Orange (parking lights); Blue/Orange (dimmer) +,- Radio, white 18 pin plug, pins 8, 17 or white 35 pin plug, pins 6, 19 Factory Amp Turn-on (M-CAN) Power Antenna Green + Radio, white 18 pin plug, pin 18 or white 35 pin plug, pin 5 Left Front Speaker (+/-) Brown - White +,- Radio, white 18 pin plug, pins 2 - 11 or white 38 pin plug, pins 13 - 14 Right Front Speaker (+/-) Red - Blue +,- Radio, white 18 pin plug, pins 3 - 12 or white 38 pin plug, pins 16 - 15 Left Rear Speaker (+/-) Yellow - Black +,- Radio, white 18 pin plug, pins 1 - 10 or white 38 pin plug, pins 1 - 2 Right Rear Speaker (+/-) Green - Orange +,- Radio, white 18 pin plug, pins 4 - 13 or white 38 pin plug, pins 28 - 27 Left Front Speaker - With Amp Brown - White +,- Amplifier under passenger seat, black 28 pin plug, pins 4 - 19 Right Front Speaker - With Amp Red - Blue +,- Amplifier under passenger seat, black 28 pin plug, pins 3 - 18 Left Front Tweeter - With Amp Black - White +,- Amplifier under passenger seat, white 28 pin plug, pins 13 - 26 Right Front Tweeter - With Amp Orange - Blue +,- Amplifier under passenger seat, white 28 pin plug, pins 12 - 25 Left Rear Speaker - With Amp Yellow - Black +,- Amplifier under passenger seat, black 28 pin plug, pins 13 - 26 Right Rear Speaker - With Amp Green - Orange +,- Amplifier under passenger seat, black 28 pin plug, pins 12 - 25 Left Rear Surround - With Amp Orange - Green +,- Amplifier under passenger seat, black 28 pin plug, pins 15 - 28 Right Rear Surround - With Amp Green - Pink +,- Amplifier under passenger seat, black 28 pin plug, pins 14 - 27 Center Channel - With Amp Blue - Red +,- Amplifier under passenger seat, white 28 pin plug, pins 14 - 27 Subwoofer - With Amp Green - Orange (coil 1); Blue - Red (coil 2) +,- Amplifier under passenger seat, black 28 pin plug, pins 2 - 17 (coil 1); pins 1 - 16 (coil 2) Aux. Audio Input Left (+/-) Green, Gray, or Yellow - Black/Orange +,- Radio, white 24 pin plug, pins 21 - 9 or white 38 pin plug, pins 24 - 25 Aux. Audio Input Right (+/-) White or Brown - Black/Orange +,- Radio, white 24 pin plug, pins 8 - 9 or white 38 pin plug, pins 10 - 25 Rearview Camera Video Red - Black or Black - Red +,- Radio, white 16 pin plug, pins 4 - 3 or white 38 pin plug, pins 7 - 21 or white 24 pin plug, pins 23 - 22 ------------- Gary Sather Posted By: bigquis Date Posted: December 13, 2022 at 12:35 AM For the life of me I cannot figure out how to get the parking lights on this thing to work. The blue wire does not bring the lights on and when I connect the white/black and green/black I only get one of the front and one of the back lights working. Any ideas?
Posted By: mgoetz74 Date Posted: December 14, 2022 at 3:55 PM parking lights - are mux Blue - 1680 Ohms Headlight-Wiper Switch, black 16 pin plug, pin 14
better off doing all 4 positive if your not using a bypass module for convince stuff like lights/locks Parking Lights White/Black (LF); Brown (RF) + IGPM-Dash Fuse Box, black 51 pin plug (B), pin 14 (LF); pin 11 (RF) Parking Lights 2 Green/Black (LR); Yellow (RR) + IGPM-Dash Fuse Box, white 41 pin plug (C), pin 22 (LR); pin 33 (RR) ------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!! Posted By: bigquis Date Posted: December 19, 2022 at 9:25 PM Thanks for the reply. I feel like a bonhead. I guess i didnt fully read that since is says LF and LR meaning only one side. Then right next to it it says RF and RR. I must have been really tired.
Thanks again! Posted By: bigquis Date Posted: December 21, 2022 at 11:27 AM Last wire I need is the hood pin. I don't really wanna drill under the hood to install that pin but I can't find that pink and black wire in the 51 pin. I see a wire that is obviously pink but I seen no black on it. I also see a bunch of other wires that are more salmon in color. I'm not very good with a multi meter so I'm winging it here. Any ideas?
