2018 Mitsubishi Mirage G4, Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146491
Printed Date: May 09, 2024 at 3:50 AM
Topic: 2018 Mitsubishi Mirage G4, Remote Start Wiring
Posted By: trowedder
Subject: 2018 Mitsubishi Mirage G4, Remote Start Wiring
Date Posted: October 09, 2020 at 5:21 PM
requesting a wiring diagram with color and location of wire for a remote install for a 2018 mitsubishi mirage g4 , thanks!
------------- TR
sorry key start
------------- TR
Posted By: tonanzith
Date Posted: October 14, 2020 at 11:58 AM
2018 mirage
Item Wire Color Polarity Wire Location
12 Volts white (40A) + ignition switch, white 6 pin plug, pin 1
Ground (chassis ground)
Starter pink + ignition switch, white 6 pin plug, pin 5
Ignition green + ignition switch, white 6 pin plug, pin 2
Accessory yellow + ignition switch, white 6 pin plug, pin 4
Second Accessory yellow + ignition switch, white 6 pin plug, pin 6
Keysense red/white open key switch, white 7 pin plug, pin 6
CAN Bus High brown/white data data link connector, black 16 pin plug, pin 6
CAN Bus Low black/white data data link connector, black 16 pin plug, pin 14
Power Lock green - right of dash fuse box, white 22 pin plug, pin 22
Power Unlock lt. blue - right of dash fuse box, white 22 pin plug, pin 11
Lock Motor violet 5 wire right of dash fuse box, white 14 pin plug, pin 3
Driver Unlock Motor pink 5 wire right of dash fuse box, white 14 pin plug, pin 10
Passenger Unlock Motor lt. green 5 wire driver kick, gray 12 pin plug, pin 11
Parking Lights green/white + dash fuse box, white 13 pin plug, pin 1
Parking Lights - (LIN bus)
Hazards green - ETACS-ECU on left rear of dash fuse box, gray 24 pin plug, pin 21
Turn Signal (Left) blue/white (hatchback); blue (sedan) + dash fuse box, white 13 pin plug, pin 10
Turn Signal (Right) gray/black (hatchback); gray (sedan) + dash fuse box, white 13 pin plug, pin 11
Headlight yellow/black (hatchback); yellow (sedan) (LO); blue/white (hatchback); blue (sedan) (HI) - dash fuse box, white 10 pin plug, pins 6, 1
Reverse Light brown (hatchback); violet/white (sedan) + driver kick, white 13 pin plug, pin 9
Left Front Door Trigger violet/white - driver kick, white 22 pin plug, pin 21
Right Front Door Trigger red/white - driver kick, white 22 pin plug, pin 22
Left Rear Door Trigger violet/white - driver kick, gray 12 pin plug, pin 5
Right Rear Door Trigger (same as left rear door trigger)
Dome Light red - dash fuse box, white 4 pin plug, pin 2
Trunk/Hatch Pin (same as left rear door trigger) (hatchback); lt. green (sedan) - trunk compartment light, white 2 pin plug, pin 2
Trunk/Hatch Release (locks/unlocks along with doors) (hatchback)
Tachometer blue/white, brown/white, or yellow/black ac any fuel injector, gray 2 pin plug, pin 2
Clutch Pedal green/white (hatchback); green (sedan) + clutch switch, black 2 pin plug, pin 1; white 2 pin plug, pin 1
Fuel Pump pink/black + dash fuse box, white 10 pin plug, pin 8
Rear Defroster green - latched dash fuse box, white 14 pin plug, pin 9
Mirror Defroster (same as rear defroster)
Left Front Heated Seat pink 5 wire heated seat switch, white 9 pin plug, pin 3
Right Front Heated Seat white 5 wire heated seat switch, white 9 pin plug, pin 9
Speed Sense yellow ac radio, white 20 pin plug, pin 11
Brake Wire blue/white (hatchback); blue (sedan) + brake switch, white 4 pin plug, pin 2; white 4 pin plug, pin 1
Parking Brake brown/white - parking brake switch, black 1 pin plug, pin 1
Horn Trigger lt. green/black (hatchback); lt. green (sedan) - driver kick, white 10 pin plug, pin 6
Wipers blue/white (hatchback); blue (sedan) (LO); white/black (hatchback); white (sedan) (HI) + dash fuse box, white 13 pin plug, pins 4, 3
Left Front Window (Up/Down) pink - gray or violet - violet A power window main switch, black 12 pin plug, pins 9 - 8 or black 16 pin plug, pins 12 - 11
Right Front Window (Up/Down) red - white A right of dash fuse box, white 14 pin plug, pins 2 - 9
Left Rear Window (Up/Down) lt. blue - green A right of dash fuse box, white 14 pin plug, pins 5 - 12
Right Rear Window (Up/Down) blue - brown A right of dash fuse box, white 14 pin plug, pins 4 - 11
Radio 12V white + radio, white 20 pin plug, pin 10
Radio Ground black/white - radio, white 20 pin plug, pin 20
Radio Ignition blue/white + radio, white 20 pin plug, pin 1
Radio Illumination gray/black (parking lights); lt. blue (dimmer) +,- radio, white 20 pin plug, pins 9, 19
Power Antenna pink + radio, white 20 pin plug, pin 14
Left Front Speaker (+/-) red - green +,- radio, white 20 pin plug, pins 8 - 18
Right Front Speaker (+/-) brown - violet +,- radio, white 20 pin plug, pins 6 - 16
Left Rear Speaker (+/-) green - white +,- radio, white 20 pin plug, pins 7 - 17
Right Rear Speaker (+/-) brown - gray +,- radio, white 20 pin plug, pins 5 - 15
Aux. Audio Input Left (+/-) white - gray (hands-free audio) +,- radio, white 18 pin plug, pins 4 - 12
Aux. Audio Input Right (+/-) black - gray (hands-free audio) +,- radio, white 18 pin plug, pins 3 - 12
Rearview Camera Video black - gray +,- radio, white 10 pin plug, pins 5 - 10
------------- Gary Sather
