2018 Ford Fusion SE, Speaker Wire Diagram?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146522
Printed Date: June 09, 2024 at 6:44 AM
Topic: 2018 Ford Fusion SE, Speaker Wire Diagram?
Posted By: mproducerstudio
Subject: 2018 Ford Fusion SE, Speaker Wire Diagram?
Date Posted: October 27, 2020 at 3:31 PM
I’m looking for the car stereo speaker wire diagram for a 2018 Ford Fusion SE I can’t seem to find it. Any help would be greatly appreciated thanks!
------------- ThatOneUberDriver
Posted By: i am an idiot
Date Posted: October 27, 2020 at 6:25 PM
Radio 12V White/Brown + Radio, black 24 pin plug, pin 1
Radio Ground Black/Gray - Radio, black 24 pin plug, pin 13
Radio Ignition Brown/Yellow (delayed accessory) + Driver Kick, door harness --or-- BCM-Dash Fuse Box, black 36 pin plug (F), pin 30
Radio Illumination (HS CAN)
Factory Amp Turn-on Violet/Red + Radio, black 26 pin plug, pin 18
Power Antenna Green/Violet + Radio, black 24 pin plug, pin 2
Left Front Speaker (+/-) White - White/Brown +,- Radio, black 24 pin plug, pins 22 - 10
Right Front Speaker (+/-) White/Violet - White/Orange +,- Radio, black 24 pin plug, pins 23 - 11
Left Rear Speaker (+/-) White/Green - Brown/Yellow +,- Radio, black 24 pin plug, pins 21 - 9
Right Rear Speaker (+/-) Brown/White - Brown/Blue +,- Radio, black 24 pin plug, pins 24 - 12
Left Front Speaker - With Amp White - White/Brown (woofer); Green/Orange - Gray/Orange (tweeter) +,- Amplifier in trunk right side, gray 16 pin plug, pins 2 - 10 (woofer); pins 3 - 11 (tweeter)
Right Front Speaker - With Amp White/Violet - White/Orange (woofer); Violet/Orange - Yellow/Orange (tweeter) +,- Amplifier in trunk right side, gray 16 pin plug, pins 6 - 14 (woofer); pins 7 - 15 (tweeter)
Left Rear Speaker - With Amp White/Green - Brown/Yellow +,- Amplifier in trunk right side, gray 16 pin plug, pins 4 - 12
Right Rear Speaker - With Amp Brown/White - Brown/Blue +,- Amplifier in trunk right side, gray 16 pin plug, pins 8 - 16
Center Channel - With Amp Green - Gray/Yellow (F); Green/Brown - Violet/Brown (R) +,- Amplifier in trunk right side, gray 16 pin plug, pins 1 - 9 (F); pins 5 - 13 (R)
Subwoofer - With Amp Green/Violet - Gray (L); Violet - Yellow (R) +,- Amplifier in trunk right side, 16 pin plug, pins 2 - 10 (L); pins 1 - 9 (R)
