2007 Dodge Dakota, Remote Start Add On Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146689
Printed Date: May 17, 2024 at 6:05 PM
Topic: 2007 Dodge Dakota, Remote Start Add On Wiring
Posted By: jasonharry
Subject: 2007 Dodge Dakota, Remote Start Add On Wiring
Date Posted: January 21, 2021 at 12:07 PM
Looking for a wiring down for adding an a vital 4003 remote start module to the OE security system.
------------- Jharry
Posted By: wirewise
Date Posted: January 21, 2021 at 12:11 PM
DAKOTA 2007-2011
KEY T-HARNESS IMMOBILIZER
CHRKEY4 N/A CHRYSLER'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) @ BATTERY or IPM, NOTE #2
STARTER SEE NOTE #1
STARTER 2 SEE NOTE #1
IGNITION 1 PINK/GRAY (+) @ IGNITION SWITCH, (BLACK, 6-PIN PLUG) PIN 3
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 SEE NOTE #1
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) PINK/RED (-) thru a 1130 Ohm Resistor @ HEADLIGHT SWITCH or INSTRUMENT CLUSTER, (GRAY, 16-PIN PLUG) PIN 5
PARKING LIGHTS ( + ) PINK/RED(+) (Left) and WHITE/ORANGE(+) (Right) @ IPM, (BLACK, 20-IN PLUG) PINS 15 and 17, NOTE #2
POWER LOCK PURPLE/DARK GREEN (-) thru a 330 Ohm Resistor in DRIVERS KICK PANEL or INSTRUMENT CLUSTER, (GRAY, 16-PIN PLUG) PIN 3
POWER UNLOCK Use LOCK wire, (-) thru a 100 Ohm Resistor
LOCK MOTOR WIRE LT. GREEN (5-wire type) in DRIVERS KICK PANEL or INSTRUMENT CLUSTER, (GRAY, 26-PIN PLUG) PIN 15
DOOR TRIGGER PURPLE (-) in DRIVERS KICK PANEL or INSTRUMENT CLUSTER, (GRAY, 26-PIN PLUG) PIN 6
DOMELIGHT SUPERVISION YELLOW/ORANGE (+) @ INSTRUMENT CLUSTER, (WHITE, 26-PIN PLUG) PIN 11
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN DARK GREEN/PURPLE (-) @ HORN SWITCH or INSTRUMENT CLUSTER, (GRAY, 26-PIN PLUG) PIN 10
TACH any wire NOT RED (AC) @ Any FUEL INJECTOR
WAIT TO START LIGHT N/A
BRAKE WHITE/LIGHT BLUE (+) @ BRAKE SWITCH or in DRIVERS KICK PANEL, Harness to Rear of Vehicle.
FACTORY ALARM DISARM DISARMS WITH FACTORY REMOTE ONLY!!
ANTI-THEFT CHRYSLER'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, See NOTE #1
NOTES
NOTE #1: This vehicle is Equipped with CHRYSLERS MULTIPLEXED IGNITION CIRCUIT/ANTI-THEFT SYSTEM that will require an INTERFACE BYPASS MODULE, Part # DBALL2 or XK09 for REMOTE STARTING
NOTE #2: THE IPM (INTEGRATED POWER MODULE) IS LOCATED IN THE ENGINE COMPARTMENT, ON THE DRIVERS FENDER.
------------- ~wirewise~
Date Posted: January 21, 2021 at 10:31 PM
Thank you wirewise. Looks like I got my work cut out for me.
Date Posted: January 21, 2021 at 10:41 PM
Another question, can I use an Xpresskit pkucg2x bypass module instead of the DBALL2 or theXK09 bypass module. I already purchased the PKUCG2X is the reason I ask.
Posted By: geepherder
Date Posted: January 22, 2021 at 5:48 AM
I think the wiring info above is from Bulldog, which only offered the DBALL2 and XK09.
According to the directechs website, the PKUCG2X will work:
https://www.directechs.com/VehicleCompatibility?Category=5&ProductState=3&VehicleID=2232------------- My ex once told me I have a perfect face for radio.
Date Posted: January 22, 2021 at 5:11 PM
Thanks again wirewise. Fixing to gather up all my wiring tools and jump into this remote start install head first.
Date Posted: January 26, 2021 at 5:33 AM
Hey Wisewre, I haven’t had the chance to start the remote start module on my 07 Dakota yet, but I do have another question about the wiring. I was looking at another thread I came across , as I was looking around on this awesome forum and found another wiring diagram that says I need to diode isolate the (-) door wires for each door. The diagram that you found and the other I found are the same, except the diode isolation of the (-) door wires. Do some Dakotas have only one door wire and some have 4 ? I have the diodes, just was wondering if it was necessary.
