Radio Diagram, 2021 Toyota Rav4 Prime SE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146978
Printed Date: May 13, 2024 at 9:04 PM
Topic: Radio Diagram, 2021 Toyota Rav4 Prime SE
Posted By: sqeclipse
Subject: Radio Diagram, 2021 Toyota Rav4 Prime SE
Date Posted: August 13, 2021 at 7:08 PM
Do anyone have a Radio diagram for 2021 Toyota Rav 4 Prime SE. Seems like iDatalink HRN-RR-TO3 and Mestro RR dosent work on this car yet~ Thanks
Posted By: i am an idiot
Date Posted: August 13, 2021 at 9:10 PM
Radio 12V Lt. Green or Tan + Radio, gray 28 pin plug, pin 4
Radio Ground White/Black - Radio, gray 28 pin plug, pin 1
Radio Ignition Gray + Radio, gray 28 pin plug, pin 15
Radio Illumination Green (parking lights); Tan (dimmer) +,- Radio, white 30 pin plug, pin 15 (parking lights); pin 16 (dimmer)
Left Front Speaker (+/-) Lavender/Black - Lavender/Red --or-- Black - Green +,- Radio, black 10 pin plug, pins 2 - 7
Right Front Speaker (+/-) Lavender/Lt. Green - Lavender/Blue --or-- White - Red +,- Radio, black 10 pin plug, pins 1 - 6
Left Rear Speaker (+/-) Lavender/Green - Lavender/Gray --or-- Yellow - Brown +,- Radio, black 10 pin plug, pins 3 - 8
Right Rear Speaker (+/-) Lavender/Red - Lavender/Green +,- Radio, black 10 pin plug, pins 4 - 9
Left Front Speaker - With Amp Lavender/White - Lavender/Lt. Green +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 14 - 29
Right Front Speaker - With Amp Lavender/Gray - Lavender/Blue +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 9 - 24
Left Front Tweeter - With Amp Lavender/Black - Lavender/Lt. Green +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 10 - 25
Right Front Tweeter - With Amp Lavender/Tan - Lavender/Gray +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 13 - 28
Left Rear Speaker - With Amp Lavender/Green - Lavender/Lt. Green +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 11 - 26
Right Rear Speaker - With Amp Lavender/Red - Lavender/Lt. Green +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 12 - 27
Subwoofer - With Amp Lavender/Yellow - Lavender/Blue (coil 1); Lavender/Red - Lavender/Blue (coil 2) +,- Amplifier in right rear quarter panel, white 30 pin plug, pins 8 - 23 (coil 1); pins 15 - 30 (coil 2)
Aux. Audio Input Left (+/-) Black - Red +,- Radio, gray 28 pin plug, pins 11 - 13
Aux. Audio Input Right (+/-) White - Red +,- Radio, gray 28 pin plug, pins 12 - 13
Rearview Camera Video Black - White (rear); Violet - Lt. Blue (panoramic) +,- Radio, white 30 pin plug, pins 28 - 29
Posted By: 99K1500
Date Posted: November 26, 2021 at 12:35 PM
Any idea on the VSS or speed wire for this vehicle? 2021 RAV4 with JBL
Posted By: mgoetz74
Date Posted: November 26, 2021 at 4:13 PM
Speed Sense Lt. Green AC Radio, gray 28 pin plug, pin 27
------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!!
Posted By: 99K1500
Date Posted: November 26, 2021 at 5:30 PM
Thanks - From the wire side of the harness, that appears to be the 2nd wire from the left on the bottom. I will give that a shot.
Posted By: 99K1500
Date Posted: December 01, 2021 at 7:45 PM
mgoetz74,
Thank you so much that Speed Sense wire was spot on! Don't suppose there is a parking brake or park wire for the JBL system. Album Art does not work UNLESS the vehicle is in Park
Posted By: r4p-md
Date Posted: March 08, 2022 at 8:23 AM
Did you ever get an answer on the parking brake question? I'm look to enable album art as well.
Thx!
------------- R4P MD
2006 TJ
Posted By: raven2k1
Date Posted: March 31, 2022 at 1:12 PM
it took me 2 days to find information about the parking brake :( In the middle connector (30 pins) cut the pin 20 wire (for me it was black) and connect the part that comes from the radio to pin 24 (isolated GND). In this way you will foul the radio to think it is always in park. isolate the remaining part of the wire that was connected to pin 20 and that's it !
good luck.
------------- SBN
Posted By: frmdaleftcoast
Date Posted: April 19, 2023 at 5:24 PM
Any chance this would also apply for my 2020 C-HR LE?
Posted By: bnml
Date Posted: December 05, 2023 at 4:59 PM
Any idea where the speed sense is on the hybrid model? Seems to be different.
Thanks,
------------- BL
