Print Page | Close Window |
2022 Hyundai Accent, Remote Start/Keyless Entry WiringPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147169 Printed Date: June 05, 2024 at 7:17 AM Topic: 2022 Hyundai Accent, Remote Start/Keyless Entry Wiring Posted By: caraudioholic24 Subject: 2022 Hyundai Accent, Remote Start/Keyless Entry Wiring Date Posted: December 10, 2021 at 6:37 AM Good Morning, I have a 2022 Hyundai Accent, normal key that I need Remote Start /Keyless entry wiring info for. Thank You in advance!!
Replies: Posted By: mgoetz74 Date Posted: December 10, 2021 at 9:31 AM nothing on the 2022 accent yet on directechs. this is the 2021 so i don't know if the 2022 is a redesign year or not
12 Volts Green (40A) + Ignition Switch, black 6 pin plug, pin 1 Second 12 Volts Blue (40A) + Ignition Switch, black 6 pin plug, pin 5 Ground (chassis ground) Starter White + Ignition Switch, black 6 pin plug, pin 3 Ignition White + Ignition Switch, black 6 pin plug, pin 4 Accessory Red + Ignition Switch, black 6 pin plug, pin 2 Second Accessory Black + Ignition Switch, black 6 pin plug, pin 6 Ignition Interrupt Pink/Black Cut I/P Junction Block, rear, black 56 pin plug (C), pin 42 Accessory Interrupt Orange/Black Cut I/P Junction Block, rear, gray 56 pin plug (D), pin 26 Keysense Blue - Key Switch, white 6 pin plug, pin 4 CAN Bus High Red (C-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 6 CAN Bus Low Blue (C-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 14 CAN Bus High 2 Orange (B-CAN) Data Junction Connector left of I/P Junction Block, green 20 pin plug, pin 19 CAN Bus Low 2 Green (B-CAN) Data Junction Connector left of I/P Junction Block, green 20 pin plug, pin 9 CAN Bus High 3 Red (C-CAN) Data Junction Connector left of I/P Junction Block, green 20 pin plug, pin 11 CAN Bus Low 3 Blue (C-CAN) Data Junction Connector left of I/P Junction Block, green 20 pin plug, pin 1 OBD 12 Volts Red (10A) + OBD-Data Link Connector, black 16 pin plug, pin 16 OBD Ground Black - OBD-Data Link Connector, black 16 pin plug, pin 4 OBD Connector Black Under Driver Dash, Behind Fuse/OBD Cover IMMO Data Blue/Black (EMS COM) Data Driver Kick, black 82 pin plug (EM11), pin 9 K Line White Data OBD-Data Link Connector, black 16 pin plug, pin 12 Power Lock White - Driver Kick, black 48 pin plug (MF11), pin 39 Power Unlock Green - Driver Kick, black 48 pin plug (MF11), pin 26 Power Unlock - Driver Door White - I/P Junction Block, rear, gray 56 pin plug (D), pin 5 Lock Motor Gray Reverse I/P Junction Block, black 68 pin plug (B), pin 55 Driver Unlock Motor Brown Reverse I/P Junction Block, black 68 pin plug (B), pin 15 or 41 Passenger Unlock Motor Brown Reverse I/P Junction Block, black 68 pin plug (B), pin 42 Factory Alarm Arm Pink - Driver Kick, black 48 pin plug (MF11), pin 9 Factory Alarm Disarm Orange Double - Driver Kick, black 48 pin plug (MF11), pin 22 Lock Detection Blue Open Driver Kick, black 48 pin plug (MF11), pin 4 Unlock Detection (same as lock detection) - Parking Lights Green/Black (L); Brown (R) + I/P Junction Block, black 68 pin plug (B), pin 37 (L); pin 36 (R) Parking Lights - Green - 1680 Ohms Headlight-Wiper Switch, black 16 pin plug, pin 14 Parking Lights MUX Green MUX Headlight-Wiper Switch, black 16 pin plug, pin 14 Hazards Brown - A/C Control Module, white 32 pin plug, pin 22 (manual A/C); white 40 pin plug, pin 33 (auto A/C) Turn Signal (Left) Orange (LF); Green (LR) + I/P Junction Block, gray 54 pin plug (A), pin 17 (LF); Driver Kick, black 48 pin plug (MF11), pin 15 (LR) Turn Signal (Right) Blue (RF); Gray (RR) + I/P Junction Block, gray 54 pin plug (A), pin 3 (RF); Passenger Kick, white 24 pin plug (MF21), pin 5 (RR) Headlight Yellow - Headlight-Wiper Switch, black 16 pin plug, pin 15 AutoLights Green Cut Headlight-Wiper Switch, black 16 pin plug, pin 14 Reverse Light Green + Driver Kick, black 82 pin plug (EM11), pin 13 Left Front Door Trigger Brown - Driver Kick, black 48 pin plug (MF11), pin 10 Right Front Door Trigger White - Passenger Kick, white 24 pin plug (MF21), pin 6 Left Rear Door Trigger Red - Driver Kick, black 48 pin plug (MF11), pin 46 Right Rear Door Trigger Brown - Passenger Kick, white 24 pin plug (MF21), pin 7 Dome Light Pink/Black, Pink, or Orange/Black - Left Front Pillar, white 24 pin plug, pin 3 Trunk/Hatch Pin Green - Driver Kick, black 48 pin plug (MF11), pin 47 Hood Pin Yellow - Driver Kick, black 82 pin plug (EM11), pin 54 Trunk/Hatch Release Brown (rear handle switch) - Driver Kick, black 48 pin plug (MF11), pin 11 Trunk Release Motor Brown + I/P Junction Block, black 68 pin plug (B), pin 2 Tachometer Blue or Gray/Black AC Camshaft Position Sensor, driver side of engine, black 3 pin plug, pin 2 Clutch Pedal Pink - Clutch Switch, black 4 pin plug, pin 3 Fuel Pump Orange + Above Driver Kick, white 24 pin plug (EF11), pin 1 Rear Defroster Yellow - Latched I/P Junction Block, rear, gray 56 pin plug (D), pin 12 Mirror Defroster (same as rear defroster) Left Front Heated Seat Yellow - Center Dash Switch, white 24 pin plug, pin 19 or white 16 pin plug, pin 6 Right Front Heated Seat Pink - Center Dash Switch, white 24 pin plug, pin 4 or white 16 pin plug, pin 3 Heated Steering Wheel Yellow - Center Dash Switch, white 16 pin plug, pin 10 Speed Sense Pink/Black AC Radio, white 35 pin plug, pin 18 or white 38 pin plug, pin 38 Brake Wire Pink/Black + Brake Switch, black 6 pin plug, pin 5 Parking Brake Pink - I/P Junction Block, black 68 pin plug (B), pin 25 Horn Trigger Blue - Driver Kick, black 82 pin plug (EM11), pin 17 Horn - Factory Alarm Gray - Driver Kick, black 82 pin plug (EM11), pin 24 Wipers Pink + Driver Kick, black 82 pin plug (EM11), pin 28 Left Front Window (Up/Down) Orange - Green (auto down); (auto up/down, motor is part of module) A Power Window Main Switch, white 18 pin plug, pins 1 - 2 Right Front Window (Up/Down) White - Brown A Driver Kick, door harness, black 54 pin plug, pins 15 - 14 Left Rear Window (Up/Down) Brown - White A Driver Kick, door harness, black 54 pin plug, pins 29 - 41 Right Rear Window (Up/Down) Green - Blue A Driver Kick, door harness, black 54 pin plug, pins 42 - 43 Sun Roof (Open/Close) Brown and Orange (open) (functions with ignition on only) Both - Overhead Console, white 8 pin plug, pins 5, 6 Sun Roof (Limit/Close) Orange and Gray (close) (functions with ignition on only) Both - Overhead Console, white 8 pin plug, pins 6, 7 Radio 12V Red + Radio, white 35 pin plug, pins 10, 11 Radio Ground Black - Radio, white 35 pin plug, pins 12, 13 Radio Ignition Orange + Radio, white 35 pin plug, pin 22 Radio Illumination Yellow (parking lights); Gray (dimmer) +,- Radio, white 35 pin plug, pin 6 (parking lights); pin 19 (dimmer) Power Antenna Blue/Orange or Red/Orange + Radio, white 35 pin plug, pin 5 Left Front Speaker (+/-) White - Brown +,- Radio, white 38 pin plug, pins 13 - 14 Right Front Speaker (+/-) Black - Yellow +,- Radio, white 38 pin plug, pins 16 - 15 Left Rear Speaker (+/-) Red - Blue +,- Radio, white 38 pin plug, pins 1 - 2 Right Rear Speaker (+/-) Green - Orange +,- Radio, white 38 pin plug, pins 28 - 27 Aux. Audio Input Left (+/-) Green - Black/Orange +,- Radio, white 38 pin plug, pins 24 - 25 Aux. Audio Input Right (+/-) White - Black/Orange +,- Radio, white 38 pin plug, pins 10 - 25 Rearview Camera Video Green - White +,- Radio, white 38 pin plug, pins 7 - 21 ------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!! |
