Stock Stereo Wiring Diagram, 2012 Chevrolet Malibu LT 2.4L ECO
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147337
Printed Date: May 29, 2024 at 1:17 AM
Topic: Stock Stereo Wiring Diagram, 2012 Chevrolet Malibu LT 2.4L ECO
Posted By: brentxiii
Subject: Stock Stereo Wiring Diagram, 2012 Chevrolet Malibu LT 2.4L ECO
Date Posted: May 01, 2022 at 1:33 PM
Trying to install aftermarket unit in car and the old one factory was cut out. Ive replaced all fuses ive found to be blown, wited the speakers up, bit im struggling getting power to the unit, my multimeter isnt reading anywhere for an ignition wire either. Im just stressed about this ishh. If anyone has a diagram or could tell me if all 7th gen malibus are wired the same, its also not a bose/amplified system. Thanks!🥺
------------- B.E.Harris
Posted By: geepherder
Date Posted: May 01, 2022 at 4:09 PM
Accessory power is not supplied in the factory harness. Some adapter modules will provide you with an accessory. If you don't want to spend that much money, you can run a wire from the ignition harness brown or check the fuse box.
------------- My ex once told me I have a perfect face for radio.
Date Posted: May 01, 2022 at 10:06 PM
Thanks, so i guess my next question is, how do i get it powered up, all i have to do is connect the constant and the ground, along with my speakers? I could post a picture of what i have going on if need be,but it wont be till tomorrow after 6pm.
Posted By: i am an idiot
Date Posted: May 01, 2022 at 10:18 PM
Radio 12V red/white + radio, black 14 pin plug, pin 1
Radio Ground black/white - radio, black 14 pin plug, pin 8
Radio Ignition (low speed GMLAN)
Radio Illumination (low speed GMLAN)
Factory Amp Turn-on same as power antenna
Power Antenna pink + radio, black 16 pin plug, pin 3
Left Front Speaker (+/-) tan - gray or tan - dk. green +,- radio, black 14 pin plug, pins 7 and 6 Notes
Right Front Speaker (+/-) lt. green - dk. green or lt. green/wht - lt. green +,- radio, black 14 pin plug, pins 5 and 4 Notes
Left Rear Speaker (+/-) brown - yellow or brown/white - brown +,- radio, black 16 pin plug, pins 6 and 7 Notes
Right Rear Speaker (+/-) dk. blue - lt. blue or dk. blue - tan +,- radio, black 16 pin plug, pins 4 and 5 Notes
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
