Reverse Wire, Backup Camera, 2015 Hyundai Santa Fe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147725
Printed Date: May 15, 2024 at 4:15 AM
Topic: Reverse Wire, Backup Camera, 2015 Hyundai Santa Fe
Posted By: garrys
Subject: Reverse Wire, Backup Camera, 2015 Hyundai Santa Fe
Date Posted: August 13, 2023 at 12:49 PM
I am installing an aftermarket stereo in my 2015 Hyundai Santa Fe, and I cannot get the backup camera to trigger when I shift into reverse. I have purchased the 3 harnesses I need to simplify the job, including the Axxess harness to retain the factory camera. I’m obviously missing a wire somewhere. Any insights are appreciated.
Posted By: cpalmer
Date Posted: August 13, 2023 at 3:10 PM
Are you using the AXDIS-HK1?
Posted By: garrys
Date Posted: August 13, 2023 at 4:10 PM
I am using the Axxess AXBUCH6V-HK2, which fits the one connector coming out of the vehicle’s dash. For the power and speaker harnesses, I bought Red Wolf, which are perfect. The stereo with Carplay etc work fine. I believe I have the 6volt converter connected correctly. I’m just missing something with the backup camera.
Posted By: cpalmer
Date Posted: August 13, 2023 at 5:31 PM
Sounds like your missing the wire that will trigger the radio to know the car is in reverse. Not familier with Red Wolf but there should be a trigger wire on the radio that needs to be connected to the reverse trigger wire in the car. Anything like that on the radio?
Posted By: garrys
Date Posted: August 14, 2023 at 7:01 AM
I have one brown wire connected to the 6v adapter. But I’m thinking there’s another reverse wire needed, perhaps from the HK2 harness?
Posted By: cpalmer
Date Posted: August 14, 2023 at 4:27 PM
Brown from the stereo? you need a wire from the car that goes positive when in reverse.
Posted By: garrys
Date Posted: August 14, 2023 at 5:13 PM
I have the (brown) radio reverse wire, which is connected to the blue/white wire of the 6v converter. What needs to also connect there is the VEHICLE’s reverse wire…that’s what I can’t locate. I’ve tried the multimeter…there is power to the stereo (which I already knew because the stereo works). I can’t however verify any power to the HK2 harness, either because there is none or because I can’t get the tips of the multimeter into the harness wiring. My plan was to find the wire that changes when I shift into reverse and use that one. So I am stuck.
Posted By: garrys
Date Posted: August 14, 2023 at 7:26 PM
I had an opportunity to tinker around today (the vehicle in question is my son’s and we basically function on opposite schedules, so I get these occasional chances to work on it). I found a wiring error in the power harness, and I can now get the camera to turn on (which I was previously unable to do). But it’s on continuously. So I still need the reverse trigger wire. Not sure if this helps but at least it’s a bit of progress. Thanks for any suggestions.
Posted By: cpalmer
Date Posted: August 14, 2023 at 7:56 PM
should be a 12 pin plug that you are getting video signal from , in there is a Red w/ black stripe wire ( at least on the vehicle side not sure what color the Axxess harness makes it). This wire should go on and off with the vehicle reverse lights
Posted By: garrys
Date Posted: August 14, 2023 at 8:14 PM
I’ve seen the black/red wire on the Hyundai wiring. Should I tap into that? I was hoping to avoid that by using the Axxess harness. Thanks for your help by the way…much appreciated.
Posted By: cpalmer
Date Posted: August 15, 2023 at 7:34 AM
I think you need to tap into it, brown from the stereo to the red / black should getting the screen to change when the car is in reverse. Then the Blue/white from the axxess harness (camera power) to the red accessory wire.
Posted By: garrys
Date Posted: August 20, 2023 at 9:30 AM
So I did finally get it working. It was the black/red wire from the vehicle’s wiring. As I mentioned, I had purchased an Axxess harness to retain the factory camera. So I traced which harness wire corresponded to the black/red Hyundai wire, tapped into that, joined it with the radio’s reverse wire and the 12volt-to-6volt converter wire and…it worked! Thanks for your help!
