2003 Oldsmobile Alero wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21067
Printed Date: May 03, 2024 at 11:58 PM
Topic: 2003 Oldsmobile Alero wiring diagram
Posted By: thepencil
Subject: 2003 Oldsmobile Alero wiring diagram
Date Posted: November 05, 2003 at 10:41 PM
Thanks in advance guys.
------------- Be careful whose advice you buy, but be patient with those who supply it.;)
Posted By: NowYaKnow
Date Posted: November 06, 2003 at 7:16 PM
Here's the basics..Same as a grand am if you've done one of those..Let me know if you need any other info.
Driver underdash. Harness going into firewall. (If there's two harnesses running parallel to each other they will be in the harness that is higher up)
Constant: Red (+)
Ignition: Pink (+)
Starter: Yellow (+)
Heat/AC: Orange (+)
Horn: Black (-)
Parking Lights: Brown (+)
Ignition Switch. Remove radio to access
Ignition 2: Dark Green
Passlock 2: Yellow and Black Wires
Driver Kick: Harness Coming In From Driver Door Boot
Trunk Release: BLACK/ White (-)
Lock/Unlock: White (-) (Negative pulse to lock, unlock needs a 1,500 ohm resistor)
Dome Sup: GREEN/ Black (-)
Door Trigger 1: GREEN/ Black (-)
Pass Kick: Harness Coming In From Driver Door Boot
Door Trigger 2: Light Blue (-)
Other
Tach: White @ Coil pack
Brake: L. Blue (+) @ Brake Switch
