I'm looking to find a wiring diagram for a remote start in a 2001 bonneville. If it's the same as the 2000, let me know.
Thanks,
-David
Yes, same as the 2000, as far as I can tell
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|orange or orn/blk *1|+ |ignition harness |
| STARTER|purple or yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|RED / black |- |drivers door lock switch |
| POWER UNLOCK|ORANGE / black |- |drivers door lock switch |
| LOCK MOTOR|gray | |drivers door module *2 |
| UNLOCK MOTOR|tan | |drivers door module *2 |
| DISARM DEFEAT|tan | |passenger door module *3 |
| PARKING LIGHTS +|do not use | | |
| PARKING LIGHTS -|BROWN / white | |DIM module *4 |
| HEADLIGHTS|white |- |DIM module *4 |
| DOOR TRIGGER|*5 |- |*5 |
| DOME SUPERVISION|gray |- |underdash light |
| TRUNK/HATCH PIN|RED / black |- |RIM module *6 |
|TRNK/HTCH RELEASE|lt. blue |- |RIM module *6 |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM|lt. green |- |drivers door module *2 |
| DISARM NO UNLOCK| | | |
| TACHOMETER|PURPLE / white | |ign. coil on top of motor |
| SPEED SENSE|dk. GREEN / WHITE | |cruise control module *7 |
| BRAKE WIRE|white |+ |low in drivers kick |
| HORN TRIGGER|black |- |DIM module *4 |
| WIPERS|white |+ |DIM module *4 |
| LF WINDOW UP/DN|dk. blue - brown |A |drivers door module *2 |
| RF WINDOW UP/DN|dk. blue - brown |A |passenger door module *3 |
| LR WINDOW UP/DN|dk. blue - brown |A |LR door module |
| RR WINDOW UP/DN|dk. blue - brown |A |RR door module |
| SUN RF OPN/CLOSE|dk. grn - lt. grn |A |sunroof motor *8 |
| SUN ROOF LIMIT|red |- |sunroof motor *8 |
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO ILLUMINATE|yellow/black |*9 |radio |
Notes:
NOTE: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555G or 555U to bypass. *1 This is a low current 12V source that should not be used to drive any high current positive circuits. *2 The drivers door module is located above the speaker in the drivers door. *3 The passengers door module is located above the speaker in the passenger door. *4 The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module. *5 The drivers door trigger wire is tan at the drivers door module, and the other door triggers are dk. blue at there respective door modules. *6 The RIM module is located behind the rear seat in the upper corner on the driver side. *7 The cruise control module is located under the hood at the top center of the firewall. *8 The sunroof motor is located to the rear of the sunroof towards the top center of the rear window. *9 Power varies with the interior light volume.
