2003 Nissan Mirano remote start/keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24433
Printed Date: May 17, 2024 at 8:57 PM
Topic: 2003 Nissan Mirano remote start/keyless
Posted By: autocustumz
Subject: 2003 Nissan Mirano remote start/keyless
Date Posted: January 12, 2004 at 4:20 PM
Anybody know where i can get wiring diagram for remote start and keyless entry? Any help will be much appreciated!!!!!
Posted By: boomer_106
Date Posted: January 12, 2004 at 11:21 PM
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | BLACK/ Red & Black Yellow | Ignition switch harness** | Ignition #1: | | BLACK/ Red (+) | Ignition switch harness* | Ignition #2: | | N/A | Ignition switch harness | Ignition #3: | | N/A | Ignition switch harness | Accessory: | | WHITE/ Blue (+) | Ignition switch harness | Brake Light: | | RED / Green (+) | Brake pedal switch | Tach Signal: | | | | Parking Lights: | | RED / Blue (+) | Drivers kick panel to the rear | Headlights: | | | | OEM Alarm Disarm: | | N/A | | OEM Alarm Arm: | | N/A | | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | | | Notes: | | *This vehicle may be equipped with a Transponder Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **This vehicle is equipped with two start wires. Both must be powered in order for vehicle to start when engine is cold. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | Green (+) | Ignition switch harness | Starter Kill: | | BLACK/ Red & Black Yellow | Ignition switch harness** | Ignition +12 Volts: | | BLACK/ Red (+) | Ignition switch harness* | Dome Lights/Superv: | | Comes on with unlock | | OEM Horn: | | GREEN/ Orange (-) | Steering column harness | Power Lock: | | Blue (-) | Drivers door module in door*** | Power Unlock: | | Red (-) | Drivers door module in door | Trunk Release: | | N/A | | Alarm Input Wire: | | Comes on with unlock | | Notes: | | ***See Note #201 Negative Trigger Door Locks |
Date Posted: January 13, 2004 at 4:25 PM
Thank you very much Boomer !!!!!
Date Posted: January 13, 2004 at 8:41 PM
Your Welcome Good luck
