04 chevy cavalier alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25118
Printed Date: April 28, 2024 at 10:26 AM
Topic: 04 chevy cavalier alarm/remote start
Posted By: toadabird04
Subject: 04 chevy cavalier alarm/remote start
Date Posted: January 23, 2004 at 12:33 AM
was just woundering if the wiring colors are the same as the 03 cavalier
Posted By: boomer_106
Date Posted: January 23, 2004 at 2:41 AM
Chevrolet | Cavalier | 2000-2004 |
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | YELLOW (+) | IGNITION SWITCH HARNESS | Ignition #1: | | PINK (+) | IGNITION SWITCH HARNESS* | Ignition #2: | | N/A | | Ignition #3: | | N/A | | Accessory: | | ORANGE (+) | IGNITION SWITCH HARNESS | Brake Light: | | WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | PURPLE / WHITE | ENGINE HARNESS NEXT TO THE BATTERY BELOW THE RADIATOR HOSE | Parking Lights: | | BROWN (+) | AT REAR OF LIGHT SWITCH OR DRIVER KICK PANEL | Headlights: | | | | OEM Alarm Disarm: | | DISARMS WHEN VEHICLE IS | STARTED EITHER BY THE KEY OR REMOTELY | OEM Alarm Arm: | | N/A | | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | | | Notes: | | *This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | RED | IGNITION SWITCH HARNESS | Starter Kill: | | YELLOW (+) | IGNITION SWITCH HARNESS | Ignition +12 Volts: | | PINK (+) | IGNITION SWITCH HARNESS* | Dome Lights/Superv: | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** | OEM Horn: | | BLACK (-) | STEERING COLUMN HARNESS | Power Lock: | | LT. BLUE | AT BCM UNDER LEFT SIDE OF DASH ** | Power Unlock: | | WHITE | AT BCM UNDER LEFT SIDE OF DASH ** | Trunk Release: | | BLACK/ WHITE (+) | AT BCM UNDER LEFT SIDE OF DASH**** | Alarm Input Wire: | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** | Notes: | | ** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram. *** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. Alternatively connect the alarm input wire to the domelight in the roof **** Use BLACK/ White for 2003 models. |
