1998 Contour
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25596
Printed Date: April 26, 2026 at 4:28 AM
Topic: 1998 Contour
Posted By: digitalsurge
Subject: 1998 Contour
Date Posted: January 30, 2004 at 9:59 PM
I am curious to know if anyone has been successful in installing a remote starter in a 1998 Ford Contour with the following chart.  I am most interested in knowing if the Tach wire is accurate.  Thx.
|              12V|red                 |+  |ignition harness            |
|          STARTER|gray/white          |+  |ignition harness            |
|         IGNITION|green               |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |+  |high in driver kick or *2   |
|     POWER UNLOCK|YELLOW /GREEN        |+  |high in driver kick or *2   |
|       LOCK MOTOR|WHITE/ purple        |   |keyless module *2           |
|     UNLOCK MOTOR|yellow/purple       |   |keyless module *2           |
|    DISARM DEFEAT|yellow/purple       |   |keyless module *2           |
| PARKING LIGHTS +|RED / blue, RED / yel   |   |headlight switch (L, R)     |
|       HEADLIGHTS|ORANGE / white        |+  |headlight switch            |
|     DOOR TRIGGER|wht/blk, wht/red    |-  |at fuse box *3              |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|black or blk/org    |-  |trunk light                 |
|         HOOD PIN|BLACK/ white         |-  |hood pin switch             |
|TRNK/HTCH RELEASE|ORANGE / green        |+  |release switch *2           |
|       TACHOMETER|WHITE/ black         |   |PCM pin 48 *1               |
|      SPEED SENSE|WHITE/ purple        |   |PCM pin 58 *1               |
|       BRAKE WIRE|orange / YELLOW       |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ blue          |-  |steering column             |
|           WIPERS|wht/grn(L),wht/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|white - yel/grn     |A  |drivers door switch         |
1 The PCM is behind the power steering reservoir. For tach can also use any BROWN / stripe at the coil pack.
Posted By: Teken
Date Posted: January 30, 2004 at 11:00 PM
Ford
Contour
1997-2000
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   GRAY/WHITE
IGNITION SWITCH HARNESS **
Ignition #1:
   GREEN
Ignition #2:
   N/A
Ignition #3:
   N/A
Accessory:
   YELLOW
Brake Light:
   ORANGE / YELLOW (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   WHITE/ BLACK
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
   RED / BLUE (+)
AT HEADLIGHT SWITCH
Headlights:
   ORANGE / WHITE (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
   N/A
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * Powertrain Control Module Located On Passenger Rear Of Engine. WHITE/ BLACK Tach Wire Also Located In 16 Pin Green Connector Next To Fuse Block Or In 42 Pin Connector On Driver Strut Tower.
** 1998 + This Vehicle May Be Equipped With Ford's PATS Anti-Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems.
Ford
Contour
1997-2000
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED
Starter Kill:
   GRAY/WHITE
Ignition +12 Volts:
   GREEN
Dome Lights/Superv:
   BLACK/ BLUE (-)
8 PIN CONNECTOR IN DR. KICK PANEL
OEM Horn:
   BLACK/ BLUE (-)
STEERING COLUMN HARNESS
Power Lock:
   WHITE/ GREEN
DRIVER'S KICK PANEL ***
Power Unlock:
   YELLOW /GREEN
Trunk Release:
   N/A
Alarm Input Wire:
   BLACK/ BLUE (-)
Notes:
*** See Note #202 - See Positive Pulse Door Lock Diagram, Must Use Relays!
Posted By: Teken
Date Posted: January 30, 2004 at 11:02 PM
FORD CONTOUR 1997-98     N/A
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED
IGNITION HARNESS
IGNITION 1        GREEN IGNITION HARNESS
IGNITION 2 NA
N/A
IGNITION 3 NA
NA
ACCESSORY /HEATER BLOWER 1   YELLOW IGNITION HARNESS
ACCESSORY /HEATER BLOWER 2        N/A N/A
STARTER   GRAY/WHITE IGNITION HARNESS
PARKING LIGHTS    RED / BLUE(+) AT HEADLIGHT SWITCH
DOMELIGHT   BLK/ BLUE(-) 8 PIN CONN. IN DRV.KICK PANEL
PWR DOOR LOCK WHITE/ GREEN DRV KICK PANEL
PWR DOOR UNLOCK YELLOW /GREEN DRV KICK PANEL (TYPE A)
TRUNK RELEASE        NA N/A
TACH SENSOR WHITE/ BLACK AT POWERTRAIN CONTROL MOD BEHIND POWER STEERING RES.
BRAKE
      ORANGE / YELLOW(+) AT SWITCH ABOVE BRAKE PED
HORN
BLACK/ BLUE(-)
STEERING COL HARNESS
FACTORY DISARM
NA
N/A
FACTORY ANTI-THEFT N/A TRANSPONDER (SOME)
