2003 Hyundai Santa Fe Alarm/Remote Start WIring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26142
Printed Date: April 24, 2026 at 8:13 PM
Topic: 2003 Hyundai Santa Fe Alarm/Remote Start WIring
Posted By: AAEgulfcoast
Subject: 2003 Hyundai Santa Fe Alarm/Remote Start WIring
Date Posted: February 09, 2004 at 12:53 PM
I need the wiring diagram for ahyundai santa fe 2003 for an alarm/remote start/keyless entry. I cannot find it on the website. Thanx guys.
Posted By: boomer_106
Date Posted: February 09, 2004 at 8:44 PM
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | Blue (+) | Ignition switch harness | Ignition #1: | | Blue (+) | Ignition switch harness | Ignition #2: | | Pink (+) | Ignition switch harness | Ignition #3: | | N/A | Ignition switch harness | Accessory: | | Green (+) | Ignition switch harness | Brake Light: | | GREEN/ Black (+) | Brake pedal switch | Tach Signal: | | Whie/Black or Blue (AC) | At the ECM* | Parking Lights: | | GREEN/ Orange (+) | At the fuse box in a 15 pin harness | Headlights: | | N/A | | OEM Alarm Disarm: | | Factory remote only | | OEM Alarm Arm: | | Factory remote only | | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | N/A | | Notes: | | *The ECM is under the center console to the right of the gas pedal. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | Red & Orange (+) | Ignition switch harness | Starter Kill: | | Blue (+) | Ignition switch harness | Ignition +12 Volts: | | Blue (+) | Ignition switch harness | Dome Lights/Superv: | | Yellow (-) | At fuse box in a 8 pin harness | OEM Horn: | | Brown (-) | Steering column harness | Power Lock: | | Yellow (-) | Drivers kick panel in a white harness** | Power Unlock: | | WHITE/ Black (-) | Drivers kick panel in a white harness | Trunk Release: | | N/A | | Alarm Input Wire: | | Yellow (-) | At fuse box in a 8 pin harness | Notes: | | **See Note #201 Negative Trigger Door Locks |
Date Posted: February 09, 2004 at 9:50 PM
Thank you very much.
Date Posted: February 10, 2004 at 11:02 PM
Your Welcome and thanks for showing your appreciation
