2003 Toyota Highlander
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26680
Printed Date: April 29, 2026 at 8:40 PM
Topic: 2003 Toyota Highlander
Posted By: IRNOTSLOW
Subject: 2003 Toyota Highlander
Date Posted: February 17, 2004 at 9:34 PM
Installing a remote starter in a 03 highlander, doeas any one know the diagram.  Also I am using the PKT by pass mod.  thanks
irnotslow
Posted By: boomer_106
Date Posted: February 19, 2004 at 12:45 PM
Toyota
Highlander
2003
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ White (+)
Ignition switch harness
Ignition #1:
Black (+)
Ignition switch harness*
Ignition #2:
BLACK / YELLOW (+)
Ignition #3:
red (Key Sense Wire)
Accessory:
Pink (+)
Brake Light:
GREEN / WHITE (+)
Brake pedal switch
Tach Signal:
WHITE/ Green (AC)
In harness at the ECM**
Parking Lights:
Green (+)
Drivers kick panel
Headlights:
N/A
OEM Alarm Disarm:
Use key sense wire
OEM Alarm Arm:
N/A
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
*This vehicle is equipped with a Transponder Anti-Theft security system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The Engine Control Module (ECM) is behind the glove box, it is the module to the left of the glove box. *** The key sense wire will measure 12 volts all the time till you place the key inside the ignition switch and the key sense wire will ground. Connect the WHITE/ black wire from the unit (ignition 3) to the wire and that will disarm the OEM factory alarm.
Toyota
Highlander
2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
White & Blue / YELLOW (+)
Starter Kill:
BLACK/ White (+)
Ignition +12 Volts:
Black (+)
Dome Lights/Superv:
Comes on with unlock
OEM Horn:
WHITE/ Red (-)
Steering column harness
Power Lock:
See note below
Power Unlock:
See note below
Trunk Release:
N/A
Alarm Input Wire:
Notes:
***See Installation Note # 212 Modern Toyota Door Locks Diagram.
Posted By: markcars
Date Posted: March 06, 2004 at 7:54 AM
Hey Irnotslow, did your highlander have a transponder in the keys? Just curious since I did not have one. I did not get the base model so I am wondering why and want to know a little more before asking my dealer.
How did your install go?
Date Posted: March 06, 2004 at 8:39 AM
markcars,
the install went very well. the key head is a little thicker than most heads. Also if you remove the steering colum clam shell. folow the lock cynlinder from the light ring to the floor. you shoud see a yellow sticker, below that is a harness ( my plug was black) with about 5-7 wires sid by side. If unplus them and then try to start you car it should not start. it will however turn over.  These wire are also used for the transponder by-pass. You will also ned to conect the key-sense wire, it is on a 4 or two wire harnes near the cylinder. it is the OLNY wire that wil show 12 or less volts with the key OUT, when you insert the key it wil show 0
irnotslow
Posted By: markcars
Date Posted: March 08, 2004 at 11:33 AM
How did you do the door locks? And the door-lock detection? I am still not complete with my install.
Also did you have 2 ignition outputs from your RS or just 1? I have 1 and need to make 2 now. I guess more fun next weekend!
