Looking for wiring info and speaker information. Very hard to find anything. Looking to install an alarm and stereo. Any ideas are welcome.
Dont know about the stereo but, this should take care of the alarm.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | BLACK | IGNITION SWITCH HARNESS |
Ignition #1: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #2: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | BLUE/RED | IGNITION SWITCH HARNESS |
Brake Light: | | GREEN / WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | BLACK | AT IGNITER ON PASSENGER WHEELWELL * |
Parking Lights: | | GREEN (+) | # PIN GRAY CONN. AT FUSE BLOCK ** |
Headlights: | | RED / BLUE (-) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | N/A | IN SCHEAMTICS |
OEM Alarm Arm: | | N/A | NO OEM ALARM PRESENT |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * BLACK Tach Wire Also Located In 26 Pin Connector Behind Glove Box. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE/ RED & WHITE | IGNITION SWITCH HARNESS |
Starter Kill: | | BLACK | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | BLACK/ WHITE (-) | 2 PIN GRAY CONN. AT FUSE BLOCK ** |
OEM Horn: | | GREEN/ RED (-) | STEERING COLUMN HARNESS |
Power Lock: | | RED / WHITE | # PIN CONN. IN DRIVER'S KICK *** |
Power Unlock: | | RED / YELLOW | # PIN CONN. IN DRIVER'S KICK *** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | BLACK/ WHITE (-) | 2 PIN GRAY CONN. AT FUSE BLOCK ** |
Notes: | | ** Fuse Block Located In Driver Kick Panel. *** Child Safety Locks: RED / BLUE (-) In Same Connector As Door Lock Wires Above. See Note #209 - Toyota Child Safety Door Lock Diagram. |
