radiator fans on buick regal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29079
Printed Date: January 30, 2026 at 10:19 PM
Topic: radiator fans on buick regal
Posted By: Akeener
Subject: radiator fans on buick regal
Date Posted: March 26, 2004 at 6:03 PM
I just bought a used car and I noticed it had dual radiator fans.  What I realized is that only one fan is running. At first, I didnt know why.  Then I thought maybe it was a secondary fan that doesnt turn on until the engine gets to a higher temperature.  Can anyone shed some light on the subject? I am a bit concerned.   Thanks so much.
Adam
Posted By: chriswallace187
Date Posted: March 26, 2004 at 11:47 PM
The secondary fan sometimes will only run when the a/c is on, or sometimes when the engine temp gets above a certain point. It's nothing to worry about in any case, as long as your primary fan works and the car doesn't overheat, but usually the secondary fans on GMs work just with the a/c.
Posted By: SOUND PRESSURE
Date Posted: March 27, 2004 at 4:20 AM
That secondary fan is for the a/c unit as soon as you kick it on the fan should start with it. Chris is correct.
Sound Pressure
Posted By: Akeener
Date Posted: March 27, 2004 at 7:54 AM
Thank you. I was hoping it was ok. I appreciate your help
Adam
Date Posted: March 28, 2004 at 11:44 PM
No problem, glad to help.
Sound Pressure
