1995 Saturn SC1 Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29233
Printed Date: January 30, 2026 at 3:44 AM
Topic: 1995 Saturn SC1 Wiring Diagram
Posted By: jklint
Subject: 1995 Saturn SC1 Wiring Diagram
Date Posted: March 29, 2004 at 6:39 AM
I recently bought a Commando central locking actuators and keyless entry to convert my no powered Saturn doors into power locking doors w/ keyless entry. I have everything hooked up and working except I dont know where to hook the horn/parking light outputs to. I'm sure there in the console or under the dash but I don't have a clue to which wires they would be. Any help?
Posted By: rudbwoy69camaro
Date Posted: March 29, 2004 at 6:28 PM
1995 Saturn sedan, coupe
ItemWire ColorPolarityWire Location
12VRED / wht, RED / lt. grn+ignition harness or *1
STARTERyellow+ignition harness or *2
IGNITIONpink+ignition harness or *1
ACCESSORYorange+ignition harness or *1
SECOND ACCESSORY
TACHOMETERPURPLE / whiteDIS module dr.firewall
POWER LOCKlt. blue+either kick harness to rear
POWER UNLOCKwhite+either kick harness to rear
PARKING LIGHTS +brownrear of fuse box or *1
PARKING LIGHTS -
DOOR TRIGGERwhite-base of 'B' pillar *3
HEADLIGHTSblue *4-light switch
WIPERS
LF WINDOW UP/DNdk. blue - brownAat master switch
RF WINDOW UP/DNdk. blu/wht - tanAat master switch
LR WINDOW UP/DNdk. grn - purAat master switch
RR WINDOW UP/DNlt. grn - pur/whtAat master switch
TRUNK/HATCH PINlt. green+at light in trunk
HOOD PINnone
TRUNK/HATCH RELEASE
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERblack-steering column
BRAKE WIRElt. blue+brake pedal switch
LOCK MOTORnonenonnone
UNLOCK MOTORnonenonnone
DISARM DEFEATnonenonnone
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:*1 Fuse boxes located in console and under hood. Wire colors and pin #s are as follows: RED / white constant - console pin F6. Pink ignition - console pin D8. Orange accessory 2 - console pin A6. Brown park lights - console pin F5. Purple (or yellow) starter - underhood pins F6, A2. *2 Can also be found purple at the clutch switch. *3 Also found in taped up harness under ashtray - one of three white wires - test to identify. *4 High-current ground for lo beam.
Posted By: jklint
Date Posted: March 29, 2004 at 7:32 PM
Well I'll give it a try and see what I can do. I appreciate the info.
