Help need wiring diagram for two trucks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29420
Printed Date: January 30, 2026 at 11:48 AM
Topic: Help need wiring diagram for two trucks
Posted By: jbla3478
Subject: Help need wiring diagram for two trucks
Date Posted: March 31, 2004 at 5:38 PM
I need it for 2002 Ford Ranger and a 2003 Chevy s-10
Josh Blackwell
Nothing But Style Car Audio
Posted By: rudbwoy69camaro
Date Posted: April 03, 2004 at 9:36 AM
2003 Chevrolet S-10 Pickup
ItemWire ColorPolarityWire Location
12Vred+ignition harness
STARTERyellow+ignition harness
IGNITIONpink+ignition harness
ACCESSORYorange+ignition harness
SECOND ACCESSORYwhite+ignition harness
TACHOMETERwhitePCM *3
POWER LOCKlt. blue+brown plug at BCM *1
POWER UNLOCKwhite+brown plug at BCM *1
PARKING LIGHTS +brownlt. blue plug at BCM *1
PARKING LIGHTS -white *4lt. blue plug at BCM *1
DOOR TRIGGER*2-BCM *1
HEADLIGHTSPURPLE / white-purple plug at BCM *1
WIPERSnone
LF WINDOW UP/DNblue - brownAdriver window switch
RF WINDOW UP/DNlt. blue - tanAdriver kick, door harness
LR WINDOW UP/DNgreen - purpleAdriver kick, door harness
RR WINDOW UP/DNlt. green - purpleAdriver kick, door harness
TRUNK/HATCH PINnone
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMlt.green-purple plug at BCM *1
HORN TRIGGERblack-steering column *5
BRAKE WIREwhite+steering column
LOCK MOTORgraydrivers kick panel
UNLOCK MOTORtandrivers kick panel
DISARM DEFEATtanpassengers kick panel
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side. *2 Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, must diode isolate these wires. *3 The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20. *4 This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground. *5 Also found in the brown plug at the BCM on vehicles with a factory alarm.
2002 Ford Ranger
12Vyellow+ignition harness
STARTERRED / lt. blue+ignition harness
IGNITIONlt. GREEN/ purple+ignition harness
ACCESSORYgray / YELLOW+ignition harness
SECOND ACCESSORYnone
TACHOMETERtan / YELLOWinstrument cluster or PCM *3
POWER LOCKpink / YELLOW-driver door harness or PKP
POWER UNLOCKpink/lt. green *4-driver door harness or PKP
PARKING LIGHTS +brownheadlight switch or GEM *1
PARKING LIGHTS -none
DOOR TRIGGER*2-GEM *1
HEADLIGHTSRED / yellow+headlight switch
WIPERSwht (L), blu/org (H)+windshield wiper motor
LF WINDOW UP/DNwht/blk - redAdriver window motor
RF WINDOW UP/DNwht/yel - tan/lt bluAdriver door harness or PKP
LR WINDOW UP/DNnone
RR WINDOW UP/DNnone
TRUNK/HATCH PINnone
HOOD PINnone
FACTORY ALARM ARM
HORN TRIGGERyellow/lt. green-steering column
BRAKE WIRElt. green+brake pedal switch
LOCK MOTORpink/blackdriver door harness
UNLOCK MOTORRED / orangedriver door harness
DISARM DEFEATpink/orangepassenger kick panel
DOME SUPERVISIONuse door trigger
SPEED SENSEgray/blackGEM *1
SUN ROOF LIMITnone
LF SPEAKERorg/lt grn-lt blu/whradio
RF SPEAKERwht/lt grn - grn/orgradio
LR SPEAKERgry/lt blu - tan/yelradio
RR SPEAKERorg/red - brn/pnkradio
RADIO 12Vlt. GREEN/ purple+radio
RADIO GROUNDblack-radio
RADIO SWITCHyellow/black+radio
RADIO ILLUMINATElt. blue/red(dimmer)+radio
POWER ANTENNAnone
Notes:NOTE: This vehicle is equipped with PATS (Passive Anti-Theft System). Use DEI module 555U to over-ride during remote start. *1 The GEM (Generic Electronic Module) is to the left of the radio. *2 The driver door trigger is yellow/black and the passenger door(s) is gray/red. Use both wires and diode isolate as shown in directfax document #1076. *3 The PCM (Powertrain Control Module) is on the top of the firewall under the hood towards the passenger side. The tachometer wire is in pin 48. Can also get tach at the ignition coil or coil pack. Use any of the tan/stripe wires. *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1093.
