2004 Dodge Caravan Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32051
Printed Date: April 28, 2024 at 3:02 AM
Topic: 2004 Dodge Caravan Alarm/Remote Start Wiring
Posted By: Xakasohx
Subject: 2004 Dodge Caravan Alarm/Remote Start Wiring
Date Posted: May 12, 2004 at 3:38 PM
Can anyone please send over the correct wiring guide for a Dodge Caravan? Need it ASAP!
------------- Holla Back!!
Posted By: Autoobsession
Date Posted: May 12, 2004 at 7:33 PM
12volts | lt. blue/red (10A) | + | ignition harness | Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to the battery for 12v. | Starter | yellow | + | ignition harness | Second Starter | PURPLE / brown | - | ignition harness | Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information. | Ignition | pink/white | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | not required for remote start | | | Second Accessory | N/A | | | Keysense | | | | Power Lock | PURPLE / green | - | conn. 3, pin 21 @ BCM | Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Power Unlock | same wire as power lock | | | Lock Motor | tan/white | | conn. 2, pin 10 @ BCM | Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Unlock Motor | tan/lt. green | | conn. 2, pin 28 @ BCM | Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Parking Lights+ | DO NOT USE | | | Parking Lights- | WHITE/ brown | - | headlight switch | Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information. | Hazards | WHITE/ blue | - | conn. 5, pin 1 @ BCM | Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Turn Signal(L) | | | | Turn Signal(R) | | | | Reverse Light | WHITE/ lt. green | + | conn. 2, pin 9 @ BCM | Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Door Trigger | | - | conn. 3 @ BCM | Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Dome Supervision | use door trigger | | | Trunk/Hatch Pin | PURPLE / orange | - | conn. 3, pin 29 @ BCM | Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Hood Pin | PURPLE / lt. blue | - | conn. 3, pin 30 @ BCM | Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Trunk/Hatch Release | PURPLE / tan | - | conn. 2, pin 6 @ BCM | Notes: The hatch release is negative trigger thru a 1.69K ohm resistor. MUST use relay.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Power Sliding Door | PURPLE / blue | - | conn. 3, pin 1 @ BCM | Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Factory Alarm Arm | PURPLE / lt. blue | - | conn. 3, pin 14 @ BCM | Notes: Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. | Factory Alarm Disarm | same wire as alarm arm | | | Disarm No Unlock | | | | Tachometer | | ac | ignition coil pack | Notes: On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan, or blue/orange. | Wait to start | N/A | | | Brake Wire | WHITE/ tan | + | brake pedal switch | Parking Brake | | | | Horn Trigger | GREEN/ purple | - | steering column | Memory Seat 1 | | | | Memory Seat 2 | | | | Memory Seat 3 | | | | Immobilizer Bypass Module: | Required: Yes | Type: Sentry Key | Part #: 555C or 555U | Notes: Only vehicles with gray keys have the immobilizer. |
