I need a wiring diagram for 1997 Ford Taurus.
82609
| 12V|lt.grn/ppl or yellow|+ |ignition harness |
| STARTER|RED / lt. blue |+ |ignition harness |
| IGNITION|RED / lt. green |+ |ignition harness |
| SECOND IGNITION| | | |
| ACCESSORY|gry/yel & RED / blk |+ |ignition harness |
| SECOND ACCESSORY|BLACK/ lt green |+ |ignition harness |
| POWER LOCK|pink / YELLOW |- |drivers kick panel |
| POWER UNLOCK|pink/green |- |drivers kick panel |
| LOCK MOTOR|pink/black | |drivers kick panel |
| UNLOCK MOTOR|RED / white | |drivers kick panel |
| DISARM DEFEAT|pink/orange | |drivers kick panel |
| PARKING LIGHTS +|brown | |switch or fuse box |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|RED / yellow |+ |headlight switch |
| DOOR TRIGGER|BLACK/ lt. blue |+ |under dash light*1 |
| TRUNK/HATCH PIN|BLACK/ pink |- |at trunk light |
|TRNK/HTCH RELEASE|pnk/yel or gry/red |*2 |at release switch
|FCTRY ALRM DISARM|pink/white |- |drivers kick panel |
| TACHOMETER|yellow/white*4 | |at coil 2 cyl. setting |
| BRAKE WIRE|RED / lt. Green |+ |Brake switch or DKP |
| HORN TRIGGER|PURPLE / orange |- |*3 |
| WIPERS|wht , dk. blue/org |+ |wiper motor *5 |
| LF WINDOW UP/DN|blk/wht - tan/ltblue|A |drivers door at switch |
| RF WINDOW UP/DN|wht/yel - tan/ltblue|A |drivers kick panel |
| LR WINDOW UP/DN|yel/ltblu-gray/org |A |drivers kick panel |
| RR WINDOW UP/DN|yel/blk - RED / blk |A |drivers kick panel |
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti Theft System). *1 Also found lt. GREEN/ orange (-) at headlight switch. BLACK/ orange at GEM (instrument fuse panel) will get all doors and hatch on wagon. Rests at ground through ignition, cut and diode isolate. *2 There are 2 wires at the switch. If the switch has a pink / YELLOW and a gray/red use the pink / YELLOW as a negative trigger. If the swich has a gray/red and a purple / YELLOW, use gray/red as a positive trigger. *3 Four pin plug to right of steering column. *4 Coil & Harness behind intake manifold at back of engine compartment. *5 Also found at the fuse/relay box under hood.
