2003 Chevy Impala Alarm/Remote Start WIring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35534
Printed Date: May 05, 2024 at 12:23 PM
Topic: 2003 Chevy Impala Alarm/Remote Start WIring
Posted By: mike swanson
Subject: 2003 Chevy Impala Alarm/Remote Start WIring
Date Posted: July 13, 2004 at 2:27 PM
I need a wire diagram for 03 chevy impala. Im putting in a crime stopper keyless/remote start. You can leave it here or E-mail me @ transam79.2@juno.com
Thank You very much
Posted By: swamprat323
Date Posted: July 13, 2004 at 2:55 PM
Make:
Model:
Year:
Chevrolet
Impala
2003
Alarm
Function Color Location
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT COURTESY LIGHT
Trunk Pin Switch RED / BLACK (-) DRIVERS KICK PANEL
Parking Lamp BLUE (-) AT HEADLIGHT SWITCH*
Power Lock ORANGE / BLACK AT SWITCH IN** #217
Power Unlock SAME WIRE DRIVERS DOOR
* Must Use A Relay To Interupt Parking Light Wire ** Lock Requires A 480 Ohm Resistor #217 See Single Wire Resistor Door Lock Circuit
Information Courtesy Of Installer!! Any Additional Information Appreciated!!
Accessories
Window Up
Window Down
Ign Key Warn
Trunk Release BLACK AT TRUNK RELEASE SWITCH #230
OEM Horn
Headlights YELLOW (-) AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm
#230 See Negative Pulse Trunk Release Circuit Information Courtesy Of Installer!! Any Additional Information Appreciated!!
Remote Start
Tach Signal WHITE AT IGNITION COIL #238
Ignition #2 DARK GREEN IGNITION SWITCH HARNESS*
Ignition #3
Accessory ORANGE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Light LIGHT GREEN (+) IN HARNESS AT LIGHT
Rear Window Defrost
#238 See General Motors Passlock ll Diagram * Must Be Powered As A Ignition Or The Vehicle Will Not Crank. Information Courtesy Of Installer!!
InterConnect Harness
Function Part # Available Location
StrInt,+12,Gnd,Ign no
Horn Honk no
Lock & Unlock no
Light Flash no
Dome Light no
Trunk Switch no
AL-100 / VIP-4000 no
Remote Start no
