03 GMC Sierra Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36860
Printed Date: April 24, 2026 at 2:48 AM
Topic: 03 GMC Sierra Alarm/Remote Start Wiring
Posted By: sasha123
Subject: 03 GMC Sierra Alarm/Remote Start Wiring
Date Posted: August 05, 2004 at 9:09 PM
Hi I got a 03 gmc sierra and I purchased car alarm wirh remote starter and window rolldown and up functions can anyone give me any diagrams to install these properly Thanks
------------- alex
Posted By: raydawg357
Date Posted: August 06, 2004 at 9:59 AM
DIRECTWIRE™ WIRING INFORMATION - GMC / FULL SIZE PICKUP / 2003 / Remote Start[PRINT THIS PAGE]
| 12volts | red (x2) | + | ignition harness | | Starter | yellow | + | ignition harness | | Second Starter | N/A | | | | Ignition | pink | + | ignition harness | | Second Ignition | white | + | ignition harness | | Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system. | | Third Ignition | N/A | | | | Accessory | orange | + | ignition harness | | Second Accessory | brown | + | ignition harness | | Keysense | lt. green | - | ignition harness | | Power Lock | use Directed module 456G | | | | Notes: If Directed module 456G is not available, refer to DirectFax document 1601. On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM. | | Power Unlock | see power lock | | | | Lock Motor | gray | | driver door module in door | | Unlock Motor | tan | | driver door module in door | | Parking Lights+ | do not use | | | | Parking Lights- | gray/black | - | brn plug, pin B2 @ BCM | | Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. | | Hazards | white | - | steering column, 5 pin plug | | Turn Signal(L) | green | + | steering column, 5 pin plug | | Turn Signal(R) | lt. green | + | steering column, 5 pin plug | | Reverse Light | lt. green | + | blk plug, pin F @ BCM | | Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. | | Door Trigger | gry/blk (L), blk/wht (R) | - | each door module in door | Notes: On base model trucks the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. On 4dr trucks the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM. Use all wires and diode isolate.
The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. | | Dome Supervision | gray/black | + | BCM, black plug, pin E | | Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. | | Trunk/Hatch Pin | N/A | | | | Hood Pin | N/A | | | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | arms with lock | | | | Factory Alarm Disarm | lt. green | - | driver door module in door | | Disarm No Unlock | see factory alarm disarm | | | | Tachometer | white | ac | instrument cluster or PCM | Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown. | | Wait to start | blue | - | instrument cluster or PCM | | Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the green plug, pin 36. | | Brake Wire | white | + | brake pedal switch | | Parking Brake | lt. blue | - | lt. blu plug, pin A7 @ BCM | | Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back. | | Horn Trigger | BLACK / YELLOW to black | - | steering column | | Memory Seat 1 | red | + | driver door module in door | | Memory Seat 2 | pink | + | driver door module in door | | Memory Seat 3 | N/A | + | | | Immobilizer Bypass Module: | Required: Yes | Type: Passlock 2 | Part #: 555L or 555T | | Notes: The Passlock 2 wire colors are yellow, black, and RED / white (not used). |
------------- Do it right the first time
Posted By: dudek38
Date Posted: August 06, 2004 at 12:33 PM
raydawg, is that from a program "directwire"? please tell me more
------------- owner of
Motion Marine & Car Audio
the florida keys
Date Posted: August 06, 2004 at 12:45 PM
What more do you need to know. That wiring diagram will tell what wires from the alarm you need to connect to the truck's wire.
Posted By: dudek38
Date Posted: August 06, 2004 at 12:53 PM
im just wondering how to get that program, thats all.
the florida keys
Posted By: kgerry
Date Posted: August 06, 2004 at 1:02 PM
become an Authorized DEI dealer.... that's the classy way....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: forbidden
Date Posted: August 06, 2004 at 9:07 PM
Alex, if you are not familiar with remote start alarms, it is highly not recommended to do this yourself. You also have a GM theft deterrent bypass in this vehicle and failure to wire the ignition lines properly will result in nightmares. Most of the time people who post for this info are not in the industry, if you are, go to it. If you are not, consider getting it installed by a professional before damage is done to either the unit or the vehicle. Should you be intent on trying this yourself, do it one slow step at a time. Meaning get the alarm done first, then the remote start, then move onto the power locks, then do the power windows or however you prefer. You will probably have a ton of questions along the way and some of the guru's here on the site will be more than happy to help. As one of these guru's and a owner of a store as well, I can tell you that there is nothing worse than trying to fix a failed effort. Good luck with the install.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: sasha123
Date Posted: August 21, 2004 at 8:48 PM
please tell me how to insatall window module thanks
------------- alex
