2000 Toyota MR2 Spyder Alarm/RS/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3943
Printed Date: May 05, 2024 at 11:06 AM
Topic: 2000 Toyota MR2 Spyder Alarm/RS/Stereo Wiring
Posted By: MidEngine4Life
Subject: 2000 Toyota MR2 Spyder Alarm/RS/Stereo Wiring
Date Posted: September 24, 2002 at 11:07 PM
Does anyone have an alarm wiring diagram for the '00-Current Toyota MR2 Spyder?  If so, could you please post it up?  Thank you.
'01 Toyota MR2 Spyder
Posted By: Velocity Motors
Date Posted: September 25, 2002 at 7:47 AM
This is for the 2000 - 2002 MR-2 and the data base does not differentiate between the Spyder and the hard top coupe.
|              12V|wht/red & wht/blu   |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|RED / white           |+  |ignition harness            |
|        ACCESSORY|pink/blue           |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |drivers kick panel          |
|     POWER UNLOCK|blue / YELLOW *1      |-  |drivers kick panel          |
|       LOCK MOTOR|blue/red            |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/black          |   |drivers kick panel          |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|green               |   |drivers kick panel          |
| PARKING LIGHTS -|RED / white           |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|       TACHOMETER|white               |   |drivers running board       |
|      SPEED SENSE|PURPLE / white        |   |drivers running board       |
|       BRAKE WIRE|GREEN / WHITE         |+  |at brake switch             |
|     HORN TRIGGER|WHITE/ red           |-  |steering column             |
|           WIPERS|blu/blk & blu/red   |+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |drivers kick panel          |
|  RF WINDOW UP/DN|red - green         |A  |passengers kick panel       |
|        RADIO 12V|blue / YELLOW         |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|gray                |+  |radio                       |
| RADIO ILLUMINATE|green               |+  |radio                       |
|    POWER ANTENNA|black               |+  |radio                       |
|       LF SPEAKER|pink - purple       |   |radio or speaker            |
|       RF SPEAKER|green - blue        |   |radio or speaker            |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  Use DEI module 555F or 555U to bypass.  *1 Requires a double pulse for unlock.  Using the same color wire in the passengers kick only requires a single pulse.    *2 Drivers door is red or RED / white in the drivers kick panel.  Passenger door trigger is RED / white in the passenger kick panel.  Use both wires and diode isolate each.
Posted By: 8 Legs
Date Posted: September 25, 2002 at 4:53 PM
You can find both the door triggers at the ECM under the driver's side dash.
Date Posted: September 30, 2002 at 5:24 PM
Thank you so much Jeff!!!!!!!!!  The help is greatly appreciated!
-Mitch
Date Posted: September 30, 2002 at 9:49 PM
No problemo and good luck !!
