2004 GMC Sierra Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41042
Printed Date: May 09, 2024 at 1:00 PM
Topic: 2004 GMC Sierra Alarm/Remote Start Wiring
Posted By: josegon
Subject: 2004 GMC Sierra Alarm/Remote Start Wiring
Date Posted: October 17, 2004 at 12:07 AM
Iam trying to install a remote start/alarm on a 2004 GMC sierra. I need to get the wiring diagram. Could somebody provide some help locating the diagram as well as providing any tips. First time doing remote stater. I've done an alarm before. Thanks
Posted By: snguyen
Date Posted: October 17, 2004 at 12:20 AM
SIERRA PICK-UP F/S      2002-2004
WIRE COLORSLOCATION
12 VOLTS CONSTANTRED (x2)IGNITION SWITCH HARNESS
IGNITION 1PINK (+)IGNITION SWITCH HARNESS
IGNITION 2WHITE (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER ORANGE (+)IGNITION SWITCH HARNESS
STARTERYELLOW (+)IGNITION SWITCH HARNESS
KEY SENSELIGHT GREEN ( - )IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )GRAY/BLACK BROWN  PLUG pin B2 at BCM
DOME LIGHT  ( - )GRAY/BLACK (Drivers door), BLACK/ WHITE (Passengers door)EACH DOOR MODULE in DOOR *2
DOME LIGHT SUPERVISION USE DOMELIGHT WIRES
POWER DOOR LOCKLIGHT BLUE LIGHT BLUE PLUG at BCM *3
POWER DOOR UNLOCKWHITE   with FACTORY KEYLESS *SEE DIAGRAM*
TACH SENSORWHITE  (AC)INSTRUMENT CLUSTER or PCM  *4
BRAKEWHITE  ( + )AT BRAKE SWITCH
HORNBLACK  ( - ) or BLACK / YELLOWat STEERING COLUMN HARNESS
FACTORY DISARMLIGHT GREEN (-)DRIVER DOOR MODULE in DOOR
FACTORY ANTI-THEFTPASSLOCK 2Requires part #791 bypass
 NOTES:
UPDATE:  TAILGATE LOCKING SYSTEM:
GM Full-size trucks from 2003 and up have a Multiplex Door Locking System, this means the MOTOR wires WILL NOT be accessible in the interior kick panels. When installing a TAILGATE LOCK, the motor wires can only be found INSIDE the DRIVERS or PASSENGERS door at the motor.
*1 - The BCM is located behind the drivers side of the dash. It has (6) plugs on the BCM with the PURPLE plug on the back.
*2 - On BASE model trucks the door trigger wires are in the LIGHT BLUE plug at BCM, pins B4 Drivers door and A5 Passengers door. On 4 door trucks the Left Rear door trigger wire is LIGHT BLUE/BLACK, pin A3, the Right Rear door is LIGHT GREEN/ BLACK, pin A2. They are in the PURPLE plug at the BCM. Use all wires and diode isolate.
*3 - On BASE model trucks the lock wire is LIGHT BLUE ( - )  and  the unlock wire is WHITE ( - ). They are in the LIGHT BLUE plug at the BCM.
*4 - The PCM (Power Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the GREEN plug, pin 10. For tach you can also go to any of the ignition coils and use the wire that is NOT PINK, BLACK or BROWN.  Wait-to-Start wire is BLUE in instrument cluster or PCM.
Posted By: snguyen
Date Posted: October 17, 2004 at 12:21 AM
GMC
Sierra Pickup
2003-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
Yellow (+)
Ignition switch harness
Ignition  #1:
Pink (+)
Ignition switch harness*
Ignition #2:
White (+)
Ignition  #3:
N/A
Accessory:
Orange (+)
Brake  Light:
White (+)
Brake pedal switch
Tach  Signal:
White (AC)
Instrument cluster or PCM**
Parking Lights:
Gray/Black (-)
Brown plug at BCM***
Headlights:
OEM Alarm  Disarm:
Lt.Green (-)
Drivers door module in door
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 *This vehicle is equipped with GM's PASSLOCK II Anti-Theft System. Use Universal Alarm Bypass Module # 2x402 where X can be any number. You can also use vehicle specific bypass module part # 23545. **The Powertrain Control Module (PCM) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug in pin # 10. ***The Body Control Module (BCM) is under the driver side dash.
GMC
Sierra Pickup
2003-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Red (+)
Starter  Kill:
Yellow (+)
Ignition  +12 Volts:
Pink (+)
Dome  Lights/Superv:
OEM Horn:
BLACK / YELLOW (-)
Steering column harness
Power  Lock:
See Note
Power  Unlock:
See Note
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
****Use vehicle specific door lock module part # 23561. On base model trucks the lock wire is Lt.Blue(-) and unlock wire is white(-). They are in the Lt.Blue plug at the Body Control Module (BCM).
Posted By: josegon
Date Posted: October 21, 2004 at 8:58 PM
Thanks for the quick responce. I checked all wiring readings with a digital meter. On white wire from Ignition switch harness ad found out that the reading for ing 2 is actually orange wire wich has a 12+ at ON/RUN and 12+ at start. The question is if it should be used for Ignition switch harness instead of white wire wich has 12+ at Acc, 12 + at ON/RUN and 12+ at start. Another question is if this vehicle has the parking lights are ground swithched or a +12 volt swithched.
Thanks,
JG
Posted By: JWorm
Date Posted: October 21, 2004 at 9:05 PM
lights are negative....white needs to be powered as an ignition....and orange as accessory. Most wiring charts say the brown wire must also be connected as a second accessory, but I have found it is usually not needed.
Posted By: josegon
Date Posted: October 21, 2004 at 9:09 PM
Sorry for the confusion I guess I clicked the mouse I typed somewhere else. Here is the right wording...
Thanks for the quick response. I checked all wiring readings with a digital meter. On white wire from Ignition switch harness I found out that the reading for ing 2 is actually the orange wire which has a +12 at ON/RUN and +12 at start. The question is if the orange should be used for ing 2 instead of white wire which has +12 at Acc, +12 at ON/RUN and 12+ at start. Another question is if this vehicle has the parking lights ground switched or a +12 volt switched.
Thanks,
JG
Posted By: josegon
Date Posted: October 22, 2004 at 3:33 PM
Posted By: JWorm
Date Posted: October 22, 2004 at 7:51 PM
You can keep asking the question over and over but the answer is still the same. I already answered you a couple posts up. You are either metering something wrong, your meter reacts too slow to changes, or you don't understand the difference between ignition and accessory.
