2002 Impala LS Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4576
Printed Date: May 05, 2024 at 11:10 PM
Topic: 2002 Impala LS Alarm/Remote Start Wiring
Posted By: malucyk
Subject: 2002 Impala LS Alarm/Remote Start Wiring
Date Posted: October 17, 2002 at 7:07 PM
Wiring diagram requested for a 2002 Impala LS.
Matthew
Posted By: Velocity Motors
Date Posted: October 17, 2002 at 8:45 PM
|              12V|red                 |+  |ignition harness *1         |
|          STARTER|yellow              |+  |ignition harness *1         |
|         IGNITION|pink                |+  |ignition harness *1         |
|  SECOND IGNITION|green               |+  |ignition harness *1         |
|        ACCESSORY|orange              |+  |ignition harness *1         |
| SECOND ACCESSORY|brown *7            |+  |ignition harness *1         |
|       POWER LOCK|ORANGE / black        |*2 |gray 24-pin plug @ BCM *3   |
|     POWER UNLOCK|same wire as lock   |-  |gray 24-pin plug @ BCM *3   |
|       LOCK MOTOR|*4                  |   |                            |
|     UNLOCK MOTOR|*4                  |   |                            |
|    DISARM DEFEAT|*4                  |   |                            |
| PARKING LIGHTS +|do NOT use          |   |                            |
| PARKING LIGHTS -|white *8            |   |pink 24-pin plug @ BCM *3   |
|       HEADLIGHTS|yellow              |-  |gray 24-pin plug @ BCM *3   |
|     DOOR TRIGGER|*5                  |-  |gray 16-pin plug @ BCM *3   |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / black           |-  |gray 24-pin plug @ BCM *3   |
|TRNK/HTCH RELEASE|black               |-  |release switch              |
|FCTRY ALRM DISARM|lt green            |-  |gray 16-pin plug @ BCM *3   |
|       TACHOMETER|white               |   |ignition coil               |
|      SPEED SENSE|green               |   |gray 16-pin plug @ BCM *3   |
|       BRAKE WIRE|white               |+  |brake switch                |
|     HORN TRIGGER|black *6            |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |drivers window switch       |
|  RF WINDOW UP/DN|lt. blu - tan       |A  |drivers door harness        |
|  LR WINDOW UP/DN|green - purple      |A  |drivers door harness        |
|  RR WINDOW UP/DN|lt. grn - purple    |A  |drivers door harness        |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
Notes:
NOTE: This vehicle has the passlock II immobilizer system *1 The ignition harness is located far right of the steering column, behind the ignition switch.  *2 Lock and unlock use the same wire. Lock requires a negative trigger with a 470 ohm resistor in-line. Unlock is negative trigger. Must use relays.    *3 The BCM is located above the brake pedal. It is a plastic box with three plugs that face the firewall.  *4 Installation of factory keyless upgrade alarm is not recommended on this vehicle because the door lock motor wires rest at approximately 7 volts.  *5 The drivers door trigger wire is blue. Blue/white will catch all other doors. Use both wires and diode isolate each.  *6 Horn can also be found at the black plug with a blue insert above the gas pedal.  *7 This wire must be powered as an accessory wire. If powered as an 2nd ignition the car will not crank.  *8 Must isolate this wire from the BCM when doing remote start to avoid 'service engine soon' light. See directfax document #1600 for wiring information.
Posted By: malucyk
Date Posted: October 17, 2002 at 9:39 PM
Thanks for the diagram.
it says something about isolating a neg parking light wire from the BCM to avoid engine light. It says see directfax document #1600 for the wiring diagram.
Any help on this would be appreciated. Thanks.
Matthew
Date Posted: October 18, 2002 at 5:27 AM
Just use a relay to reverse the polarity of the parking light wire from the RS unit. This will isolate this wire from the parkingl ights.
