2002 Chevrolet Cavalier Z24
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4577
Printed Date: May 05, 2024 at 9:12 AM
Topic: 2002 Chevrolet Cavalier Z24
Posted By: malucyk
Subject: 2002 Chevrolet Cavalier Z24
Date Posted: October 17, 2002 at 7:08 PM
Wiring diagram requsted for a 2002 Chev Cavalier Z24.
Matt
Posted By: Velocity Motors
Date Posted: October 17, 2002 at 8:45 PM
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*2 |either kick panel           |
|     POWER UNLOCK|white               |*2 |either kick panel           |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |harness to rear, dkp        |
|       HEADLIGHTS|dk. blue            |-  |headlight switch            |
|     DOOR TRIGGER|grn/blk & lt. blue  |-  |*3                          |
|  TRUNK/HATCH PIN|black               |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |BCM *4                      |
|       TACHOMETER|PURPLE / white        |   |engine harness *1           |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE: This vehicle has the passlock II immobilizer system  *1 The engine harness is found next to the battery, below the radiator hose, just above the transaxle.   *2 Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A). Also found at BCM.  *3 The GREEN/ black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each. Also found at BCM.  *4 The BCM is located to the left of the steering column above the kick panel.
