Isuzu Axiom 2004
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46235
Printed Date: May 03, 2024 at 7:29 AM
Topic: Isuzu Axiom 2004
Posted By: jayyzr
Subject: Isuzu Axiom 2004
Date Posted: December 28, 2004 at 5:28 PM
I need the wiring information to hook up an remote starter
------------- Taking It 1 Wire @ A Time...
Posted By: boomer_106
Date Posted: December 28, 2004 at 7:55 PM
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | BLACK/ White to WHITE/ blue(+) | Ignition switch harness* | Ignition #1: | | BLACK / YELLOW to BLACK/ Red (+) | Ignition switch harness | Ignition #2: | | Blue (+) | Ignition switch harness | Ignition #3: | | N/A | Ignition switch harness | Accessory: | | BLACK/ Red to BLACK / YELLOW (+) | Ignition switch harness | Brake Light: | | Red (+) | Brake pedal switch | Tach Signal: | | BLACK/ Red (AC) | Drivers kick panel in black harness | Parking Lights: | | GREEN/ Red (+) | Drivers kick panel | Headlights: | | N/A | | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | N/A | | Notes: | | *The ignition cylinder wires change color after a junction plug, the first color listed is on the ignition cylinder side and the second color is the fuse box side. |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | White & WHITE/ Black (+) | Ignition switch harness | OEM Alarm Disarm: | | Blue / YELLOW (-) | Drivers kick panel | Dome Lights/Superv: | | Red (-) | Drivers kick panel | OEM Horn: | | Green or Orange (-) | Steering column harness | Power Lock: | | Lt.GREEN/ Red (-) | Either kick panel** | Power Unlock: | | RED / Blue (-) | Either kick panel | Trunk Release: | | N/A | | Alarm Input Wire: | | Red (-) | Drivers kick panel | Notes: | | ** See Note #201 Negative Trigger Door Locks |
Posted By: jayyzr
Date Posted: December 28, 2004 at 8:39 PM
Date Posted: December 28, 2004 at 8:41 PM
You're Welcome.
