2005 Toyota Matrix Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46272
Printed Date: May 03, 2024 at 11:32 AM
Topic: 2005 Toyota Matrix Alarm/Remote Start Wiring
Posted By: euroman
Subject: 2005 Toyota Matrix Alarm/Remote Start Wiring
Date Posted: December 29, 2004 at 3:22 AM
Purchased an alarm and remote start But I need wiring info for a 2005 Toyota Matrix
Posted By: KarTuneMan
Date Posted: December 29, 2004 at 6:44 PM
12volts | white (25A), black (15A) | + | ignition harness | Starter | red | + | ignition harness | Second Starter | N/A | | | Ignition | BLACK/ white | + | ignition harness | Second Ignition | BLACK / YELLOW | + | ignition harness | Third Ignition | N/A | | | Accessory | blue/red | + | ignition harness | Second Accessory | N/A | | | Keysense | blue/black | - | ignition harness | Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors. | Power Lock | green | - | driver kick, 10 pin plug | Notes: Meter these wires while turning the key in the driver door key cylinder. | Power Unlock | blue / YELLOW (double pulse) | - | driver kick, 10 pin plug | Notes: Meter these wires while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug. | Lock Motor | blue | 5wi | driver kick, blue 12 pin plug | Unlock Motor | red | 5wi | driver kick, blue 12 pin plug | Parking Lights+ | green | + | driver kick, harness to rear | Parking Lights- | GREEN / WHITE | - | headlight switch | Hazards | yellow/black | - | flasher relay left of fuse box | Turn Signal(L) | GREEN/ black | + | flasher relay left of fuse box | Turn Signal(R) | GREEN/ YELLOW | + | flasher relay left of fuse box | Reverse Light | RED / black | + | front of fuse box, 10 pin plug | Door Trigger | RED / white | - | interior light switch on dash | Dome Supervision | RED / black | - | interior light switch on dash | Trunk/Hatch Pin | common with door trigger wire | | | Hood Pin | N/A | | | Trunk/Hatch Release | blue/white | - | release switch on dash | Power Sliding Door | N/A | | | Factory Alarm Arm | arms with lock | | | Factory Alarm Disarm | disarms with unlock | | | Disarm No Unlock | use key sense wire | | | Tachometer | black | ac | ECM, far right plug, pin 5 | Notes: The ECM (Engine Control Module) is behind the glove box.
On the XRS models, the tach wire is in the second plug from the right, pin 3. | Wait to start | N/A | | | Brake Wire | GREEN / WHITE | + | brake pedal switch | Parking Brake | RED / black | - | parking brake switch | Horn Trigger | GREEN/ YELLOW | - | steering column | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Immobilizer Bypass Module: | Required: Yes | Type: Transponder | Part #: 556U or 555U |
