04 Golf
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46316
Printed Date: May 11, 2024 at 12:57 PM
Topic: 04 Golf
Posted By: sound decision
Subject: 04 Golf
Date Posted: December 29, 2004 at 6:52 PM
I am putting in a deck into a 04 golf. the power wires seem to be giving me weird readings. It is the monsoon deck originally with the double din opening,and I am putting in a JVC. If i just use the metra 70-9003 harness will it all work or is there a trick to it???? When I first looked at the car I didn't have the harness so I was just testing the wires. So I guess what I am asking is if the monsoon system needs more work that just using the 70-9003 harness.
Thanks in Advance
Posted By: auex
Date Posted: December 30, 2004 at 10:00 PM
You will probably have to bypass the amplifier, it is on the driver's side either behind the big panel or under the rear deck. Check into this model harness, 70-1787 .Here is the wiring info,
LF Speaker +/- blue/white - BROWN / white +,- radio harness
RF Speaker +/- red - BROWN / red +,- radio harness
LR Speaker +/- RED / green - BROWN / green +,- radio harness
RR Speaker +/- blue - BROWN / blue +,- radio harness
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
