Saturn remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47168
Printed Date: May 03, 2024 at 9:23 AM
Topic: Saturn remote start
Posted By: stiverp
Subject: Saturn remote start
Date Posted: January 07, 2005 at 8:29 PM
 Has anyone put a remote start on an 2002 L200 ? Do I need anything extra (bypass, or a 5 wire) ? Does anyone have a wiring diagram? Thanks, Stiver.
Posted By: mobileworks
Date Posted: January 07, 2005 at 10:11 PM
Saturn
L Series
2000-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle  ColorLocation
Start:
YELLOWIGNITION SWITCH HARNESS *
Ignition  #1:
PINKIGNITION SWITCH HARNESS
Ignition  #2:
ORANGEIGNITION SWITCH HANRESS
Ignition  #3:
GREEN (-)IGNITION SWITCH HARNESS **
Accessory:
BROWNIGNITION SWITCH HARNESS
Brake  Light:
BLUEAT PEDAL OR DRIVER'S KICK PANEL
Tach  Signal:
Parking Lights:
BROWN (+)AT HEADLIGHT SWITCH
Headlights:
Diesel  Glow Plug:
Clutch  Bypass Wire:
NOTES: * This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. - General Motors PASSLOCK II Bypass Diagram. ** This Is The Key Sense Wire. It Needs To See Ground During Remote Start To Prevent ""Service"" Light From Coming On.
Alarm and Keyless Entry Wiring Colors
Function
Constant  +12 Volts:
RED
OEM Alarm Disarm:
Dome  Lights/Superv:
SEE NOTE BELOW ***
OEM Horn:
LT. BLUE/RED (-)
STEERING COLUMN (AIR BAG) HARNESS
Power  Lock:
ORANGE / BLACK (+)
DRIVER'S KICK PANEL ****
Power  Unlock:
RED / BLACK (+)
Trunk  Release:
BLACK (+)
AT SWITCH OR IN TRUNK
Alarm  Input Wire:
SEE NOTE BELOW ***
NOTES: *** GREY/BLACK & BLACK/ WHITE AT BCM. CONNECT BOTH WIRES AND DIODE ISOLATE. **** Positive Pulse Door Lock System. Positive Pulse Door Lock System.
You can use a code alarm PLXR for the passlock 2 bypass...
https://www.mobileworksaudio.com/shopdisplayproducts.son?page=2
Posted By: evilburl
Date Posted: February 01, 2005 at 11:06 PM
Would this be the same as  a 1993 sl2? I have been looking and looking
