2002 nissan sentra remote start and door lock schematics. please help i don't want a fire. thanks.
Constant 12 volts | WHITE/ RED | IGNITION SWITCH HARNESS |
Ignition 12 volts | BLACK/ RED | IGNITION SWITCH HARNESS |
Starter | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Dome Light | RED / WHITE (-) | 20 PIN CONNECTOR IN DR. KICK PANEL * |
Trunk Pin Switch | RED / BLACK (-) | AT LIGHT IN TRUNK ** |
Parking Lamp | WHITE/ RED (+) | AT HEADLIGHT SWITCH |
Power Lock | GRAY | 16 PIN CONNECTOR |
Power Unlock | PURPLE / RED | IN DRIVER KICK PANEL |
* With Power Locks Doem Light Can Be Found As RED (-) And RED / WHITE At "Smart Entry Control Timer" Behind Driver Dash. ** With OEM Alarm: RED / BLACK (-) Trunk Wire Also Located At "Smart Entry Control Timer" Behind Driver Dash
Negative Pulse Door Locks
Accessories |
Window Up | D\ GRN/RED P\ RED / WHT D\ YELLOW P\ GRN/WHT @ MAIN SWITCH | |
Window Down | F/ BLUE F/ RED R/ YEL/BLU R/ GREEN | |
Ign Key Warn | | |
Trunk Release | RED (-) | AT TRUNK RELEASE SWITCH |
OEM Horn | WHITE/ GREEN (-) | STEERING COLUMN HARNESS |
Headlights | RED / YELLOW (DR) & | VIOLET (PS) (+) AT HEADLIGHT SW. |
OEM Alarm Arm | L GREEN/ RED (-) | AT "SMART ENTRY CONTROL UNIT" |
OEM Alarm Disarm | WHITE/ BLUE (-) | LOCATED BEHIND DRIVER DASH |
Reversal Rest At Ground Power Window Circuit
Remote Start |
Tach Signal | RED STRIPE | AT ENGINE CONTROL MODULE * |
Ignition #2 | | |
Ignition #3 | | |
Accessory | WHITE | IGNITION SWITCH HARNESS |
Neutral Safety | | |
Brake Light | RED / GREEN (+) | AT BRAKE SWITCH |
Reverse Light | | |
Rear Window Defrost | | |
*Engine Control Module Located Behind Center Console. BLACK / YELLOW Cold Start Wire Needs To Be Powered Up In The Start Mode.
Immobilizer Bypass
MO
