2005 Toyota 4runner SE alarm w/r start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49249
Printed Date: April 29, 2024 at 9:08 AM
Topic: 2005 Toyota 4runner SE alarm w/r start
Posted By: DevineT4R
Subject: 2005 Toyota 4runner SE alarm w/r start
Date Posted: February 03, 2005 at 1:38 AM
I need a 2005 Toyota 4Runner Wiring diagram to install a Compustar Alarm w/ remote start.
Posted By: jandjav
Date Posted: February 05, 2005 at 12:47 AM
MODEL | YEAR(S) | 4-RUNNER | 2005 - |
KEY | T-HARNESS | IMMOBILIZER | N/A | N/A | 791 BYPASS MODULE and EXTRA IGNITION KEY |
PART | COLOR | LOCATION | DIAGRAM | 12 VOLT CONSTANT | WHITE/ BLUE and RED (+) | IGNITION SWITCH HARNESS | | STARTER | GREEN/ BLACK (+) | IGNITION SWITCH HARNESS | | STARTER 2 | N/A | | | IGNITION 1 | BLACK/ RED (+) | IGNITION SWITCH HARNESS | | IGNITION 2 | BLUE / YELLOW (+) | IGNITION SWITCH HARNESS | | IGNITION 3 | N/A | | | ACCESSORY /HEATER BLOWER 1 | WHITE/ GREEN (+) | IGNITION SWITCH HARNESS | | ACCESSORY /HEATER BLOWER 2 | N/A | | | KEYSENSE | GREEN/ YELLOW (-) | IGNITION SWITCH HARNESS | | PARKING LIGHTS ( - ) | GREEN (-) | @ BECU, TOP PLUG PIN 8 See NOTE *1 | | PARKING LIGHTS ( + ) | GREEN (+) | LEFT of FUSES, 16-PIN Plug | | POWER LOCK | BLUE | IN DRIVERS KICK PANEL, 18-PIN Plug (TYPE B) | | POWER UNLOCK | GREEN (DOUBLE PULSE) | IN DRIVERS KICK PANEL, 18-PIN Plug (TYPE B) | | DOOR TRIGGER | PURPLE / YELLOW (-) | @ BECU, TOP Plug, PIN 12 See NOTE *1 | | DOMELIGHT SUPERVISION | WHITE (-) | @ Plug to the RIGHT of the FUSES, Pin 8 | | TRUNK RELEASE | N/A | | | SLIDING POWER DOOR | N/A | | | HORN | GREEN/ RED (-) | @ HORN SWITCH | | TACH | BLACK/ WHITE | @ ECM BEHIND GLOVEBOX See NOTE *2 | | WAIT TO START LIGHT | N/A | | | BRAKE | GREEN/ YELLOW (+) | LEFT of FUSES, 16-Pin Plug | | FACTORY ALARM DISARM | DISARMS with KEYSENSE wire | | | ANTI-THEFT | TRANSPONDER | @ IGNITION SWITCH TUMBLER | |
EXTRA INFORMATION | NOTE *1 the BECU is part of the FUSE/RELAY BOX under the DRIVERS SIDE of the DASH. the unit has 3 Plugs on the RIGHT SIDE of the FUSE BOX, these are the BECU harnesses. NOTE *2 on 6 Cylinder vehicles, it is the second plug from the bottom, Pin 1, or at the DATA LINK Connector under the drivers side of the dash,and on the V-8, it is in the bottom plug, Pin 5. |
LINK 1 | LINK TEXT 1 | LINK 2 | LINK TEXT 2 | | | | |
