2001 Honda CR-V wiring codes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5185
Printed Date: April 29, 2024 at 9:04 PM
Topic: 2001 Honda CR-V wiring codes
Posted By: boymata
Subject: 2001 Honda CR-V wiring codes
Date Posted: November 06, 2002 at 2:52 PM
Greetings. Does anyone have the codes and location for the wiring? I have installed remote start system and for safety and precise troubleshoot, wiring codes would be logical.
I am backtracking my malfunctions>>>ingnition controlled door locks, etc. thanks to everyone.
thank you
Posted By: Velocity Motors
Date Posted: November 06, 2002 at 2:55 PM
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|GREEN / WHITE *2      |-  |driver door harness *3      |
|     POWER UNLOCK|GREEN/ orange *2     |-  |driver door harness *3      |
|       LOCK MOTOR|WHITE/ red           |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/red            |   |drivers kick panel          |
|    DISARM DEFEAT|yellow/red          |   |passengers kick panel       |
| PARKING LIGHTS +|RED / black           |   |dash dimmer                 |
| PARKING LIGHTS -|blue/red            |   |*6                          |
|       HEADLIGHTS|RED / white           |+  |headlight switch            |
|     DOOR TRIGGER|lt. GREEN/ red       |-  |drivers kick *3             |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|blue/black          |-  |drivers kick *3             |
|         HOOD PIN|yellow/red or yellow|-  |hood switch *3              |
|TRNK/HTCH RELEASE|yellow              |+  |release switch              |
|       TACHOMETER|blue                |   |test connector *1           |
|      SPEED SENSE|blue/white          |   |instrument cluster or PCM *7|
|       BRAKE WIRE|GREEN / WHITE         |+  |cruise control *5           |
|     HORN TRIGGER|gray *4             |-  |drivers kick                |
|           WIPERS|blue(L), blu/yel(H) |-  |steering column             |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |power window switch         |
|  RF WINDOW UP/DN|blu/yel - blu/orn   |A  |power window switch         |
|  LR WINDOW UP/DN|grn/yel - green     |A  |power window switch         |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |power window switch         |
Notes:
*1 Found at the 2-pin tach test connector on the drivers side of the firewall.  *2 Must use relays to trigger the lock and unlock wires.  *3 Also found at the green factory alarm plug located in the drivers kick panel.   *4 May also use blue/green at the steering column, negative trigger.  *5 The cruise control module is located in the drivers kick panel.  *6 This wire only works if there is a factory alarm installed. It is at the green factory alarm plug in the drivers kick.  *7 The PCM is in the passenger kick panel. VSS is in the 31 pin plug, pin 23.
Posted By: boymata
Date Posted: November 07, 2002 at 6:47 AM
Thank you Jeff. Much oblige to you.
thank you
