2005 ford escape alarm and starter info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54814
Printed Date: April 28, 2024 at 5:31 PM
Topic: 2005 ford escape alarm and starter info
Posted By: cfd324
Subject: 2005 ford escape alarm and starter info
Date Posted: April 29, 2005 at 6:36 AM
If anyone has info for a 2005 ford escape alarm and starter info with door lock and tach wire it would be much apreciated. Thanks....
Posted By: thepencil
Date Posted: April 29, 2005 at 10:02 AM
DIRECTWIRE™ WIRING INFORMATION - FORD / ESCAPE / 2005 / Remote Start
12volts red (10A)   +   ignition harness
Starter tan/lt. blue   +   ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green   +   ignition harness
Second Accessory N/A
Keysense BLACK/ pink   +   ign. harn. or SJB, conn. E, pin 29
Notes: The SJB (Smart Junction Box) is the fuse/relay box on the passenger side of the center console.
Power Lock pink/white   -   driver kick or SJB, conn. D, pin 22
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor pink/black   5wi driver kick or SJB, conn. C, pin 20
Unlock Motor RED / orange   5wi driver kick or SJB, conn. C, pin 3
Parking Lights+ brown   +   driver kick or SJB, conn. C, pin 19
Parking Lights- WHITE/ black   -   switch or SJB, conn. E, pin 4
Hazards RED / white   -   switch or SJB, conn. E, pin 5
Turn Signal(L) lt grn/wht (F), lt grn/wht (R) +   SJB, conn B, pin 14 & conn C, pin 6
Turn Signal(R) wht/lt blu (F), wht/lt blu (R) +   SJB, conn B, pin 23 & conn C, pin 9
Reverse Light BLACK/ pink   +   driver kick or SJB, conn. C, pin 10
Door Trigger use dome supervision wire
Dome Supervision pink   -   driver kick or SJB, conn. C, pin 28
Trunk/Hatch Pin use dome supervision wire
Hood Pin PURPLE / orange   -   pin switch or SJB, conn. B, pin 5
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm WHITE/ purple   -   driver kick or SJB, conn. D, pin 2
Factory Alarm Disarm dk. blue/lt. green   -   driver kick or SJB, conn. D, pin 3
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or WHITE/ red (Hybrid)   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green   +   switch or SJB, conn. C, pin 14
Parking Brake lt. GREEN/ red   -   switch or SJB, conn. D, pin 13
Horn Trigger yellow/lt. green   -   column or SJB, conn. A, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 556U or 555U
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
